CLAMP0524P
CLAMP0524P
    WPMTEK(维攀微)
    DFN2510-10
    双向ESD 5V截止 峰值浪涌电流:5A
CLAMP0524P 数据手册
CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Dimensions and Pin Configuration Description NC The CLAMP0524P is an ultra low capacitance TVS NC GND NC NC array,utilizing leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage I/O_1 I/O_2 sensitive high-speed data lines. The CLAMP0524P has an GND I/O_3 I/O_4 ultra-low capacitance with a typical value at 0.3pF, and complies with the IEC 61000-4-2 (ESD) standard with ±25kV air and ±20kV contact discharge. It is assembled into a 10-pin 2.5x1.0x0.5mm lead-free DFN package. The flow through style package allows for easy PCB layout and Circuit and Pin Schematic matched trace lengths necessary to maintain con- sistent impedance between high speed differential lines such as USB 3.0 and HDMI. The small size, ultra-low capacitance and high ESD surge protection make CLAMP0524P an Mechanical Characteristics ideal choice to protect HDMI, MDDI, USB3.0 and other  Package: DFN2510-10 (2.5×1.0×0.5mm)  Lead Finish: Matte Tin  Case Material: “Green” Molding Compound.  UL Flammability Classification Rating 94V-0 high speed ports. Features  Ultra low capacitance: 0.3pF typical (I/O to I/O)  Moisture Sensitivity: Level 3 per J-STD-020  Ultra low leakage: nA level  Terminal Connections: See Diagram Below  Low operating voltage: 5V  Marking Information: See Below  Low clamping voltage Applications  Up to 4 lines protects  HDMI 1.3 & 1.4, USB 2.0 & 3.0 and MDDI ports  Leadless flow-through package  Monitors and flat panel displays  Complies with following standards:  Set-top box and Digital TV – IEC 61000-4-2 (ESD) immunity test  Video graphics cards  Digital Video Interface (DVI)  Notebook Computers  PCI Express and Serial SATA Ports Air discharge: ±25kV Contact discharge: ±20kV – IEC61000-4-5 (Lightning) 5A (8/20µs)  RoHS Compliant Marking information Dot denotes Pin1 Ordering Information Part Number CLAMP0524P Rev.A_Aug,2016 Packaging 3000/Tape & Reel Reel Size 7 inch Details marking code reference specification of approval list -1- www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 80 W Peak Pulse Current (8/20µs) IPP 5 A ESD per IEC 61000−4−2 (Air) ±25 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range ±20 kV TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 5 V Any I/O pin to ground V IT = 1mA, any I/O pin to ground 0.5 µA VRWM = 5V, any I/O pin to ground 6 Reverse Leakage Current IR Clamping Voltage VC 9 V Clamping Voltage VC 16 V Junction Capacitance CJ 0.4 pF Junction Capacitance CJ 0.8 pF Rev.A_Aug,2016 0.01 0.3 -2- Test Condition IPP = 1A (8 x 20µs pulse), any I/O pin to ground IPP = 5A (8 x 20µs pulse), any I/O pin to ground VR = 0V, f = 1MHz, between I/O pins VR = 0V, f = 1MHz, any I/O pin to ground www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Typical Performance Characteristics (TA=25°C unless otherwise Specified) Peak Pulse Power vs. Pulse Time Junction Capacitance vs. Reverse Voltage Power Derating Curve Clamping Voltage vs. Peak Pulse Current Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform 8 kV Contact per IEC61000−4−2 Rev.A_Aug,2016 -3- www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Typical Application The CLMAP0524P is designed for easy PCB layout by allowing the traces to run straight through the device. ThePCB traces could be used to connect the pin pairs for each line. For example, line 1 enters at pin 1 and exits at pin 10 and the PCB trace connects Pin 1 and Pin 10 together. Ground is connected at Pin 3 and Pin 8. 10 1 9 2 8 3 7 4 6 5 CLMAP0524P_SC on USB 3.0 Port Application Rev.A_Aug,2016 -4- www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array CLMAP0524P on DVI Port Application Rev.A_Aug,2016 -5- www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array CLMAP0524P on HDMI Port Application Rev.A_Aug,2016 -6- www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array CLMAP0524P on VGA Port Application CLMAP0524P_SC on eSATA Port Application Rev.A_Aug,2016 -7- www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -8- www.wpmtek.com CLAMP0524P Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Package mechanical data DIMENSIONS SYM MIN MILLIMETERS NOM MAX MIN INCHES NOM MAX A 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.15 0.20 0.25 0.006 0.008 0.010 b1 0.35 0.40 0.45 0.014 0.016 0.018 b2 0.20 0.25 0.30 0.008 0.010 0.012 c 0.10 0.15 0.20 0.004 0.006 0.008 D 2.45 2.50 2.55 0.098 0.100 0.102 e 0.50BSC 0.020BSC Nd 2.00BSC 0.080BSC E 0.95 1.00 1.05 0.038 0.040 0.042 L 0.35 0.40 0.45 0.014 0.016 0.018 L1 0.075REF 0.003REF L2 0.050REF 0.002REF h 0.08 0.12 0.15 0.003 0.005 0.006 R 0.05 0.10 0.15 0.002 0.004 0.006 Suggested Land Pattern DIMENSIONS SYM MILLIMETERS INCHES X1 0.200 0.008 X2 0.400 0.016 X3 0.500 0.020 Y 0.600 0.024 Z 1.400 0.056 Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -9- www.wpmtek.com
