ROTARY CODED SWITCHES
RoHS compliant
SD-1000/2000
INTERNAL STRUCTURE
SD-1000 / 2000 series
①
④
③
②
⑥
⑦
⑤
Part name
Material
Flammability
Polyphenylenesulphide
UL94V-0
Stainless (SUS 301)
Silicone rubber
UL94HB
■ FEATURES
①
Housing
● RoHS compliant
● Fine click with metallic spring
● Low profile of 3.9 mm makes perfect for high density
board mounting applications
● Gold plated contact provides excellent reliability
● Cross and minus slot are available
● Terminal pin arrangement 3-3
②
Metallic spring
③
“O” ring
④
Insert rotor
⑤
Base
⑥
Contact
⑦
Terminal pin
Rotor : Polyamide
Pattern : Copper alloy, Gold-plated
UL94V-0
UL94V-0
■ PART NUMBER DESIGNATION
S D - 1 0 1 0 T B
Series name
Shape of terminal
No. of positions
B:Gull wing (Top setting type only)
Blank : Through hole pin (Snap-in terminal pin)
1:16 positions
2:10 positions
Shape of rotor
Form of packaging
0:Without knob (Minus slot)
1:With knob (with extended shaft)
2:Without knob (Cross slot)
T:Taping (Gull wing type only)
W:Tray packaging
Blank:Plastic bag
Code format
Setting position
1:Real code (Rotor color Yellow)
3:Complementary code (Rotor color Red)
0:Top setting
1:Side setting
※ Please refer to the LIST OF PART NUMBERS when placing orders.
SD-1000/2000
■ LIST OF PART NUMBERS
● Binary coded decimal
Shape of rotor
Top setting
With knob
(Through hole pin)
Side setting
With knob
(Through hole pin)
Form of packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Taping
Top setting
(Gull wing)
Plastic bag
Tray packaging
Taping
Real code
SD-2010
SD-2010W
SD-2110
SD-2110W
SD-2210
SD-2210W
SD-2011
SD-2011W
SD-2111
SD-2111W
SD-2211
SD-2211W
SD-2010B
SD-2010WB
SD-2010TB
SD-2210B
SD-2210WB
SD-2210TB
Complementary code
Pieces in package
SD-2030
SD-2030W
SD-2130
SD-2130W
SD-2230
SD-2230W
SD-2031
SD-2031W
SD-2131
SD-2131W
SD-2231
SD-2231W
SD-2030B
SD-2030WB
SD-2030TB
SD-2230B
SD-2230WB
SD-2230TB
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
500 pcs./reel
25 pcs./pack
50 pcs./tray
500 pcs./reel
Complementary code
Pieces in package
SD-1030
SD-1030W
SD-1130
SD-1130W
SD-1230
SD-1230W
SD-1031
SD-1031W
SD-1131
SD-1131W
SD-1231
SD-1231W
SD-1030B
SD-1030WB
SD-1030TB
SD-1230B
SD-1230WB
SD-1230TB
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
500 pcs./reel
25 pcs./pack
50 pcs./tray
500 pcs./reel
● Binary coded hexadecimal
Shape of rotor
Top setting
With knob
(Through hole pin)
Side setting
With knob
(Through hole pin)
Form of packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Taping
Top setting
(Gull wing)
Plastic bag
Tray packaging
Taping
※ Verify the above part numbers when placing orders.
※ Taping and tray version can be supplied only in reel or tray units.
Real code
SD-1010
SD-1010W
SD-1110
SD-1110W
SD-1210
SD-1210W
SD-1011
SD-1011W
SD-1111
SD-1111W
SD-1211
SD-1211W
SD-1010B
SD-1010WB
SD-1010TB
SD-1210B
SD-1210WB
SD-1210TB
SD-1000/2000
■ STANDARD SPECIFICATIONS
BCD (Real code, complementary code)
BCH (Real code, complementary code)
Circuit type
Operating temperature range
− 40 ~ 85 °C
Storage temperature range
Non-washable
Sealing
0.65 g
Without knob Top setting
0.76 g
With knob Top setting
0.95 g
Without knob Side setting
1.05 g
With knob Side setting
Net weight
■ ELECTRICAL CHARACTERISTICS
Contact rating
Non-switching
Switching
Minimum
DC50 V 100 mA
DC5 V 100 mA
DC20 mV 1 µA
Contact resistance
Insulation resistance
Dielectric strength
Amplitude 1.5 mm or
Acceleration 98 m/s2,
10-500-10 Hz, 3 directions for 2 h each
Vibration
490 m/s2, 11 ms
6 directions for 3 times each
Resistance load DC50V 100mA
40 °C, Relative humidity 90 ~ 95 %, 240 h
20000 steps
DC5 V, 100 mA
Shock
Humidity
Load life
High temperature exposure
85 °C, 96 h
Low temperature exposure
− 40 °C, 96 h
Thermal shock
− 40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles
〈Reflow profile for soldering heat evaluation〉
Temperature
250
200
150
100
50
Peak : 250
+5
150 ℃
Adjustment torque
4 ~ 25 mN·m {41 ~ 255 gf·cm}
22.5° (SD-1000), 36° (SD-2000)
Stepping angle
Terminal strength (Through hole pin only)
10 N {1.02 kgf} minimum
Stop strength (With knob only)
10 N {1.02 kgf}, 10 s
Solderability
245 ± 3 °C, 2 ~ 3 s
Gull wing
Reflow : Peak temperature 255 °C
(Please refer to the profile below.)
