Spartan Edge Accelerator Board
The Spartan Edge Accelerator Board (SEA Board in short) is a lightweight FPGA
development board, it is based on the Xilinx Spartan-7 chip and follows the Arduino
shield form factor. Hence, you can use it as an Arduino shield to driver an LCD and a
camera or as a stand-alone FPGA development board. Besides, with the help of onboard ESP32 chip, the SEA board also enables your Arduino with WiFi and Bluetooth
function.
Spartan-7 is the newest and most cost-effective FPGA chip among Xilinx’s FPGA
family, offers the best in class performance per watt.
On top of that, we provide the full FPGA APIs for Arduino, which means Arduino users
are able to use the FPGA function without knowing anything about FPGA. This board
will broaden Arduino’s capability in many ways like simple image processing and
computer vision application, signal encryption and decryption, and signal sampling and
processing.
Features
Full FPGA APIs for Arduino
Stand alone mode/Arduino Shield mode
On-board WiFi and bluetooth 4.1 with BLE
On-board 8 bit ADC
On-board 6 axis Accelerometer and Gyroscope
On-board Grove Connector(I2C/D2)
Specification
Parameter
Value
FPGA
FPGA Chip
Spartan-7 XC7S15
Logic Cells
12,800
Slics
2000
CLB Flip-Flops
16,000
Max. Distributed RAM (Kb)
150
Block RAM/FIFO w / ECC (36 kb each) 10
Total Block RAM (Kb)
360
Clock Mgmt Tiles (1 MMCM + 1 PLL)
2
DSP Slices
Wireless
Wireless Chip
Espressif ESP32-D0WDQ6
WiFi
802.11 b/g/n 2.4GHz
Bluetooth
Bluetooth 4.1 with BLE
Peripheral
Video
Mini HDMI x1
Parameter
Value
Camera
CSI/MIPI interface x1 (compatible with Raspberry Pi Camera V1 - OV5640)
SD card
Micro SD/TF card slot x1
FPGA GPIO
10 pins header (IO9~IO0)
Arduino GPIO
32 pins header (Arduino form factor)
Grove
Grove Connector x2 (I2C/D2)
LED
Monochrome LED x2
RGB LED x2
Button
Boot x1
Reset x1
FPGA Reset x1
User x2
Switch
Power Mode Switch x1
5-Channel DIP Switch x1
Power
Operating Voltage
5V
IO Voltage
5V
Power Mode
USB Type C 5V
VIN 8~17V
Arduino Micro USB 5V
Others
ADC
8 bit ADC1173
6-axis LSM6DS3TR
Attention
The SEA shield's IO voltage is 5V, and the FPGA's IO voltage is 3.3V, so we made a
voltage divider to make the IOs voltage compatible. The 3.3V IO voltage of the SAM
D21 series will be less than 3.3V after voltage division, which is not enough to drive the
FPGA's IO. Therefore, at present, the SEA development board only supports the 5V IO
Arduino board, such as Arduino UNO and Seeeduino V4.2.
Hardware Overview
Figure 1. Hardware Overview of SEA Board
Number Detail
1.
FPGA : XC7S15-1FTGB196C
2.
WiFi/Bluetooth : ESP32-D0WDQ6
3.
6-axis Accelerometer and Gyroscope : LSM6DS3TR
4.
DAC : DAC7311IDCKR
5.
Buck-DCDC : TPS62130
6.
USB-to-UART : CP2102-GMR
7.
USB : Type-C
8.
Mini HDMI
9.
CSI Interface :MIPI Camera (compatible with Raspberry Pi Camera V1 - OV5640)
10.
Arduino Header : Compatible with Arduino UNO
11.
DIP Switchs :
K1-K4 user switchs
K5 Switch FPGA Programming Mode
->>>> JTAG : Using Xilinx official Programming Tool
->>>> Slave : Using ESP32 to Program the FPGA
12.
ESP32 Button :Boot and RST
13.
FPGA Button :USER1 USER2 FPGA_RST
14.
User LED: L1/L2/RGB1/RGB2
PWR : Power On
FPGA_DONE : Light up after programming the FPGA with esp32.
15.
Power Switch :
USB->Powered by USB Type C (5V DC)
5V->Powered by VIN Pin (8~17V DC)
16.
Power Mode:
OFF->Isolate the power supply of Arduino and Shield
ON->Connect Power of Arduino and Shield
17.
DAC Output and ADC Input Header
Number Detail
18.
FPGA IO : IO9~IO0
19.
FPGA JTAG Download Interface
20.
