RL103TA
RL103TA
    SMCDIODESOLUTIONS(桑德斯)
    Axial
    DIODEGENPURP200V1AA-405
RL103TA 数据手册
RL101-RL107 Green Products Technical Data Data Sheet N0557, Rev. - RL101 THRU RL107 Features:         GENERAL PURPOSE SILICON RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Amperes The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Construction utilizes void-free molded plastic technique Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 250°C/10 seconds, 0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data:      Case: A-405 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.008 ounce, 0.23 grams Mechanical Dimensions: In Inches/mm A-405  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  RL101-RL107 Green Products Technical Data Data Sheet N0557, Rev. - MARKING DIAGRAM: Where XXXXX is YYWWL RL101 SSG YY WW L = Part Name = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 ORDERING INFORMATION Device Package A-405 (Pb-Free) RL101-RL107 Shipping 5000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol RL101 RL102 RL103 RL104 RL105 RL106 RL107 Unit Maximum repetitive peak reverse voltage Maximum DC blocking voltage VRRM VDC 50 100 200 400 Maximum RMS voltage VRMS 35 70 140 280 Maximum average forward rectified current 0.375”(9.5mm) lead length @TA = 75°C I(AV) 1.0 A Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30.0 A Maximum instantaneous forward voltage at 1.0A VF 1.1 V Maximum DC reverse current @TA = 25°C at rated DC blocking voltage @TA = 100°C IR 5.0 50.0 µA Typical Junction Capacitance (Note 1) CJ 15.0 pF RθJA 50.0 °C/W TJ,TSTG -65 to +175 °C Typical Thermal Resistance (Note 2) Operating and Storage Temperature Range 600 420 Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal resistance from junction to ambient at 0.375” (9.5mm) lead length, P.C.B. mounted.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  800 1000 V 560 700 V RL101-RL107 Technical Data Data Sheet N0557, Rev. -  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products RL101-RL107 Technical Data Data Sheet N0557, Rev. - Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
RL103TA 价格&库存
很抱歉,暂时无法提供与“RL103TA”相匹配的价格&库存,您可以联系我们找货
