UF4003TA
UF4003TA
    SMCDIODESOLUTIONS(桑德斯)
    DO-41(DO-204AL)
    Diode Standard 200V 1A Through Hole DO-41
UF4003TA 数据手册
UF4001 THRU UF4007 Technical Data Data Sheet N0115, Rev. B Green Products UF4001 THRU UF4007 ULTRA FAST RECITIFIERS Applications:    Switching Power Supply Power Switching Circuits General Purpose Features:         The plastic package carries Underwriters Laboratory Flammability Classification 94V-O Ultra-fast switching for high efficiency Low reverse leakage High forward surge current capability High temperature soldering guaranteed 250℃/10 seconds, 0.375”(9.5mm) lead length This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm / Inches and Marking: 25.4(1.00) MIN (2 PLCS) CATHODE BAND 5.21 (0.205) 4.06 (0.160) CATHODE 1.27(0.050) MAX FLASH(2 PLCS) 0.864 (0.034) DIA 0.71 (0.028) (2 PLCS) ANODE 2.70(0.106) 2.00(0.079) DIA DO-41 MARKING,MOLDING RESIN Marking: UF4001/UF4002/UF4003/UF4004/UF4005/ UF4006/UF4007  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  UF4001 THRU UF4007 Green Products Technical Data Data Sheet N0115, Rev. B Marking Diagram: UF4001 = Part Name Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device UF4001 THRU UF4007 Package Shipping DO-41 (Pb-Free) 5000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  UF4001 THRU UF4007 Green Products Technical Data Data Sheet N0115, Rev. B Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. SYMBOLS Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375"( 9.5mm ) lead length at TA=55℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load ( JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ VRRM VRMS VDC Power dissipation value Maximum reverse recovery time (Note 1) Typical junctin capacitance ( Note 2) Typical thermal resistance ( Note 3) Approximate Weight Operating junction and storage temperature range PDV trr CJ RCJA wt UF 4001 50 35 50 UF 4002 100 70 100 UF 4003 200 140 200 UF 4004 400 280 400 UF 4005 600 420 600 UF 4006 800 560 800 UF 4007 1000 700 1000 UNIS V V V I(AV) 1.0 A IFSM 30.0 A VF 1.0 1.70 5.0 50.0 IR TJ,TSTG V μA - 1.5 15.0 50.0 0.35 W ns pF ℃/W g -65 to +150 ℃ 50 75 Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A. Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm) lead length, P.C.B mounted.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  UF4001 THRU UF4007 Technical Data Data Sheet N0115, Rev. B  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products UF4001 THRU UF4007 Technical Data Data Sheet N0115, Rev. B Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
UF4003TA 价格&库存
很抱歉,暂时无法提供与“UF4003TA”相匹配的价格&库存,您可以联系我们找货
