SBR230LSTR
SBR230LSTR
    SMCDIODESOLUTIONS(桑德斯)
    SOD123
    DIODESCHOTTKY30V2ASOD123
SBR230LSTR 数据手册
SANGDEST MICROELECTRONICS SBR230LS Green Products Technical Data Data Sheet N0893, Rev. C SBR230LS SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • 125 °C TJ operation Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions (In mm/Inches) SOD-123 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBR230LS Green Products Technical Data Data Sheet N0893, Rev. C Marking Diagram: Where X is Date Code L3N = Part Name Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device SBR230LS Package SOD-123 (Pb-Free) Shipping 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBR230LS Green Products Technical Data Data Sheet N0893, Rev. C Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Peak Reverse Voltage Average Rectified Output Current @IF = 1A,TA = 25°C @IF = 2A,TA = 25°C @IF = 1A,TA = 100°C @IF = 2A,TA = 100°C Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 100°C Peak Repetitive Forward Current (at rated VR ,square wave,100kHz,TL=95°C) Non−Repetitive Peak Surge Current (Surge Applied at Rated Load Conditions Halfwave, Single Phase, 60 Hz) Maximum Junction Capacitance (Note 1) Symbol Value Unit VR 30 V IF(AV) 2 A Forward Voltage IRM 0.60 0.75 0.52 0.67 1.0 25 mA IFRM 4.0 A IFSM 25 A Cj 150 pF TJ -55 to +125 °C Storage Temperature Range TSTG -55 to +150 °C Voltage Rate of Change (rated VR, TJ=25°C) d v/dt 10000 V/µs wt 0.028 g Operating Junction Temperature Range Approximate Weight VFM Case Style V SOD-123 Note 1. Measured at 1MHz and applied reverse voltage of 5.0V D.C. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS SBR230LS Green Products Technical Data Data Sheet N0893, Rev. C 100 Instantaneous Reverse Current (mA) TJ=25℃ 100 10 0 5 10 15 20 25 30 35 40 10 1 0.1 TJ=125℃ TJ=100℃ TJ=75℃ 0.01 TJ=25℃ 0.001 10 20 30 40 50 60 70 80 90 Percent of Rated Peak Reverse Voltage (%) Reverse Voltage (V) Fig.2-Typical Reverse Characteristics Fig.1-Typical Junction Capacitance 10 Instantaneous Forward Current (A) Junction Capacitance (PF) 1000 TJ=125℃ TJ=100℃ 1 TJ=25℃ TJ=75℃ 0.1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 Forward Voltage Drop (V) Fig.3-Typical Forward Voltage Drop Characteristics • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • 100 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0893, Rev. C SBR230LS Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SBR230LSTR 价格&库存
很抱歉,暂时无法提供与“SBR230LSTR”相匹配的价格&库存,您可以联系我们找货