Grove Connector : 1x I2C; 1x D2&D3
21.
Ceramic chip antenna
22.
ADC : ADC1173
23.
SPI Flash : W25Q32JVZPIG
24.
Analog Switch :DG2788A
25.
LDO : XC6221B102MR
26.
LDO : RT9013-18GB
27.
LDO : CJ1117-3V3
28.
SD card slot : Micro SD/TF card
Getting Started
Spartan Edge Accelerator Board can work in two modes:
Arduino shield Mode
Stand-alone Mode
In brief, it can work as a Arduino shield to bring the Arduino FPGA and Wireless
features, it also can work as a FPGA development board without an Arduino.
Arduino shield Mode
In this wiki, we use Seeeduino V4.2, you can also use Arduino UNO, they are fully
compatible with each other.
Hardware
Materials required
Seeeduino V4.2 x1
Spartan Edge Accelerator Board x1
Micro SD card or TF card x1
USB Type C data cable x1
Hardware Connection
Step1. Insert the Micro SD card or TF card into the SD card slot
Step2. Plug the SEA Board into the Arduino
Step3. Use one of the following three methods to power the system
Power Port
Input Voltage Power Switch Position
Power Mode Position
Powered by SEA board USB Type C port
5V DC
USB
ON
Powered by Seeeduino V4.2 micro USB port
5V DC
ON
Powered by Seeeduino V4.2 DC port
8~17V DC
5V
ON
Figure 2. SEA board Work with Arduino
Attention
You can also power both the SEA board and the Arduino at the same time, but please
make sure you have set the Power Mode Position to OFF. Only then, the system power
will be isolated, and you can power the Arduino and SEA board separately.
Spartan Edge Accelerator Board ESP32 Boot
Firstly, to work with Arduino, we should load bitstream(FPGA Logic) from SD Card to
the on-board FPGA(xc7s15). The following library will show you how to do this via onboard ESP32.
a library for Spartan Edge Accelerator Board
The purpose of this library is to load bitstream(FPGA Logic) from SDCard to the onboard FPGA(xc7s15) by the on-board ESP32.
The software development environment is Arduino IDE with ESP32 Boards support.
Since Version 1.6.4, Arduino allows installation of third-party platform packages using
Boards Manager. We have packages available for Windows, Mac OS, and Linux (32
and 64 bit).
Install the current upstream Arduino IDE at the 1.8 level or later. The current version is at
the Arduino website.
Start Arduino and open Preferences window.
Enter https://dl.espressif.com/dl/package_esp32_index.json into Additional
Board Manager URLs field. You can add multiple URLs, separating them with commas.
Open Boards Manager from Tools > Board menu and install esp32 platform (and don't
forget to select your ESP32 board from Tools > Board menu after installation).
select tool->board->DOIT ESP32 DEVKIT
Stable release link: https://dl.espressif.com/dl/package_esp32_index.json
Development release
link: https://dl.espressif.com/dl/package_esp32_dev_index.json
If you want more details, you can click the link
LIBRARY USAGE
1.Download the ESP32 Boot Library
Then add this library to your Arduino IDE.
If you don't know how to install the library, please kindly check:
Installing Additional Arduino Libraries
You can find two example folders in this library
Example
Description
01LoadDefaultBitstream This example will load SDCard file /overlay/default.bit to FPGA
02LoadConfigBitstream This example will read a ini format file /board_config.ini in SDCard,then load the
bitstream spcified by the value of key overlay_on_boot to FPGA.
2.Prepare SDCard
2.1 Format the SDCard with FAT16/FAT32 filesystem.
2.2 Create a top level subfolder named overlay in the SDCard.
2.3 Put your bitstream or sample bitstream files (must have a extend name .bit) into the
folder overlay.
Tip
The sample bitsteam : GPIO extension controlled by SPI interface, with support of
ADC/DAC/RGB-LED, see source code.
2.4 If you run example 01LoadDefaultBitstream, rename the bitstream file
in overlay to default.bit.
2.5 If you run example 02LoadConfigBitstream, put board_config.ini into SDCard root
folder.
2.6 Insert the SDCard to the Spartan (Edge Accelerator) Board.
3.Upload example
3.1 Connect the Spartan Board through USB Type-C wire to the PC, and install
USB232 driver (chip CP2102).
3.2 Turn the power switch (near the USB Type-C slot) to USB side to power on the
board.
3.3 Open one of the library examples by Arduino IDE.
3.4 Check Board & Port setting in Arduino IDE as described in last section.
3.5 Press 'BOOT' Button on Sparton Board and last more than 1 seconds to force
ESP32 enter Bootloader mode.
