Seeeduino Nano
SKU 102010268
The Seeeduino Nano is a compact board similar to the Seeeduino V4.2/Arduino UNO, and it
is fully compatible with Arduino Nano on pinout and sizes.
Seeeduino Nano VS. Seeeduino V4.2
The same as Seeedunio V4.2, Seeeduino Nano is built around Atmega328P ‐‐ 8‐bit AVR
microcontroller. So you can use the same program code on both boards. However, the
dimensions of the two are significantly different. Less than a quarter of the size, but with
almost the same features, Seeeduino Nano will save more space for your project, more
suitable for space‐constrained scenes.
Seeeduino Nano VS. Arduino Nano
First, the most intuitive difference is the price. The Seeeduino Nano offers the same
features and high‐quality experience as the Arduino Nano in less than half the price. On the
other hand, the Seeeduino Nano has also made the following improvements compared to
the Arduino Nano. 1‐Change the Mini‐USB into Type‐C, which is symmetrical and
reversible. 2‐ Add one Grove I2C connector, with the help Grove system, you can play with
hundreds of sensors and actuators simply by plugging. We've listed the main differences
between these products as follows:
Model
Processor
Input
IO
Analog Digital
USB
Voltage Voltage In/Out IO/PWM
Grove
Connector
Seeeduino ATmega328P 5V / 7V4.2
12V
3.3V/5V 6/0
14/6
micro- 2xI2C+1xUART
USB
Seeeduino ATmega328P 5V / 7Nano
12V
5V
8/0
14/6
Type
C
Arduino
Nano
5V
8/0
14/6
MiniUSB
ATmega328P 5V / 712V
1xI2C
Seeeduino Nano Add‐on
One more thing, we know that only one on‐board Grove connector may not be enough, so
we made this Grove shield for Arduino Nano, which has 3 Grove digital connectors, 3 Grove
analog connectors, 1 Grove I2C connector, and 1 Grove UART connector. For most projects,
these Grove interfaces are more than enough, but if you still need to connect more grove
modules, you can also use our Grove ‐ I2C Hub.
Note
This product does not contain this shield, if you need it, please click on Grove shield for Arduino
Nano to view.
Features
43mm*18mm Tiny board
16M ATmega328P
Fully compatible with Arduino Nano
USB Type C for Programming and power
On‐board Grove I2C connector
Breadboard‐friendly
Hardware Overview
ECCN/HTS
ECCN
EAR99
HSCODE
8517709000
USHSCODE
85177000
UPC
https://www.seeedstudio.com/Seeeduino‐Nano‐p‐4111.html/7‐17‐19
很抱歉,暂时无法提供与“102010268”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+67.277251+8.69170
