Multilayer Chip LC Band Pass Filter – SLFB Series
Operating Temp. : -40℃ ~+ 85℃/ -55℃ ~+ 125℃
FEATURES
Small and low profile enables high density mounting
Low insertion loss and high attenuation
Excellent solderability
APPLICATIONS
Mobile communication equipment for GSM, LTE,5G systems, etc.
Bluetooth, WLAN, WIFI, GPS, etc.
Base station application
PRODUCT IDENTIFICATION
SLFB
18
-2R450G
-02
T
F
①
②
③
④
⑤
⑥
①
②
Type
SLFB
Bandpass LC Filter
③
External Dimensions (L×W) (mm)
15 [0402]
1.0×0.5
18 [0603]
1.6×0.8
21 [0805]
22 [1008]
32 [1210]
2.0×1.2
2.5×2.0
3.2×2.5
⑤
④
Series Code
T
02, A1, etc.
Packing
Tape & Reel
Center Frequency
Example
Nominal Value
1R917G
1910MHz
2R450G
2450MHz
5R550G
5550MHz
⑥
Hazardous Substance Free
Products
F
SHAPE AND DIMENSIONS
Type: SLFB15-2R450G-02TF
Dimensions and Land Patterns
Type: SLFB18 Series
Sunlord
Specifications subject to change without notice. Please check our website for latest information.
Revised 2020/06/26
Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
Type: SLFB18-2R450G-10TF
Type: SLFB21 Series
Type: SLFB21-2R450G-02TF
Type: SLFB21-2R450G-13TF
Type:
SLFB21-2R450G-06/09/10TF
Sunlord
Revised 2020/06/26
Type: SLFB22 Series
Land
Solder resist
No Pattern solder resist
Unit:mm
Type: SLFB32 Series
SPECIFICATIONS
SLFB15 TYPE
Part Number
Center
Frequency
Pass Band
Max. IL in PB
(at 25°C)
Units
Symbol
MHz
f0
MHz
PB
dB
IL
SLFB15-2R450G-02TF
2450.0
f0±50.0
1.4
Attenuation
Thickness
dB
25dB Min. at 880~960MHz
8.0dB Min. at 1710~1970MHz
23dB Min. at 4800~5000MHz
32dB Min. at 7200~7500MHz
mm
T
0.38±0.05
SLFB18 TYPE
Part Number
Center
Frequency
Pass Band
Max. IL in PB
(at 25°C)
Attenuation
Thickness
Units
MHz
MHz
dB
dB
mm
Symbol
f0
PB
IL
T
SLFB18-1R910G-01TF
1910.0
1805~2025
1.7
SLFB18-1R950G-01TF
1950.0
1880~2025
1.9
SLFB18-2R450G-02TF
2450.0
f0±50.0
2.2
Sunlord
30dB at 700~950MHz
15dB at 950~1050MHz
30dB at 2400~2500MHz
35dB at 2700~5400MHz
30dB at 5500~12500MHz
20dB at 1545~1610MHz
25dB at 2400~2500MHz
25dB. at 5150~5850MHz
24dB Min. at 880~960MHz
20dB Min. at 1710~1990MHz
15.5dB Min. at 4800~5000MHz
19.5dB Min. at 7200~7500MHz
0.75
0.75
0.60±0.10
Revised 2020/06/26
SPECIFICATIONS
SLFB18 TYPE
Part Number
Center
Frequency
Pass Band
Max. IL in PB
(at 25°C)
Units
Symbol
MHz
f0
MHz
PB
dB
IL
SLFB18-2R450G-07TF
2450.0
f0±50.0
1.8
SLFB18-2R450G-08TF
2450.0
f0±50.0
1.8
SLFB18-2R450G-10TF
2450.0
f0±50.0
3.0
SLFB18-2R450G-31TF
2450.0
f0±50.0
0.95
Attenuation
Thickness
dB
30dB Min. at 800~960MHz
25dB Min. at 1710~1990MHz
30dB Min. at 4800~5000MHz
30dB Min. at 7200~7500MHz
mm
T
