BAV16W
Green Products
Technical Data
Data Sheet N0589, Rev. -
BAV16W SCHOTTKY BARRIER DIODE
Features:
Fast switching speed
Surface mount package ideally suited for automatic insertion
For general purpose switching applications
High conductance
Mechanical Data:
Case: SOD-123, Molded Plastic
Terminals: Plated Leads Solderable per MIL-STD-202, Method 208
Polarity: Cathode Band
Marking: T6
Weight: 0.01 grams(approx)
Mechanical Dimensions: In mm / Inches
SOD-123(CJ)
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
BAV16W
Green Products
Technical Data
Marking Diagram:
T6
= Part Name
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
BAV16W
Package
Shipping
SOD-123(Pb-Free)
3000pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Characteristic
Symbol
Limit
Unit
VRM
75
V
VRRM
VRWM
VR
100
V
VR(RMS)
71
V
Forward Continuous Current
IFM
300
mA
Average Rectified Output Current
IO
150
mA
IFSM
2
A
Pd
400
mW
RθJA
250
°C/W
Junction Temperature Range
TJ
150
°C
Storage Temperature Range
TSTG
-55 to +150
°C
Non-Repetitive Peak Reverse Voltage
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
Power Dissipation
Typical Thermal Resistance Junction to Ambient
BAV16W
Green Products
Technical Data
Data Sheet N0589, Rev. Characteristic
Symbol
Max
Unit
Test Condition
Forward Voltage
VF
Reverse Leakage Current
IR
0.715
0.855
1.0
1.25
1
IF=1mA
V IF=10mA
IF=50mA
IF=150mA
μA VR=75V
Capacitance between terminals
CT
2
pF VR=0V,f=1.0MHz
Reverse recovery time
trr
4
ns
IF= IR=10mA, Irr=0.1×IR, RL=100Ω
Typical Characteristics
BAV16W
Technical Data
Green Products
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“BAV16WTR”相匹配的价格&库存,您可以联系我们找货
