102990883
102990883
    SEEED(矽递科技)
    Respeaker Core AI智能语音识别开发板、IOT物联网方案、RK3229芯片
102990883 数据手册
ReSpeaker Core V2.0 ReSpeaker Core V2 – high performance voice interactive solution Product Overview Key Benefits Seeed’s ReSpeaker Core v2 is designed for voice interactive applications. It based on quad-core ARM Cortex-A7, up to 1.5Ghz, and 1GB RAM on-board. Besides, it features six microphone array with necessary speech algorithm, like DoA(Direction of arrival), BF(Beam-Forming), AEC(Acoustic echo cancellation) and etc. • Debian-based Linux system • SDK for speech algorithm with Full documents • C++ SDK and Python wrapper • Speech algorithms and features • Keyword wake-up • BF(Beam-Forming) ReSpeaker Core v2 runs GNU/Linux operation system. It benefits from powerful and active community, we can use lot of existing software/tools for development, testing and deploy, so that rapid product development become available. • DoA(Direction of arrival) • NS(Noise suppression) • AEC(Acoustic echo cancellation) and AGC(Automatic gain control) • All-in-one solution with high performance SoC • 8 channel ADCs for 6 microphone array and 2 loopback(hardware loopback) ReSpeaker Core v2 is not only designed for makers/enthusiast, but also a turnkey solution for business company. The hardware consists of two parts, one is the minimized SoC module which is small and easy to manufacturing and ready for final product. Another is a bottom board can be full customizable. Copyright © 2008-2017 Seeed Development Limited All rights reserved 1 ReSpeaker Core V2.0 Hardware Features Applications • • Smart speaker • Intelligent voice assistant systems • Voice recorders • Voice conferencing system • Meeting communicating equipment • Voice interacting robot • Car voice assistant • Other scenarios need voice command ARM Quad-core Cortex-A7 up to 1.5GHz • ARM Mail-400MP2 GPU • 1GB RAM DDR3 • Audio and Video • • • • 8 channel ADCs for 6 microphone array and 2 loopback • 3.5mm audio headset connector • JST 2.0 output connector for 8 Ohm Speaker • HDMI 2.0* Connectivity: • WiFi b/g/n • Bluetooth 4.0 and Low Energy dual-mode • Ethernet Storage • 4GB eMMC on-board • SD card slot Peripheral • 1 x USB Host/OTG • 1 x USB power • 1 x Grove socket, support I2C and digital port • 6 x GPIO • 1 x UART • 12 x programmable LEDs Copyright © 2008-2017 Seeed Development Limited All rights reserved 2 ReSpeaker Core V2.0 Hardware Overview Copyright © 2008-2017 Seeed Development Limited All rights reserved 3
102990883
物料型号:ReSpeaker Core V2.0
器件简介:ReSpeaker Core V2.0是为语音交互应用设计的高性能解决方案。它基于四核ARM Cortex-A7,最高1.5GHz,板载1GB RAM。此外,它具有六个麦克风阵列和必要的语音算法,如DoA(到达方向)、BF(波束形成)、AEC(声学回声消除)等。
引脚分配:文档中未明确列出引脚分配,但提到了硬件接口,包括3.5mm音频耳机插孔、JST 2.0输出连接器(8欧姆扬声器)、HDMI 2.0、WiFi b/g/n、蓝牙4.0及低功耗双模式、以太网、4GB板载eMMC、SD卡槽、1个USB主机/OTG、1个USB电源、1个Grove插座(支持I2C和数字端口)、6个GPIO、1个UART、12个可编程LED。
参数特性:四核ARM Cortex-A7,最高1.5GHz,ARM Mail-400MP2 GPU,1GB DDR3 RAM,8通道ADC用于6个麦克风阵列和2个硬件回环,支持WiFi b/g/n、蓝牙4.0及低功耗双模式、以太网。
功能详解:ReSpeaker Core V2.0运行GNU/Linux操作系统,支持Debian-based Linux系统,提供语音算法SDK和完整文档,C++ SDK和Python封装器。语音算法和特性包括关键词唤醒、波束形成、到达方向、噪声抑制、声学回声消除和自动增益控制。
应用信息:适用于智能扬声器、智能语音助手系统、语音记录器、语音会议系统、语音交互机器人、车载语音助手以及其他需要语音命令的场景。
封装信息:文档中未提供封装信息,但提供了硬件概览图,显示了产品的物理布局和接口位置。
102990883 价格&库存
很抱歉,暂时无法提供与“102990883”相匹配的价格&库存,您可以联系我们找货