Manual soldering:
350 ± 10 °C, 3 ~ 4 s
Soldering
heat
Through
hole pin
Flow : 260 ± 3 °C as the temperature in
a pot of molten solder, immersion
from head of terminal to backside
of board 5 ~ 6 s, two times
maximum
Manual soldering:
380 ± 10 °C, 3 ~ 4 s
Shear (Gull wing only)
Pre Heating Zone
90 ± 30 s
30 ± 10 s
Heating time
AC250 V, 60 s
16 (SD-1000), 10 (SD-2000)
Over 230 ℃
180 ℃
1000 M Ω (DC100 V) minimum
■ MECHANICAL CHARACTERISTICS
No. of positions
■ ENVIRONMENTAL CHARACTERISTICS
100 m Ω maximum
Soldering Zone
Reflow : two times maximum
5 N {0.51 kgf}, 10 s
Substrate bending (Gull wing only)
Width 90 mm, bend 3 mm, 5 s, 1 time
Pull-off strength (Gull wing only)
{ } : Reference only
SD-1000/2000
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
● SD-1010 (Real code)
● SD-1030 (Complementary code)
● SD-2010 (Real code)
● SD-2030 (Complementary code)
0.6 W × 3.2 L × 1.2 D
10
3.9
10
3.3±0.5
3.9
3.3±0.5
② Ⓒ ⑧
② Ⓒ ⑧
BCD
6 – 0.6 ± 0.1
t = 0.15
2.54
Production date code
7.62
10
7.62
01
EF 2
10
89
67 A
345
④ Ⓒ ①
2.54
● SD-1210 (Real code)
● SD-1230 (Complementary code)
3.9
④ Ⓒ ①
2.54
● SD-2210 (Real code)
● SD-2230 (Complementary code)
0.6 W × 3.2 L × 1.5 D
10
6 – 0.6 ± 0.1
t = 0.15
2.54
3.3±0.5
10
3.9
3.3±0.5
② Ⓒ ⑧
② Ⓒ ⑧
BCD
6 – 0.6 ± 0.1
t = 0.15
2.54
7.62
10
7.62
01
EF 2
10
89
67 A
345
④ Ⓒ ①
2.54
● SD-1110 (Real code)
● SD-1130 (Complementary code)
3.9
3.3±0.5
10
6.5
3.9
3.3±0.5
② Ⓒ ⑧
6 – 0.6 ± 0.1
t = 0.15
2.54
7.62
φ 3.9
901
10
7.62
BCD
78
φ 3.9
23
456
89
67 A
345
01
EF 2
2.54
0.7 W × 1 D
6.5
② Ⓒ ⑧
10
④ Ⓒ ①
● SD-2110 (Real code)
● SD-2130 (Complementary code)
0.7 W × 1 D
10
6 – 0.6 ± 0.1
t = 0.15
2.54
④ Ⓒ ①
2.54
6 – 0.6 ± 0.1
t = 0.15
2.54
④ Ⓒ ①
2.54
SD-1000/2000
● SD-1011 (Real code)
● SD-1031 (Complementary code)
10
● SD-2011 (Real code)
● SD-2031 (Complementary code)
6.8
6.8
10
10
01
EF 2
10
89
67 A
345
3.3±0.5
3.3±0.5
BCD
① Ⓒ ④
2.54
② Ⓒ ⑧
3.3
2.54
6 – 0.6 ± 0.1
t = 0.15
2.54
● SD-1211 (Real code)
● SD-1231 (Complementary code)
10
① Ⓒ ④
2.54
6 – 0.6 ± 0.1
t = 0.15
2.54
● SD-2211 (Real code)
● SD-2231 (Complementary code)
6.8
② Ⓒ ⑧
3.3
2.54
6.8
10
10
01
EF 2
10
89
67 A
345
3.3±0.5
② Ⓒ ⑧
3.3
2.54
6 – 0.6 ± 0.1
t = 0.15
2.54
● SD-1111 (Real code)
● SD-1131 (Complementary code)
0.7 W × 1 D
10
6.5
10
6.8
10
BCD
3.3
2.54
6 – 0.6 ± 0.1
t = 0.15
3.3±0.5
78
② Ⓒ ⑧
① Ⓒ ④
2.54
φ 3.9
23
φ 3.9
01
EF 2
10
6.5
456
89
67 A
3.3±0.5
6 – 0.6 ± 0.1
t = 0.15
2.54
0.7 W × 1 D
6.8
② Ⓒ ⑧
3.3
2.54
● SD-2111 (Real code)
● SD-2131 (Complementary code)
345
2.54
① Ⓒ ④
2.54
901
3.3±0.5
BCD
① Ⓒ ④
2.54
② Ⓒ ⑧
① Ⓒ ④
2.54
2.54
3.3
2.54
6 – 0.6 ± 0.1
t = 0.15
SD-1000/2000
● SD-1010B (Real code)
● SD-1030B (Complementary code)
● SD-2010B (Real code)
● SD-2030B (Complementary code)
⑧ Ⓒ ②
4
10
1
4
⑧ Ⓒ ②
1
10
13
10
13
01
EF 2
10
89
67 A
345
BCD
2.54
6 – 0.6 ± 0.1
t = 0.15
