BAT54WTR
BAT54WTR
    SMCDIODESOLUTIONS(桑德斯)
    SOT-323-3
    DIODESCHOTTKY30V200MASOT323
BAT54WTR 数据手册
BAT54W/AW/CW/SW Technical Data Data Sheet N0027, Rev. B Green Products BAT54W/AW/CW/SW SCHOTTKY BARRIER DIODE Features:   Extremely Fast Switching Speed Low forward voltage Mechanical Data:    Case: SOT-323, Molded plastic body Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: Polarity symbols marked on case Mechanical Dimensions: In Inches / mm SOT-323  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BAT54W/AW/CW/SW Green Products Technical Data Data Sheet N0027, Rev. B Marking Diagram: BAT54W BAT54AW BAT54CW BAT54SW KL5/KL6/KL7/KL8 = Part Name Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device BAT54W/AW/CW/SW Package Shipping SOT-323(Pb-Free) 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BAT54W/AW/CW/SW Green Products Technical Data Data Sheet N0027, Rev. B Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Symbol Limit Unit VRRM VRWM VR 30 V Forward Continuous Current IFM 200 mA Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 600 mA Pd 200 mW RθJA 500 °C/W Junction Temperature Range TJ 125 °C Storage Temperature Range TSTG -55 to +150 °C Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Power Dissipation Typical Thermal Resistance Junction to Ambient Characteristic Symbol Max Unit Test Condition Forward Voltage VF Reverse Leakage Current IR 0.24 0.32 0.40 0.50 1.0 2 IF=0.1mA IF=1mA V IF=10mA IF=30mA IF=100mA μA VR=25V Diode capacitance CT 10 pF VR=1V,f=1.0MHz Reverse recovery time trr 5 ns IF= IR=10mA, Irr=0.1×IR, RL=100Ω  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BAT54W/AW/CW/SW Technical Data Data Sheet N0027, Rev. B Typical Characteristics  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Green Products BAT54W/AW/CW/SW Technical Data Data Sheet N0027, Rev. B Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
BAT54WTR 价格&库存
很抱歉,暂时无法提供与“BAT54WTR”相匹配的价格&库存,您可以联系我们找货
