1N4001G
1N4001G
    SMCDIODESOLUTIONS(桑德斯)
    DO-41(DO-204AL)
    Diode Standard 50V 1A Through Hole DO-41
1N4001G 数据手册
1N4001G THRU 1N4007G Technical Data Data Sheet N0544, Rev. - 1N4001G THRU 1N4007G 1.0A GLASS PASSIVATED RECTIFIER Features:         Green Products Diffused Junction Low Forward Voltage Drop High Current Capability High Reliability High Surge Current Capability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical data:      Case: Molded Plastic Terminals: Plated Leads Solderable Per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.35 grams(Approx) Mounting Position: Any Mechanical Dimensions: In mm/Inches DO-41  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1N4001G THRU 1N4007G Green Products Technical Data Data Sheet N0544, Rev. - Marking Diagram: Where XXXXX is YYWWL 1N4001G SSG YY WW L Cautions:Molding resin = Part Name = SSG = Year = Week = Lot Number Epoxy resin UL:94V-0 Ordering Information Device Package DO-41 (Pb-Free) 1N4001G-1N4007G Shipping 5000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbol Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR RMS Reverse Voltage VRMS 1N 1N 1N 1N 1N 1N 1N Unit 4001G 4002G 4003G 4004G 4005G 4006G 4007G 50 5 100 1 200 2 400 4 600 6 800 8 1000 1 V 35 3 70 7 140 1 280 2 420 4 560 5 700 1 V Average forward rectified output current @TA = 75°C IO 1.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30 A Forward Voltage @IF =1.0A VFM 1.0 V Peak Reverse Current At Rated DC Blocking Voltage @TA = 25°C @TA = 100°C IRM 5.0 50 µA Typical Junction Capacitance (Note 2) CJ 8 pF Typical Thermal Resistance Junction to Ambient (Note 1) RθJA 100 °C/W Operating Junction Temperature Range TJ -65 to +175 °C TSTG -65 to +175 °C Storage Temperature Range Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm form the case. 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1N4001G THRU 1N4007G Technical Data Data Sheet N0544, Rev. -  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products 1N4001G THRU 1N4007G Technical Data Data Sheet N0544, Rev. - Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
1N4001G 价格&库存
很抱歉,暂时无法提供与“1N4001G”相匹配的价格&库存,您可以联系我们找货
