SIT5022AI-1BE-33S-290.000000Y
    SITIME(赛特时脉)
    SMD3225_6P
    有源晶振 290MHz SMD3225_4P
SIT5022AI-1BE-33S-290.000000Y 数据手册
SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice Features Applications  Any frequency between 220 MHz and 625 MHz accurate to 6 decimal places  LVPECL and LVDS output signaling types  0.6ps RMS phase jitter (random) over 12 kHz to 20 MHz bandwidth  Frequency stability as low as ±5 ppm. Contact SiTime for tighter stability options  Industrial and extended commercial temperature ranges  Industry-standard packages: 3.2 x 2.5, 5.0 x 3.2 and 7.0 x 5.0 mm  For frequencies lower than 220 MHz, refer to SiT5021 datasheet  SATA, SAS, 10GB Ethernet, Fibre Channel, PCI-Express  Networking, broadband, instrumentation Electrical Characteristics Parameter and Conditions Symbol Min. Typ. Max. Unit Condition LVPECL and LVDS, Common Electrical Characteristics Supply Voltage Output Frequency Range Vdd f 2.97 3.3 3.63 2.25 2.5 2.75 V V 2.25 – 3.63 V 220 – 625 MHz Termination schemes in Figures 1 and 2 - XX ordering code Initial Tolerance F_init -2 – 2 ppm At 25°C after two reflows Stability Over Temperature F_stab -5 – +5 ppm Over operating temperature range at rated nominal power supply voltage and load. Contact SiTime for tighter stability options. Supply Voltage F_vdd – 50 – ppb ±10% Vdd Output Load F_load – 0.1 – ppm 15 pF ±10% of load First Year Aging F_aging1 -2.5 – +2.5 ppm 25°C 10-year Aging F_aging10 -5 – +5 ppm 25°C Operating Temperature Range Pull Range T_use -40 – +85 °C Industrial -20 – +70 °C Extended Commercial PR ±12.5, ±25, ±50 ppm Upper Control Voltage VC_U Vdd-0.1 – – V Control Voltage Range VC_L – – 0.1 V Control Voltage Input Impedance Z_vc 100 – – k 8 kHz Frequency Change Polarity Control Voltage -3dB Bandwidth – Positive slope – V_BW – Input Voltage High VIH 70% – – Vdd Pin 1, OE or ST Input Voltage Low VIL – – 30% Vdd Pin 1, OE or ST – 100 250 kΩ Pin 1, OE logic high or logic low, or ST logic high 2 – – MΩ Pin 1, ST logic low Input Pull-up Impedance Z_in – All Vdds. Voltage at which maximum deviation is guaranteed. Start-up Time T_start – 6 10 ms Measured from the time Vdd reaches its rated minimum value. Resume Time T_resume – 6 10 ms In Standby mode, measured from the time ST pin crosses DC 45 – 55 % Contact SiTime for tighter duty cycle Duty Cycle LVPECL, DC and AC Characteristics Current Consumption Idd – 61 69 mA Excluding Load Termination Current, Vdd = 3.3V or 2.5V OE Disable Supply Current I_OE – – 35 mA OE = Low Output Disable Leakage Current I_leak – – 1 A OE = Low Standby Current I_std – – 100 A ST = Low, for all Vdds Maximum Output Current Output High Voltage Output Low Voltage Output Differential Voltage Swing Rise/Fall Time OE Enable/Disable Time RMS Period Jitter RMS Phase Jitter (random) SiTime Corporation Rev. 1.5 I_driver – – 30 mA Maximum average current drawn from OUT+ or OUT- VOH VOL V_Swing Tr, Tf T_oe Vdd-1.1 Vdd-1.9 1.2 – – – – 1.6 300 – Vdd-0.7 Vdd-1.5 2.0 500 115 V V V ps ns See Figure 1(a) See Figure 1(a) See Figure 1(b) 20% to 80%, see Figure 1(a) T_jitt – 1.2 1.7 ps f = 266 MHz, VDD = 3.3V or 2.5V – 1.2 1.7 ps f = 312.5 MHz, VDD = 3.3V or 2.5V – 1.2 1.7 ps f = 622.08 MHz, VDD = 3.3V or 2.5V – 0.6 0.85 ps f = 312.5 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdds T_phj 990 Almanor Avenue, Sunnyvale, CA 94085 f = 220 MHz - For other frequencies, T_oe = 100ns + 3 period (408) 328-4400 www.sitime.com Revised November 12, 2015 SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice Electrical Characteristics (continued) Parameter and Conditions Symbol Min. Typ. Max. Unit Condition LVDS, DC and AC Characteristics Current Consumption Idd – 47 55 mA OE Disable Supply Current I_OE – – 35 mA OE = Low Differential Output Voltage VOD 