1N4448WSTR
1N4448WSTR
    SMCDIODESOLUTIONS(桑德斯)
    SOD-323F
    Diode Standard 75V 250mA Surface Mount SOD-323
1N4448WSTR 数据手册
1N4448WS SURFACE MOUNT FAST SWITCHING DIODE Green Products Technical Data Data Sheet N0579, Rev. - 1N4448WS FAST SWITCHING DIODE Features:     Small Package Low Reverse Current Fast Switching Speed Surface Mount Package Ideally Suited for Automatic Insertion Mechanical Data:      Case: SOD-323, Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Marking: T5 Weight: 0.004 grams(approx) Mechanical Dimensions: In mm / Inches SOD-323(CJ)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1N4448WS SURFACE MOUNT FAST SWITCHING DIODE Green Products Technical Data Data Sheet N0579, Rev. - Marking Diagram: T5 = Part Name Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device 1N4448WS Package Shipping SOD-323(Pb-Free) 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1N4448WS SURFACE MOUNT FAST SWITCHING DIODE Green Products Technical Data Data Sheet N0579, Rev. - Maximum Ratings @Ta=25℃ Characteristic Symbol Value Unit VRM 100 V VRRM VRWM VR 75 V VR(RMS) 53 V Forward Continuous Current IFM 500 mA Average Rectified Output Current Io 250 mA Non-Repetitive Peak Forward Surge Current @t=8.3ms IFSM 2.0 A Power Dissipation PD 200 mW RθJA 625 °C/W TJ, TSTG -65 to +150 °C Non-Repetitive Peak Reverse Voltage Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Thermal Resistance, Junction to Ambient Junction and Storage Temperature Range Electrical Characteristics @Ta=25℃ Characteristics Forward Voltage Drop Reverse Current Symbol VF1 IR1 IR2 Capacitance between terminals CT Reverse Recovery Time trr Condition @ 5mA, Pulse, TJ = 25 C @ 10mA, Pulse, TJ = 25 C @ 100mA, Pulse, TJ = 25 C @ 150mA, Pulse, TJ = 25 C @VR = 75V, Pulse, TJ = 25 C @ VR = 20V, Pulse, TJ = 25C @VR = 0 V, Tc=25℃ fSIG = 1MHz IF=10mA IR = 10mA TJ = 25 C Irr =1 mA RL=100Ω Min. 0.62  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Max. 0.72 0.855 1.0 1.25 Units V 2.5 μA 25 nA 4 pF 4 ns 1N4448WS SURFACE MOUNT FAST SWITCHING DIODE Technical Data Data Sheet N0579, Rev. - Typical Characteristics  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 1N4448WS SURFACE MOUNT FAST SWITCHING DIODE Technical Data Data Sheet N0579, Rev. - Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
1N4448WSTR 价格&库存
很抱歉,暂时无法提供与“1N4448WSTR”相匹配的价格&库存,您可以联系我们找货
