122NQ030-1
122NQ030-1
    SMCDIODESOLUTIONS(桑德斯)
    HALF-PAK
    电压:30V 电流:120A
122NQ030-1 数据手册
122NQ030/R-1 Technical Data Data Sheet N1017, Rev. A Green Products 122NQ030/R-1 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • • 150℃ TJ operation Unique high power, Half-Pak module Replaces three parallel DO-5’S Easier to mount and lower profile than DO-5’S High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device 122NQ030R-1 122NQ030-1 All SMC parts are traceable to the wafer lot The top side is terminal, the bottom side Additional testing can be offered upon request is base plate. Mechanical Dimensions: In Inches / mm PRM1-1(HALF PAK Module) MARKING, MOLDING RESIN st nd Marking for 122NQ030/R-1, 1 row SS YYWWL, 2 row 122NQ030-1/122NQ030R-1 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL: 94V-0 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 122NQ030/R-1 Technical Data Data Sheet N1017, Rev. A Green Products Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current Symbol VRRM VRWM VR IF(AV) Peak One Cycle Non-Repetitive Surge Current (per leg) IFSM Condition - Max. 30 Units V 50% duty cycle @TC =110°C, rectangular wave form 120 A 8.3 ms, half Sine pulse 2880 A Electrical Characteristics: Characteristics Forward Voltage Drop(per leg) * Symbol VF1 VF2 Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 120A, Pulse, TJ = 25 °C @ 240A, Pulse, TJ = 25 °C @ 120A, Pulse, TJ = 125 °C @ 240A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.49 0.59 0.41 0.54 10 560 Units 7400 pF 7.0 nH 10,000 V/μs V V mA mA Pulse Width < 300µs, Duty Cycle
122NQ030-1 价格&库存
很抱歉,暂时无法提供与“122NQ030-1”相匹配的价格&库存,您可以联系我们找货
122NQ030-1
  • 1+326.457981+42.28773
  • 27+217.3091227+28.14913
  • 108+196.81886108+25.49493
库存:210