3.6 Press 'Upload' button in Arduino IDE to upload the example ('s compiled binary)
to ESP32.
4.Run example
4.1 Make sure the on-board DIP-switch K5 (last one) on Slave(ON) side, which
enable FPGA programing by other device(MCU).
4.2 Press 'RST' button on Spartan Board to startup the example.
4.3 After the example bootup a few seconds, the FPGA_DONE(red color) LED on
the board will light on.
Spartan Edge Accelerator Board IO Example
Then, the following tutorial will show you how to control the GPIO/ADC/DAC/RGB-LED
resources of Spartan Edge Accelerator Board with Arduino.
Download the IO Example Library:
Add this library to your Arduino IDE. If you don't know how to install the library, please
kindly check:
Located to the examples folder, choose any example, double cilck the .ino file.
Upload the demo. If you do not know how to upload the code, please check How to
upload code.
Stand-alone Mode
Hardware
Materials required
Just power the Spartan Edge Accelerator Board via the USB Type C cable.
Software
Spartan Edge Accelerator Board can also work as a traditional FPGA development
board. The following traditional will show you how to use it at the stand-alone mode.
In this section, you will learn about the Project mode features for project creation,
source file management, design analysis, constraint definition, and synthesis and
implementation run management. This could be used as a quick reference.
Step 1: Creating a Project
Launching Vivado
Creating a New Project
1. After Vivado opens, select Create Project on the Getting Started page.
2. Click Next in the New Project wizard
3. Specify the Project Name and Location (Select “Create project subdirectory” to
create a folder for your project)
4. Click Next.
5. Select RTL Project as the Project Type and click Next.(Select Do not specify
sources at this time and add your files soon afterwards)
(The Vivado Design Suite allows for different design entry points depending on your
source file types and design tasks. You can choose the suitable type of project.)
1. Select the xc7s15ftgb196-1 part for project, and click Next, as shown in figure 1.
2. Click Finish
Figure 1.
The Vivado IDE opens project_tutorial in the default layout, as shown in figure 2.
Figure 2.
The Flow Navigator shows the basic design process clearly.
The Sources is made up of Constraints, Simulation Sources and Utility Sources.
The Design Runs creates synth_1 and impl_1 by default.
The running status of vivado is displayed in the upper right corner.
Step 2: Add and Create Your Files
*in this step, we add test.v , test_pin.xdc , test_sim.v in our project. These files are
located in different folders of vivado_tutorial/vivado_tutorial.srcs*
1. Click Add Sources in the PROJECT MANAGER of the Flow Navigator to add RTL
file.
2. Select Add or create design sources and click Next.
3. Click the button
and select options or click the options directly to add or create
files, as shown in figure 3.
Figure 3.
1. Here, we add RTL files directly. Select Add Files and add file test.v in your directory, as
shown in figure 4.
Figure 4.
1. Click Finish.
2. Click Add Sources in the PROJECT MANAGER of the Flow Navigator again to
add constraints file.
3. Select Add or create constraints and click Next.
4. Click Add Files and add your constraints file test_pin.xdc ,as shown in figure 5
Figure 5.
5. Click Finish.
6. Click Add Sources in the PROJECT MANAGER of the Flow Navigator again to
add simulation file.
7. Select Add or create simulation sources and click Next.
8. Click Add Files and add your simulation file test_sim.v ,as shown in figure 6
Figure 6.
9. Click Finish.
Finally, the file we added will appear in the Sources, as shown in figure 7.
Figure 7.
Step 3: Elaborating the RTL Design
The Vivado IDE includes an RTL analysis and IP customizing environment. There are
also several RTL Design Rule Checks (DRCs) to examine ways to improve
performance or power on the RTL design.
1. Select Open Elaborated Design in the Flow Navigator to elaborate the design.
2. Ensure that the Layout Selector pull down menu in the main Toolbar has Default
Layout selected. The Elaborated Design enables various analysis views including
an RTL Netlist, Schematic, and Graphical Hierarchy. The views have a cross-select
feature, which helps you to debug and optimize the RTL.
3. Explore the logic hierarchy in the RTL Netlist window and examine the Schematic.
You can traverse the schematic by double-clicking on cells to push into the
hierarchy, or by using commands like the Expand Cone or Expand/Collapse from
the Schematic popup menu.
4. Select any logic instance in the Schematic and right-click to select the Go to
Source or Go to Definition commands.
