102991299
102991299
    SEEED(矽递科技)
    Wio Terminal: ATSAMD51 Core with Realtek RTL8720DN BLE 5.0 & Wi-Fi 2.4G/5G Dev Board
102991299 数据手册
    Wio Terminal: ATSAMD51 Core with Realtek RTL8720DN BLE 5.0 & Wi-Fi 2.4G/5G Dev Board SKU 102991299 Compatible with Arduino and MicroPython, Wio Terminal is an ATSAMD51-based microcontroller with wireless connectivity supported by Realtek RTL8720DN. Its CPU speed runs at 120MHz (Boost up to 200MHz). Realtek RTL8720DN chip supports both Bluetooth and Wi-Fi providing the backbone for IoT projects. The Wio Terminal itself is equipped with a 2.4” LCD Screen, onboard IMU(LIS3DHTR), Microphone, Buzzer, microSD card slot, Light sensor, and Infrared Emitter(IR 940nm). Note The Wio Terminal Battery Chassis with a builtin 650mAH Lithium battery and 6 Grove Interfaces is already launched, check it out! We are planning to develop more extension boards for Wio Terminal in the future and we are open to all suggestions from the community! Join the disccusion at Forum and tell us your thoughts!   Description The Wio (Wireless Input and Output) platform (Wio Link, Wio Nodes,etc.) was first introduced to the world at the end of 2015 by Seeed. Today a new Wio member is joining the family - Wio Terminal. Instead of being a single embedded functional module, Wio Terminal is more of a complete system, equipping with Screen + Development Board + Input/Output Interface + Enclosure. Make it an efficient and Product-Ready Product. Sensing and tagging the Real-World data with over 300 Groves created by Seeed A pythonic way to use a 100% open-source Hardware. Build your program interpreter starting from 90% with LCD screen and compact enclourse Compatible with Arduino and Micropython, Wio Terminal is an ATSAMD51-based microcontroller with wireless connectivity supported by Realtek RTL8720DN. Its CPU speed runs at 120MHz (Boost up to 200MHz). Realtek RTL8720DN chip supports both Bluetooth and Wi-Fi providing the backbone for IoT projects. The Wio Terminal itself is equipped with a 2.4” LCD Screen, onboard IMU(LIS3DHTR), microphone, buzzer, microSD card slot, light sensor, and infrared emitter(IR 940nm). On top of that, it also has two multifunctional Grove ports for Grove Ecosystem and Raspberry pi 40-pin compatible GPIO for more add-ons. With Wio Terminal: Wio Terminal + Grove = IoT System Wio Terminal + Raspberry Pi = Edge Computing System Wio Terminal + Customized add-ons = Handheld devices or endless possibilities! Highly Integrated Design MCU, LCD, WIFI, BT, IMU, Microphone, Buzzer, microSD Card, Configurable Buttons, Light Sensor, 5-Way Switch, Infrared Emitter (IR 940nm), Crypto-authentication Ready Powered by Microchip ATSAMD51P19 ARM Cortex-M4F core running at 120MHz (Boost up to 200MHz) 4 MB External Flash, 192 KB RAM Comprehensive Protocol Support SPI, I2C, I2S, ADC, DAC, PWM, UART(Serial) Powerful Wireless Connectivity Powered by Realtek RTL8720DN Dual Band 2.4Ghz / 5Ghz Wi-Fi (802.11 a/b/g/n) BLE / BLE 5.0 USB OTG Support USB-Host Accessible Devices: Mouse, Keyboard, MIDI Devices, Xbox/PS Gaming Controllers, 3D Printers USB-Client Simulated Devices: Mouse, Keyboard, MIDI Devices Grove Ecosystem 300+ Grove modules to explore with IoT Two onboard multi-functional Grove ports can be used for Digital, Analog, I2C, and PWM Raspberry Pi 40-pin Compatible Can be mounted to a Raspberry Pi as a slave device Raspberry Pi's HAT can be used with an adapter cable Software Support Arduino MicroPython ArduPy AT Firmware Demo Note If you are interested in our demos, detailed tutorials and Arduino libraries can be found in our wiki. Wio Terminal Displaying onboard IMU data in realtime Wio Terminal Displaying and Storing Light Sensor Data Applications Python Terminal Device Data Collection Device for Machine Learning Hand-held Device Retro Gaming Device IoT Controller Education Prototyping Slave device / Accessories for Raspberry Pi Pinout Diagram Hardware Overview Setup, Documentation, and Support Please visit our wiki for more information about Wio Terminal. https://www.seeedstudio.com/Wio‐Terminal‐p‐4509.html/3‐23‐20
102991299 价格&库存
很抱歉,暂时无法提供与“102991299”相匹配的价格&库存,您可以联系我们找货
  • 1+274.660251+35.49962
库存:506
