102010168
102010168
    SEEED(矽递科技)
    ATmega328P-MU(32KB Flash 2KB RAM 1KB EEPROM) 5V 40mA 16MHz Grove车载接口
102010168 数据手册
      Seeeduino Lotus V1.1 - ATMega328 Board with Grove Interface SKU 102010168 Description If you have experience using Seeed’s Seeeduino board plus a base shield, you would know how easy it is because there is no jumper wire and soldering. In order to make it more convenient, we created the Seeeduino Lotus V1.0, a 2 in 1 solution of Seeeduino board and base shield. It turns out Seeeduino Lotus V1.0 is very welcome because it combines the advantages of Seeeduino board and base shield and also very cost effective. This time we’d like to introduce the new version, Seeeduino Lotus V1.1 to you. Seeeduino Lotus V1.1 is a small update of the V1.0 version, we only changed the USB bus converter chip CH340 to CP2102N in order to make this board more compatible with Mac OS. Despite this change, the board is still based on ATMEGA328P-MU, a high performance, low power 8-Bit AVR Microcontroller. It is still Arduino compatible and has rich peripherals including digital interface, analog interface, I2C, SPI, UART. The update of hardware might be small, while the reduction of price is huge. Even though the hardware is almost the same to the V1.0 version, the price of Seeeduino Lotus V1.1 is almost half of the V1.0. We have made a lot of cost down work to make this progress. The result is that you will have better experience and save more money. No matter you are using Windows or Mac OS, if want to build something based on Arduino quickly and conveniently, this board is the best for you. Features  Combination of Seeeduino and base shield.  Arduino UNO Compatible  On-board Grove connector  Mac OS compatible.  Cost effective Documents Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum. Technical Details   Weight G.W 21g Battery Exclude Microcontroller ATmega328P-MU Operating Voltage 5V DC Current per I/O Pin 40 mA Flash Memory 32 KB (ATmega328P-MU) RAM 2 KB (ATmega328P-MU) EEPROM 1 KB (ATmega328P-MU) Clock Speed 16 MHz Digital Interface D2,D3,D4,D5,D6,D7 Analog Interface A0,A2,A4,A6 Other I2C *2, SPI, UART Part List Seeeduino Lotus V1.1 1                     https://www.seeedstudio.com/Seeeduino‐Lotus‐V1.1‐ATMega328‐Board‐with‐Grove‐Interface‐p‐2917.html 8‐30‐17
102010168 价格&库存
很抱歉,暂时无法提供与“102010168”相匹配的价格&库存,您可以联系我们找货
  • 1+120.035371+15.59891
库存:72