250 350 450 mV See Figure 2 Output Disable Leakage Current I_leak – – 1 A OE = Low Standby Current I_std – – 100 A ST = Low, for all Vdds VOD – – 50 mV See Figure 2 VOD Magnitude Change Offset Voltage Excluding Load Termination Current, Vdd = 3.3V or 2.5V VOS 1.125 1.2 1.375 V See Figure 2 VOS Magnitude Change VOS – – 50 mV See Figure 2 Rise/Fall Time Tr, Tf – 495 600 ps 20% to 80%, see Figure 2 OE Enable/Disable Time T_oe – – 115 ns f = 220 MHz - For other frequencies, T_oe = 100ns + 3 period RMS Period Jitter T_jitt – 1.4 1.7 ps f = 266 MHz, VDD = 3.3V or 2.5V – 1.4 1.7 ps f = 312.5 MHz, VDD = 3.3V or 2.5V – 1.2 1.7 ps f = 622.08 MHz, VDD = 3.3V or 2.5V – 0.6 0.85 ps f = 312.5 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdds RMS Phase Jitter (random) T_phj Pin Description Pin Map Functionality V Control VC/OE/ST 1 Output Enable NC Top View H or Open: specified frequency output L: output is high impedance H or Open: specified frequency output L: Device goes to sleep mode. Supply current reduces to I_std. Standby 2 Voltage control NA VC/OE/ST 1 6 VDD NC 2 5 OUT- GND 3 4 OUT+ No Connect; Leave it floating or connect to GND for better heat dissipation 3 GND Power VDD Power Supply Ground 4 OUT+ Output Oscillator output 5 OUT- Output Complementary oscillator output 6 VDD Power Power supply voltage Absolute Maximum Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C VDD -0.5 4 V Electrostatic Discharge (HBM) – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C Thermal Consideration JA, 4 Layer Board JC, Bottom 7050, 6-pin 142 27 5032, 6-pin 97 20 3225, 6-pin 109 20 Package (°C/W) (°C/W) Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev. 1.5 Page 2 of 8 www.sitime.com SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice Waveform Diagrams OUT80% 80% 20% 20% VOH OUT+ Tr VOL Tf GND Figure 1(a). LVPECL Voltage Levels per Differential Pin (OUT+/OUT-) V _ S w in g 0 V t Figure 1(b). LVPECL Voltage Levels Across Differential Pair OUT80% 80% VOD 20% 20% OUT+ VOS Tr Tf GND Figure 2. LVDS Voltage Levels per Differential Pin (OUT+/OUT-) Rev. 1.5 Page 3 of 8 www.sitime.com SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice Termination Diagrams LVPECL: VDD Z 0 = 50  OUT+ D+ Receiver Device L V P E C L D rive r Z0 = 5 0  OUT- D50  50  V T T = V D D – 2.0 V Figure 3. LVPECL Typical Termination VDD= 3.3V => R1 = 100 to 150  VDD= 2.5V => R1 = 75  VDD OUT+ 100 nF Z0 = 50  D+ Receiver Device LVPECL Driver 100 nF Z0 = 50  OUTR1 R1 D50  50  VTT Figure 4. LVPECL AC Coupled Termination VDD = 3.3V => R1 = R3 = 133  and R2 = R4 = 82  VDD = 2.5V => R1 = R3 = 250  and R2 = R4 = 62.5  VDD R1 VDD OUT+ R3 Z0 = 50  D+ Receiver Device LVPECL Driver OUT- Z0 = 50  DR2 R4 Figure 5. LVPECL with Thevenin Typical Termination Rev. 1.5 Page 4 of 8 www.sitime.com SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice LVDS: VDD OUT+ Z0 = 50  D+ 100  LVDS Driver OUT- Z0 = 50  Receiver Device D- Figure 6. LVDS Single Termination (Load Terminated) Rev. 1.5 Page 5 of 8 www.sitime.com SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice Dimensions and Patterns Package Size – Dimensions (Unit: mm)[1] Recommended Land Pattern (Unit: mm)[2] 3.2 x 2.5x 0.75 mm 3.2±0.05 2.20 #4 #2 #3 #4 #6 0.9 #1 #3 #2 1.00 0.7 YXXXX 2 .2 5 #5 1.6 #5 2.5±0.05 #6 #1 0.6 0.75±0.05 0 .6 5 1 .0 5 5.0 x 3.2 x 0.75 mm #5 #4 #2 #3 #4 #5 #6 1.20 #6 YXXXX #1 #3 #2 #1 0.75±0.05 7.0 x 5.0x 0.90 mm 7.0±0.10 5.08 #2 #5 #6 #3 #3 5.08 1.10 YXXXX #1 #4 #2 3.80 #4 2.60 #5 5.0±0.10 #6 #1 1.60 0.90 ±0.10 1.40 1.60 Notes: 1. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of the device. 