1N4001 THRU 1N4007
Technical Data
Data Sheet N0543, Rev. -
1N4001 THRU 1N4007
1.0 SILICON RECTIFIER
Features:
Green Products
Diffused Junction
Low Forward Voltage Drop
High Current Capability
High Reliability
High Surge Current Capability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical data:
Case: Molded Plastic
Terminals: Plated Leads Solderable Per MIL-STD-202, Method 208
Polarity: Cathode Band
Weight: 0.35 grams(Approx)
Mounting Position: Any
Mechanical Dimensions: In mm/Inches
DO-41
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
1N4001 THRU 1N4007
Green Products
Technical Data
Marking Diagram:
Where XXXXX is YYWWL
1N4001
SSG
YY
WW
L
= Part Name
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL: 94V-0
Ordering Information
Device
1N4001-1N4007
Package
DO-41
(Pb-Free)
Shipping
5000pcs / tape
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
1N4001 THRU 1N4007
Green Products
Technical Data
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Type Number
Symbol
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
RMS Reverse Voltage
VRMS
1N
4001
1N
4002
1N
4003
1N
4004
1N
4005
1N
1N
4006 4007
50
5
100
1
200
2
400
4
600
6
800
8
1000
1V
35
3
70
7
140
1
280
2
420
4
560
5
700
1
V
Unit
Average forward rectified output current
@TA = 75°C
IO
1.0
A
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
30
A
Forward Voltage
@IF =1.0A
VFM
1.0
V
Peak Reverse Current
At Rated DC Blocking Voltage
@TA = 25°C
@TA = 100°C
IRM
5.0
50
µA
Typical Junction Capacitance (Note 2)
CJ
15
pF
Typical Thermal Resistance Junction to
Ambient (Note 1)
RθJA
50
°C/W
Operating Junction Temperature Range
TJ
-65 to +125
°C
TSTG
-65 to +150
°C
Storage Temperature Range
Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm form the case.
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
1N4001 THRU 1N4007
Technical Data
Green Products
1N4001 THRU 1N4007
Technical Data
Green Products
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“1N4005TA”相匹配的价格&库存,您可以联系我们找货
