Seeeduino XIAO ‐ Arduino Microcontroller ‐ SAMD21 Cortex
M0+
SKU 102010328
Seeeduino XIAO is the smallest Arduino compatible board in Seeeduino Family. It is an Arduino
microcontroller that is embedded with the SAMD21 microchip. The interfaces of Seeeduino XIAO is rich
enough in such a tiny Dev. Board as well.
Key Features
Powerful CPU: ARM® Cortex®-M0+ 32bit 48MHz microcontroller(SAMD21G18) with 256KB
Flash,32KB SRAM
Flexible compatibility: Compatible with Arduino IDE
Easy project operation: Breadboard-friendly
Small size: As small as a thumb(23.5x17.5mm) for wearable devices and small projects.
Multiple development interfaces: 11 digital/analog pins, 10 PWM Pins, 1 DAC output, 1 SWD
Bonding pad interface, 1 I2C interface, 1 UART interface, 1 SPI interface.
Description
Take a look at Seeeduino XIAO. What a small size and cute looking! It is the smallest
member of the Seeeduino family. Seeeduino XIAO still carries the powerful CPU-ARM®
Cortex®-M0+(SAMD21G18) which is a low-power Arduino microcontroller. On the other
hand, this little board has good performance in processing but needs less power. As a
matter of fact, it is designed in a tiny size and can be used for Arduino wearable devices and
small projects.
Apart from the strong CPU, Seeeduino XIAO is excellent in many other functions. It has 14
GPIO PINs, which can be used for 11 analog PINs, 11 digital PINs, 1 I2C interface, 1 UART
interface, and 1 SPI interface. Some PINs have various functions, A1/D1 to A10/D10 Pins
have PWM functions and Pin A0/D0 has a function of DAC which means you can get
true analog signals not PWM signals when you define it as an analog pin, that’s why 14
GPIO PINs can realize more I/O PINs and interfaces. Moreover, Seeeduino XIAO supports
the USB Type-C interface which can supply power and download code. There are power
pads at the back of the XIAO which support battery and make it designed for wearable
devices to become realistic. Except for the power LED, we add a user LED on board for your
better coding experience. Usually a Dev. Board as small as this size will use the chip’s inner
crystal oscillator for time fixing, in order to make the clock more accurate, Seeeduino XIAO
layouts an extra 32.768KHz to make the clock more stable.
Seeeduino XIAO is perfectly compatible with Arduino IDE, you can easily develop some
small projects with the help of the large and comprehensive Arduino library. So get one and
you will soon love it!
Attention
All the I/O pins are 3.3V, please do not input more than 3.3V, otherwise, the CPU may be damaged.
This is the Wiki of the Seeeduino XIAO, you can view the basic settings of running the
board.
Specification
CPU: ARM Cortex-M0+ CPU(SAMD21G18) running at up to 48MHz
Storage: 256KB Flash,32KB SRAM
I/O PINs: 14 GPIO PINs,11 analog PINs, 11 digital PINs, 1 DAC output Pin
Interface: 1 I2C interface,1 UART interface, 1 SPI interface
Power supply and downloading interface: USB Type-C interface
LEDs: 1 user LED, 1 power LED, two LEDs for serial port downloading
Reset button: two reset button short connect to reset
Power Pads: For the battery power supply
Software compatibility: Compatible with Arduino IDE
Projection cover for protecting the circuit
Dimensions: 23.5x17.5x3.5 mm
Typical Application
Wearable devices
Rapid prototyping (directly attached to the expanded PCB as a minimal system)
Perfect for all the projects need mini arduino
DIY keyboard
USB development (USB to multi-channel TTL/USB host mode, etc.)
A scenario where you need to read multiple mock values The DAC output
Demo
Use Seeeduino XIAO, Grove - Touch Sensor, Grove - RGB LED Ring to renew your glove to a party
mode, which can change the lightning modes of the glove by touching.
Hardware Pinout
Part List
1 x Seeeduino XIAO - Arduino Microcontroller - SAMD21 Cortex M0+
2 x 7pins header
4 x pasters
Note
We are going to bring new add-ons to extend functionalities based on the community needs, so we are
looking forward to any suggestions you guys have! Let us know in the forum, we will carefully listen to
and take action!
ECCN/HTS
HSCODE
UPC
8543709990
https://www.seeedstudio.com/Seeeduino‐XIAO‐Arduino‐Microcontroller‐SAMD21‐Cortex‐M0+‐p‐4426.html/1‐14‐20
很抱歉,暂时无法提供与“102010328”相匹配的价格&库存,您可以联系我们找货