2. A capacitor of value 0.1 F between Vdd and GND is recommended. Rev. 1.5 Page 6 of 8 www.sitime.com SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice Ordering Information SiT5022AC -1CE-33VQ123.123456T Packaging: Part Family “T” for Tape & Reel (3 Ku Reel) “Y” for Tape & Reel (1 Ku Reel) Blank for Bulk “SiT5022” Revision Letter “A” is the revision of Silicon Frequency 220.000000 MHz to 625.000000 MHz Temperature Range “C” Extended Commercial, -20 to 70°C “I” Industrial, -40 to 85°C Pull Range Options “-” for No Pull “Q” for ±12.5 ppm “M” for ±25 ppm “B” for ±50 ppm Signalling Type “1” = LVPECL “2” = LVDS Feature Pin (pin 1) “V” for Voltage Control “E” for Output Enable “S” for Standby “N” for No Connect Package Size “B” 3.2 x 2.5 mm “C” 5.0 x 3.2 mm “D” 7.0 x 5.0 mm Supply Voltage Frequency Stability[3] “25” for 2.5V ±10% “33” for 3.3V ±10% “XX” for 2.5 to 3.3V ±10% “E” for ±5.0 ppm Note: 6. Contact SiTime for tighter stability options. Frequencies Not Supported Range 1: From 251.000001 MHz to 263.999999 MHz Range 2: From 314.000001 MHz to 422.999999 MHz Range 3: From 502.000001 MHz to 527.999999 MHz Ordering Codes for Supported Tape & Reel Packing Method Device Size 12 mm T&R (3ku) 12 mm T&R (1ku) 12 mm T&R (250u) 16 mm T&R (3ku) 16 mm T&R (1ku) 16 mm T&R (250u) 7.0 x 5.0 mm – – – T Y X 5.0 x 3.2 mm T Y X – – – 3.2 x 2.5 mm T Y X – – – Rev. 1.5 Page 7 of 8 www.sitime.com SiT5022 220-625 MHz High Performance Differential (VC) TCXO The Smart Timing Choice The Smart Timing Choice Additional Information Document Description Download Link Manufacturing Notes Tape & Reel dimension, reflow http://www.sitime.com/component/docman/doc_download/85-manufacturing-notes-for-sitime-oscillators profile and other manufacturing related info Qualification Reports RoHS report, reliability reports, composition reports http://www.sitime.com/support/quality-and-reliability Performance Reports Additional performance data such as phase noise, current consumption and jitter for selected frequencies http://www.sitime.com/support/performance-measurement-report Termination Techniques Termination design recommendations http://www.sitime.com/support/application-notes Layout Techniques Layout recommendations http://www.sitime.com/support/application-notes Revision History Version Release Date 1.2 8/20/13 Change Summary 1.3 12/16/13 Added input specifications, LVPECL/LVDS waveforms, packaging T&R options 1.4 12/11/14 Modified Thermal Consideration values and Pin Configuration table (pin 1) and drawing 1.5 11/12/15 • Revised stability over temperature and first year aging values in the electrical characteristics table • Revised frequency stability option Original © SiTime Corporation 2015. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liability for any loss, damage or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or (iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress. Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below. CRITICAL USE EXCLUSION POLICY BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE. SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly prohibited. Rev. 1.5 Page 8 of 8 www.sitime.com The Smart Timing Choice The Smart Timing Choice Supplemental Information The Supplemental Information section is not part of the datasheet and is for informational purposes only. SiTime Corporation 990 Almanor Avenue, Sunnyvale, CA 94085 (408) 328-4400 www.sitime.com The Smart Timing Choice The Smart Timing Choice Silicon MEMS Outperforms Quartz SiTime Corporation Silicon MEMS Outperforms Quartz Rev. 1.2 990 Almanor Avenue, Sunnyvale, CA 94085 (408) 328-4400 www.sitime.com Revised November 13, 2015 Silicon MEMS Outperforms Quartz The Smart Timing Choice The Smart Timing Choice Best Reliability Best Electro Magnetic Susceptibility (EMS) Silicon is inherently more reliable than quartz. Unlike quartz suppliers, SiTime has in-house MEMS and analog