● SD-1210B (Real code)
● SD-1230B (Complementary code)
2.54
⑧ Ⓒ ②
6 – 0.6 ± 0.1
t = 0.15
4
10
1
4
● SD-2210B (Real code)
● SD-2230B (Complementary code)
10
1
① Ⓒ ④
⑧ Ⓒ ②
1
2.54
1
① Ⓒ ④
2.54
13
10
13
01
EF 2
2.54
① Ⓒ ④
1
① Ⓒ ④
2.54
6 – 0.6 ± 0.1
t = 0.15
2.54
2.54
1
BCD
10
89
67 A
345
6 – 0.6 ± 0.1
t = 0.15
SD-1000/2000
■ CODE FORMAT
No. of positions
Position
Real code
Code
Complementary code
8
4
2
1
8
4
2
1
SD-1000 series (16 positions)
SD-2000 series (10 positions)
0 1 2 3 4 5 6 7 8 9 A B C D E F
● …Contact closed
■ TERMINAL CONNECTION / P.C.B. THROUGH HOLE DIMENSIONS
Top setting
Terminal pin
layout
(Bottom view)
Real code
Real
Real code
code
8
C 88
2 CC
22
Side setting
Operating face Operating face of
Operating
of
Operating
face complementary
Operating face
facecode
of
ofOperating
real code face
of
complementary
of real
real code
code
complementary code
code
Complementary code
Complementary
Complementary code
code
1
C 11
4 CC
44
8
C 88
2 CC
22
1
C 11
4 CC
44
1 C 4
11 CC 44
8 C 2
88 CC 22
2.54 ± 0.1 6 – φ 0.8 hole
2.54
2.54 ±± 0.1
0.1 66 –– φφ 0.8
0.8 hole
hole
2.54 ± 0.1
2.54 ±± 0.1
0.1
2.54
P.C.B. dimensions
(Bottom view)
2.54 ± 0.1
2.54 ±± 0.1
0.1
2.54
2.54
2.54 ±± 0.1
0.1 66 –– φφ 0.8
0.8 hole
hole
1 C 4
11 CC 44
8 C 2
88 CC 22
SD-1000/2000 case
SD-1000/2000
SD-1000/2000 case
case
SD-1000/2000 case
SD-1000/2000
SD-1000/2000 case
case
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
1.75
2.54
6–1
2.54
1.75
10.5
(14)
(Unit: mm)
SD-1000/2000
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500,
1000, 1500 pcs., etc.
● Taping version is boxed with one reel (500 pcs.).
Maximum number of consecutive missing pieces=2
Leader length and reel dimension are shown in the diagrams below:
● Embossed tape dimensions
● Reel dimensions
(Unit: mm)
(In accordance with EIAJ ET-7200A)
Empty
Filled
2 ± 0.5
End
φ 13 ± 0.2
Head
40 mm min.
Direction of feed
φ 21 ± 0.8
20 pitches min.
Leader
400 mm min.
φ 80 ± 1
Empty
φ 330 ± 2
25.4 ± 1
Part No. label
29.4 ± 1
(Unit: mm)
16 ± 0.1
4 ± 0.1 2 ± 0.1
0.4 ± 0.1
11.5 ± 0.1
24
φ 1.5 +0.1
1.75 ± 0.1
(In accordance with EIAJ RC-1009B)
Direction of feed
● Tray version is packaged in 50 pcs. per tray. Orders will
be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs.
etc.
● Tray version is boxed with 10 trays.
4.8
● The smallest unit of bulk pack in a plastic bag is 10 pcs.
per pack. Orders will be accepted for unit of minimum 10
pcs., i.e., 10, 20, 30 pcs. , etc.
● Boxing of bulk in a plastic bag is performed with 25 pcs.
(standard 50 pcs.) per box.
很抱歉,暂时无法提供与“SD-2011”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.683971+4.50881
- 10+29.0256810+3.77325
- 50+25.3794950+3.29926
- 100+23.96759100+3.11571
- 250+22.27240250+2.89534
- 500+21.12670500+2.74641
- 1000+20.099361000+2.61286
- 2500+18.916232500+2.45905