27dB Min. at 800~900MHz
34dB Min. at 4800~5000MHz
34dB Min. at 7200~7500MHz
35dB Min. at 880~960MHz
30dB Min. at 1505~1610MHz
15dB Min. at 2110~2170MHz
25dB Min. at 4800~5000MHz
20dB Min. at 7200~7500MHz
20dB at 500~960 MHz
0.60±0.10
23dB at 3200~3312 MHz
30dB at 4800~5000 MHz
32dB at 7200~7500 MHz
SLFB18-5R500G-01TF
5512.5
f0±362.5
1.5
SLFB18-5R500G-31TF
5512.5
f0±362.5
1.5
30dB Min. at 800~3800MHz
15dB Min. at 10000~12000MHz
33dB at 100~2170 MHz
29dB at 2170~2500 MHz
15dB at 6900~7000 MHz
16dB at 7000~7200 MHz
16dB at 7200~7800 MHz
32dB at 9800~12000 MHz
0.65±0.10
SLFB21 TYPE
Part Number
Center
Frequency
Pass Band
Max. IL in PB
(at 25°C)
Units
Symbol
MHz
f0
MHz
PB
dB
IL
SLFB21-2R450G-02TF
2450.0
f0±50.0
1.5
SLFB21-2R450G-03TF
2450.0
f0±50.0
1.7
SLFB21-2R450G-06TF
2450.0
f0±50.0
1.8
Sunlord
Attenuation
Thickness
dB
30dB Min. at 900MHz
20dB Min. at 1850MHz
30dB Min. at 4800MHz
30dB Min. at 824~915MHz
28dB Min. at 1545~1605MHz
35dB Min. at 1710~1990MHz
30dB Min. at 2170MHz
25dB Min. at 7200~7500MHz
mm
T
0.95±0.10
0.80±0.10
Revised 2020/06/26
SPECIFICATIONS
SLFB21 TYPE
Part Number
Center
Frequency
Pass Band
Max. IL in PB
(at 25°C)
Units
Symbol
MHz
f0
MHz
PB
dB
IL
SLFB21-2R450G-09TF
2450.0
f0±50.0
1.5
SLFB21-2R450G-10TF
2450.0
f0±50.0
2.5
SLFB21-2R450G-13TF
2450.0
f0±50.0
1.0
SLFB21-5R500G-01TF
5410.0
f0±510.0
1.5
Attenuation
Thickness
dB
30dB Min. at 746~960MHz
30dB Min. at 1540~1605MHz
30dB Min. at 1710~1990MHz
30dB Min. at 2110~2170MHz
15dB Min. at 3300~3800MHz
35dB Min. at 4800~5000MHz
21dB Min. at 902~928 MHz
26dB Min. at 4800~5000 MHz
34dB Min. at 7200~7500 MHz
29dB Min. at 9600~10000 MHz
30dB Min. at 3500MHz
25dB Min. at 9800~11840MHz
5dB Min. at 14700~17760MHz
mm
T
0.80±0.10
0.95±0.10
SLFB22 TYPE
Part Number
Center
Frequency
Pass Band
Max. IL in PB
(at 25°C)
Units
Symbol
MHz
f0
MHz
PB
dB
IL
SLFB22-2R450G-A1TF
2450.0
f0±50.0
1.7
SLFB22-1R917G-A4TF
1917.0
f0±50.0
1.9
Attenuation
Thickness
dB
25dB Min. at 1750MHz
6dB Min. at 2100MHz
22dB Min. at 4800~5000MHz
50dB Min. at 956~961MHz
24dB Min. at 2868~2883MHz
29dB Min. at 3824~3844MHz
33dB Min. at 4780~4805MHz
32dB Min. at 5736~5766MHz
mm
T
0.90±0.10
SLFB32 TYPE
Center
Pass
Max. IL in PB
Frequency
Band
(at 25°C)
Units
Symbol
MHz
f0
MHz
PB
dB
IL
SLFB32-2R450G-K5TF
2450.0
f0±50.0
1.8
Part Number
Sunlord
Attenuation
Thickness
dB
48dB Min. at 902~928MHz
50dB Min. at 1500~1550MHz
12dB Min. at 2150~2200MHz
mm
T
1.50±0.10
Revised 2020/06/26
很抱歉,暂时无法提供与“SLFB18-2R450G-02TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32195
- 100+0.26579
- 300+0.23771
- 1000+0.21665
