1F4TA
1F4TA
    SMCDIODESOLUTIONS(桑德斯)
    R-1
    DIODE GEN PURP 400V 1A R-1
1F4TA 数据手册
1F1-1F7 Technical Data Data Sheet N0429, Rev.- FEATURES      Green Products 1F1 THRU 1F7 FAST RECOVERY RECTIFIERS Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Fast switching for high efficiency Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 260℃ /10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension MECHANICAL DATA      Case: R-1 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.007 ounce, 0.20 grams MECHANICAL DIMENSIONS: In Inches/mm R-1(XH)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1F1-1F7 Green Products Technical Data Data Sheet N0429, Rev.- MARKING DIAGRAM Where XXXXX is YYWWL 1F1 SSG YY WW L = Part Name = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 ORDERING INFORMATION Device Package R-1 (Pb-Free) 1F1-1F7 Shipping 5000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. Characteristic Symbol 1F1 Maximum repetitive peak reverse voltage Maximum DC blocking voltage VRRM VDC 50 Maximum RMS voltage VRMS Maximum average forward rectified current 0.375”(9.5mm) lead length at @TA = 25°C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) I(AV) 1.0 A IFSM 25.0 A Maximum instantaneous forward voltage at 1.0A VF 1.3 V Maximum DC reverse current At Rated DC Blocking Voltage IRM 5.0 50 µA @TA = 25°C @TA = 125°C 35 1F2 1F3 1F4 1F5 1F6 1F7 Unit 5 100 3 70 1 200 7 140 2 400 1 280 4 600 2 420 6 800 4 560 8 1000 5 700 1 V Maximum reverse recovery time (Note 1) trr Typical Junction Capacitance (Note 2) CJ 15 pF RθJA 50 °C/W TJ, TSTG -55 to +150 °C Typical Thermal Resistance Junction to Ambient (Note 3) Operating junction and storage temperature range 150 250 Note: 1.Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  500 1 V ns 1F1-1F7 Technical Data Data Sheet N0429, Rev.- Green Products  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1F1-1F7 Technical Data Data Sheet N0429, Rev.- Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
1F4TA 价格&库存
很抱歉,暂时无法提供与“1F4TA”相匹配的价格&库存,您可以联系我们找货
