102010021
102010021
    SEEED(矽递科技)
    内置Dragino WiFi物联网模块HE和兼容Arduino Yun的ATmega32u4支持2.4Ghz WiFi、802.11 b/g/n内置以太网端口和运行OpenWrt系统的USB 2.0
102010021 数据手册
Seeeduino Cloud - Arduino Yun compatible openWRT controller SKU 102010021 Seeeduino Cloud is a microcontroller board based on Dragino WiFi IoT module HE and ATmega32u4. HE is a high performance, low cost 150M, 2.4G WiFi module which means “core” in Chinese and with an Open Source OpenWrt system inside. Seeeduino Cloud is also an Arduino compatible board, 100% compatible with Grove, shield and IDEs(Arduino IDE 1.5.3 and later). Except for the normal interface of Arduino, Seeeduino Cloud has built-in Ethernet and WiFi support, a USB-A port which makes it very suitable for those prototype design that needs network connection and mass storage. It is also a good idea to make Seeeduino Cloud to an IoT gateway. Features • • • • • • • • • Compatible with Arduino Yun Based on Dragino WiFi IoT module HE Open Source OpenWrt system inside Support 2.4Ghz WiFi, 802.11 b/g/n Support Ethernet Support USB 2.0 Size: 75.10mm x 53.39mm x 11.50mm / 2.95"x 2.10 x 0.45" Working temperature: -20~60°C Surface color: Red Technical Details Dimensions 116mm x 76mm x 26mm Weight G.W 54g Battery Exclude HE Module CPU ATHEROS AR9331 Clock Speed 400MHz RAM 64MB Flash 16MB OS Open Source OpenWrt Interfaces 2 x RJ45, 1 x USB Host, 1 x UART, 14 multiplex GPIOs Power 3.3V power input WiFi Support 150M 2.4Ghz WiFi, 802.11 b/g/n AVR Arduino Microcontroller Microcontroller ATmega32u4 Flash Memory 32KB SRAM 2.5kB EEPROM 1kB Clock Speed 16MHz Digital I/O Pins 20 PWM Channels 7 Analog Input Channels 12 Part List Seeeduino Cloud 1 Antenna 1 Documents • • • Schematic Seeeduino Cloud Eagle file Seeeduino Cloud Firmware https://www.seeedstudio.com/Seeeduino-Cloud-Arduino-Yun-compatible-openWRT-controller-p-2123.html 1-10-18
102010021 价格&库存
很抱歉,暂时无法提供与“102010021”相匹配的价格&库存,您可以联系我们找货