CMOS expertise, which allows SiTime to develop the most reliable products. Figure 1 shows a comparison with quartz technology. SiTime’s oscillators in plastic packages are up to 54 times more immune to external electromagnetic fields than quartz oscillators as shown in Figure 3. Why is SiTime Best in Class: • SiTime’s MEMS resonators are vacuum sealed using an advanced EpiSeal™ process, which eliminates foreign particles and improves long term aging and reliability • World-class MEMS and CMOS design expertise Why is SiTime Best in Class: • Internal differential architecture for best common mode noise rejection • Electrostatically driven MEMS resonator is more immune to EMS SiTime vs Quartz Electro Magnetic Susceptibility (EMS) Reliability (Million Hours) - 30 IDT Epson 1,140 38 28 Average Spurs (dB) - 39 SiTime - 40 - 40 - 42 - 43 - 45 - 50 - 60 SiTime 54X Better - 70 - 73 - 80 - 90 Kyocera Figure 1. Reliability Comparison[1] Epson TXC CW SiLabs SiTime Figure 3. Electro Magnetic Susceptibility (EMS)[3] Best Aging Best Power Supply Noise Rejection Unlike quartz, MEMS oscillators have excellent long term aging performance which is why every new SiTime product specifies 10-year aging. A comparison is shown in Figure 2. SiTime’s MEMS oscillators are more resilient against noise on the power supply. A comparison is shown in Figure 4. • SiTime’s MEMS resonators are vacuum sealed using an advanced EpiSeal process, which eliminates foreign particles and improves long term aging and reliability • Inherently better immunity of electrostatically driven MEMS resonator SiTime MEMS vs. Quartz Aging 10 SiTime MEMS Oscillator Quartz Oscillator 8.0 Aging (±PPM) 8 SiTime 2X Better 6 4 2 0 3.0 3.5 1.5 1-Year 10-Year Figure 2. Aging Comparison[2] Silicon MEMS Outperforms Quartz Rev. 1.2 Why is SiTime Best in Class: • On-chip regulators and internal differential architecture for common mode noise rejection • Best analog CMOS design expertise Additive Integrated Phase Jitter per mVp-p Injected Noise (ps/mv) Why is SiTime Best in Class: Power Supply Noise Rejection SiTIme 5.0 NDK Epson Kyocera 4.0 3.0 2.0 SiTime  SiTime 3X Better 1.0 0.0 10 100 1,000 Power Supply Noise Frequency (kHz) 10,000 Figure 4. Power Supply Noise Rejection[4] www.sitime.com Silicon MEMS Outperforms Quartz The Smart Timing Choice The Smart Timing Choice Best Vibration Robustness Best Shock Robustness High-vibration environments are all around us. All electronics, from handheld devices to enterprise servers and storage systems are subject to vibration. Figure 5 shows a comparison of vibration robustness. SiTime’s oscillators can withstand at least 50,000 g shock. They all maintain their electrical performance in operation during shock events. A comparison with quartz devices is shown in Figure 6. Why is SiTime Best in Class: Why is SiTime Best in Class: • The moving mass of SiTime’s MEMS resonators is up to 3000 times smaller than quartz • Center-anchored MEMS resonator is the most robust design • The moving mass of SiTime’s MEMS resonators is up to 3000 times smaller than quartz • Center-anchored MEMS resonator is the most robust design Vibration Sensitivity (ppb/g) TXC Epson Connor Winfield Kyocera SiLabs 100.00 10.00 1.00 SiTime Up to 30x Better 0.10 10 100 Vibration Frequency (Hz) Figure 5. Vibration Robustness[5] 1000 Peak Frequency Deviation (PPM) Vibration Sensitivity vs. Frequency SiTime 16 14 Differential XO Shock Robustness - 500 g 14.3 12.6 12 10 8 SiTime Up to 25x Better 6 3.9 4 2.9 2.5 2 0.6 0 Kyocera Epson TXC CW SiLabs SiTime Figure 6. Shock Robustness[6] Notes: 1. Data Source: Reliability documents of named companies. 2. Data source: SiTime and quartz oscillator devices datasheets. 