5. Click the Messages window at the bottom of the Vivado IDE, and examine the
messages.
6. Click the Collapse All button in the Messages toolbar.
7. Expand the Elaborated Design and the messages, as shown in figure 8.
Figure 8.
1. Click one of the links and the Text Editor opens the RTL source file with the relevant line
highlighted.
2. Close the Text Editor windows.
3. Close the Elaborated Design by clicking on the X on the right side of the Elaborated
Design window banner, and click OK to confirm.
4. Step 4: Using the IP Catalog
The Xilinx IP Catalog provides access to the Vivado IP configuration and generation
features. You can sort and search the Catalog in a variety of ways. IP can be
customized, generated, and instantiated.
1. Click the IP Catalog button in the Flow Navigator, under Project Manager.
2. Browse the IP Catalog to examine the various categories and IP filtering
capabilities.
3. Choose the corresponding IP and perform native customization and configuration of
IP within the tool and select OK
4. Close the IP Catalog tab by clicking on the X on the window tab.
5. Step 5: Running Behavioral Simulation
The Vivado IDE integrates the Vivado Simulator, which enables you to add and manage
simulation sources in the project. You can configure simulation options, and create and
manage simulation source sets. You can run behavioral simulation on RTL sources,
prior to synthesis.
1. In the Flow Navigator, under Project Manager, click the Settings command. The Settings
dialog box opens with Project Settings at the top, and Tool Settings below that, as shown in
figure 9.
Figure 9.
1. Examine the settings available on the Simulation page, then click Cancel to close the
dialog box.
2. Click the Run Simulation command in the Flow Navigator, then click the Run Behaviora
Simulation in the sub-menu, as shown in figure 10.
Figure 10.
1. Drag the bar to the left and use these tools to zoom in or zoom out to see the appropriate
image, as shown in figure 11 and figure 12.
Figure 11.
Figure 12.
1. Click X on the Right-Up corner of figure 13 and click OK to close the SIMULATION.
Figure 13.
Step 6: Reviewing Design Run Settings
Design runs are a way of configuring and storing the many options available in the
different steps of the synthesis and implementation process. You can configure these
options and save the configurations as strategies to be used in future runs.
2. Select the Synthesis page under Project Settings. For a complete description of
these options, see the Vivado Design Suite User Guide: Synthesis(UG901).
3. Select the Implementation page under Project Settings. For a complete description
of these options, see the Vivado Design Suite User Guide: Implementation(UG904).
4. Step 7: Synthesizing and Implementing the Design
After configuring the synthesis and implementation run options, you can run
synthesis and run implementation in the Design Runs or click the button
or click
corresponding buttons in the Flow Navigator to do this. The running status of vivado
is displayed in the upper right corner while Synthesizing and Implementing.
For this tutorial, we will run these steps in the Design Runs.
1. Right click the syth_1 and select Launch Runs, as shown in figure 14.
Figure 14.
1. Click ok and running status is displayed in the upper right corner, as shown in figure 15.
Figure 15.
1. Click Open Synthesized Design for further design and analysis. You can see Report
Timing Summary , Report Utilization and others, as shown in figure 16.
Figure 16.
1. Run Implementation in the same way, as shown in figure 17.
Figure 17.
1. Click Open implemented Design to see reports after implementation
2. Step 8: Generating a Bitstream File
After Implementing the Design, we can see synthesis and implement Complete in
the Design Runs,as shown in figure 18.
Figure 18.
Click Generate Bitstream in the Flow Navigator.
Step 9: Download the file
After Generate Bitstream, you have two ways to load the file to FPGA.
You can use the JTAG interface(on the Right-Up corner of figure 19) to load the bit file
to FPGA in vivado, or use the ESP32 (on the Right-Down corner of figure 19) to load
the bit file to FPGA.
Figure 19.
Follow below steps, to load bitstream to FPGA through JTAG interface
1. Power the board and connect the Platform Cable USB II (Or Compatible Cable).
2. Click Open Target and Auto Connect in the Flow Navigator.
3. While connect to the board successfully, click Program Device and choose the bit
file and click Program, as shown in figure 20
Figure 20.
1. After download the bit file, the FPGA_DONE led will light.
In this project, if you press any key or both of them(USER1 and USER2), LED L1 will go
out.
Resources
[PDF] Spartan-7 FPGAs Datasheet
[PDF] ESP32 Datasheet
Tech Support
Please submit any technical issue into our forum.
http://wiki.seeedstudio.com/Spartan-Edge-Accelerator-Board//10-3-19
