Grove - W600
Grove - W600
    SEEED(矽递科技)
    模块
    www.seeedstudio.com/Grove-W600-p-4019.html
Grove - W600 数据手册
        Grove ‐ W600 SKU 113020031    The Grove ‐ W600 is a cost‐effective 2.4GHz WiFi module for Arduino, build around the W600 Module, support 802.11b/g/n. The Seeed W600 Module features ARM Cortex‐M3 with 1MB on‐chip flash and freeRTOS kernel. The Grove ‐ W600 has one Grove connector, two buttons(reset & config) and three LED indicators(power/reset/wifi). As you can see, there is also an onboard PCB antenna in the W600 Module. This module support AT command, so just plug the Grove ‐ W600 into your Arduino compatible systems, it can enable the WiFi ability easily via the software UART. We also take the pins of the W600 chip out and put them on the back of the board, in case you need to use the I2S/I2C/SPI/GPIO pins(our library do not support this part). The most exciting part is that with the help of Android / IOS app it supports One Shot Activity function, which means you can connect and disconnect the WiFi network by pressing a single button. What a convenience! We really think the W600 is a cost‐effect and powerful WiFi chip, and we seriously consider it as an ESP8266 competitor. So we made it Grove and we hope it may impress you. Tip For IOS user, you can seach the app name in the apple app store : one shot config Features           Support IEEE802.11 b/g/n Support 2.4~2.4835 GHz Support Wi‐Fi WMM/WMM‐PS/WPA/WPA2/WPS Support multiple network protocols: TCP/UDP/ICMP/DHCP/DNS/HTTP Integrated GPIO device controller Support for user‐programmable GPIO control Supports AT+ instruction protocol based on ASCII encoding (UART interface) Applications wireless audio and video smart home smart toys Pinout ECCN/HTS ECCN  5A002.a.1  HSCODE  8517709000  UPC                   https://www.seeedstudio.com/Grove‐W600‐p‐4019.html/5‐15‐19
Grove - W600 价格&库存
很抱歉,暂时无法提供与“Grove - W600”相匹配的价格&库存,您可以联系我们找货