3. Test conditions for Electro Magnetic Susceptibility (EMS): • According to IEC EN61000-4.3 (Electromagnetic compatibility standard) • Field strength: 3V/m • Radiated signal modulation: AM 1 kHz at 80% depth • Carrier frequency scan: 80 MHz – 1 GHz in 1% steps • Antenna polarization: Vertical • DUT position: Center aligned to antenna Devices used in this test: SiTime, SiT9120AC-1D2-33E156.250000 - MEMS based - 156.25 MHz Epson, EG-2102CA 156.2500M-PHPAL3 - SAW based - 156.25 MHz TXC, BB-156.250MBE-T - 3rd Overtone quartz based - 156.25 MHz Kyocera, KC7050T156.250P30E00 - SAW based - 156.25 MHz Connor Winfield (CW), P123-156.25M - 3rd overtone quartz based - 156.25 MHz SiLabs, Si590AB-BDG - 3rd overtone quartz based - 156.25 MHz 4. 50 mV pk-pk Sinusoidal voltage. Devices used in this test: SiTime, SiT8208AI-33-33E-25.000000, MEMS based - 25 MHz NDK, NZ2523SB-25.6M - quartz based - 25.6 MHz Kyocera, KC2016B25M0C1GE00 - quartz based - 25 MHz Epson, SG-310SCF-25M0-MB3 - quartz based - 25 MHz 5. Devices used in this test: same as EMS test stated in Note 3. 6. Test conditions for shock test: • MIL-STD-883F Method 2002 • Condition A: half sine wave shock pulse, 500-g, 1ms • Continuous frequency measurement in 100 μs gate time for 10 seconds Devices used in this test: same as EMS test stated in Note 3 7. Additional data, including setup and detailed results, is available upon request to qualified customers. Please contact productsupport@sitime.com. Silicon MEMS Outperforms Quartz Rev. 1.2 www.sitime.com Document Feedback Form The Smart Timing Choice The Smart Timing Choice SiTime values your input in improving our documentation. Click here for our online feedback form or fill out and email the form below to productsupport@sitime.com. 1. Does the Electrical Characteristics table provide complete information? Yes No If No, what parameters are missing? _________________________________________________________________________________________________ 2. Is the organization of this document easy to follow? Yes No If “No,” please suggest improvements that we can make: _________________________________________________________________________________________________ 3. Is there any application specific information that you would like to see in this document? (Check all that apply) EMI Termination recommendations Shock and vibration performance Other If “Other,” please specify: _________________________________________________________________________________________________ 4. Are there any errors in this document? Yes No If “Yes”, please specify (what and where): _________________________________________________________________________________________________ 5. Do you have additional recommendations for this document? _________________________________________________________________________________________________ Name ________________________________________________________________________________ Title ________________________________________________________________________________ Company _________________________________________________________________________________________ Address _________________________________________________________________________________________ City / State or Province / Postal Code / Country ___________________________________________________________ Telephone __________________________________ Application ________________________________________________________________________________________ Would you like a reply? Yes No Thank you for your feedback. Please click the email icon in your Adobe Reader tool bar and send to productsupport@sitime.com. Or you may use our online feedback form. Feedback Form Rev. 1.0 www.sitime.com
SIT5022AI-1BE-33S-290.000000Y 价格&库存
很抱歉,暂时无法提供与“SIT5022AI-1BE-33S-290.000000Y”相匹配的价格&库存,您可以联系我们找货
