105030027
105030027
    SEEED(矽递科技)
    9V~24V I2C接口 调速控制(车载电位器)多种模式 CW/CWW、制动/正常、正弦波/方波
105030027 数据手册
      Brushless Motor Shield (TB6605FTG) SKU 105030027   The Brushless Motor Shield (TB6605FTG) is a brushless motor driver for Arduino compatible system. It supports 9V ~ 24V DC input and can continuously and continuously output large current to drive the brushless motor. With the onboard potentiometer, you can adjust the motor speed easily. This shield offers a variety of modes to choose from, you can use the four onboard switches to switch functions. With the onboard Grove I2C interface, you can work with other grove modules with this shield easily, for instance, you can use a Grove ‐ LCD RGB Backlight to display the Motor speed. We also released the TB6605 BLDC Motor Kit for Arduino, which is based on this shield and contains an LCD and a high‐quality brushless motor to display the Motor speed.     Feature Wide input voltage range: 9V ~ 24V I2C interface Hardware adjustable speed control(On‐board Potentiometer) Multiple modes available: CW/CWW, Brake/Normal, Sine wave/Square wave Hardware Overview                       https://www.seeedstudio.com/BLDC‐Motor‐Shield‐TB6605‐p‐4025.html/5‐15‐19
105030027 价格&库存
很抱歉,暂时无法提供与“105030027”相匹配的价格&库存,您可以联系我们找货
    • 1+558.33840
    • 200+216.07560
    • 500+208.48320
    • 1000+204.72480
