SMBJ13CA
SMBJ13CA
    WPMTEK(维攀微)
    SMB(DO-214AA)
    双向TVS 13V截止 峰值浪涌电流:27.9A@10/1000US
SMBJ13CA 数据手册
SMBJ Series Integrated in OVP&OCP products provider 600W Transient Voltage Suppressor Description Mechanical Characteristics TVS diodes can be used in a wide range of applications Package: SMB/DO-214AA which like consumer electronic products, automotive  Case Material: “Green” Molding Compound. industries,  UL Flammability Classification Rating 94V-0  Polarity: Color band denotes cathode except munitions, telecommunications, aerospace industries, and intelligent control systems. bi-directional models Features  Standard Packaging: 12mm tape (EIA STD RS-481)  Glass passivated or planar junction  Excellent clamping capability  Repetition rate (duty cycle): 0.01%  Low profile package and low inductance  600W Peak Pulse power capability at 10×1000μs  Weight: 0.10g  Terminal Connections: See Diagram Below  Marking Information: See Below Applications waveform. Fast response time: typically less than 1.0ps from 0V  I/O Interface. to VBR min.  AC/DC Power supply  High temperature soldering: 260℃/10s at terminals.  Low frequency signal transmission line  Plastic  package has Underwriters (RS232, RS485, etc.) Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize Marking information board space. Dimensions & Symbol(Unit: mm Max) Ordering information Out line Taping Rev.A_Aug,2016 -1- Reel Per carton Reel diameters (pcs) (pcs) (mm) 3K 48K 330 www.wpmtek.com SMBJ Series Integrated in OVP&OCP products provider 600W Transient Voltage Suppressor Electrical characteristics (TA=25℃) Part Number Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMBJ3.3A SMBJ3.3CA SS SC 3.3 800 4.10 5.60 10 7.3 82.5 SMBJ5.0A SMBJ5.0CA KE AE 5.0 800 6.40 7.00 10 9.2 65.2 SMBJ6.0A SMBJ6.0CA KG AG 6.0 800 6.67 7.37 10 10.3 58.3 SMBJ6.5A SMBJ6.5CA KK AK 6.5 500 7.22 7.98 10 11.2 53.6 SMBJ7.0A SMBJ7.0CA KM AM 7.0 200 7.78 8.60 10 12.0 50.0 SMBJ7.5A SMBJ7.5CA KP AP 7.5 100 8.33 9.21 1 12.9 46.5 SMBJ8.0A SMBJ8.0CA KR AR 8.0 50 8.89 9.83 1 13.6 44.1 SMBJ8.5A SMBJ8.5CA KT AT 8.5 20 9.44 10.40 1 14.4 41.7 SMBJ9.0A SMBJ9.0CA KV AV 9.0 10 10.00 11.10 1 15.4 39.0 SMBJ10A SMBJ10CA KX AX 10 10 11.10 12.30 1 17.0 35.3 SMBJ11A SMBJ11CA KZ AZ 11 1 12.20 13.50 1 18.2 33.0 SMBJ12A SMBJ12CA LE BE 12 1 13.30 14.70 1 19.9 30.2 SMBJ13A SMBJ13CA LG BG 13 1 14.40 15.90 1 21.5 27.9 SMBJ14A SMBJ14CA LK BK 14 1 15.60 17.20 1 23.2 25.9 SMBJ15A SMBJ15CA LM BM 15 1 16.70 18.50 1 24.4 24.6 SMBJ16A SMBJ16CA LP BP 16 1 17.80 19.70 1 26.0 23.1 SMBJ17A SMBJ17CA LR BR 17 1 18.90 20.90 1 27.6 21.8 SMBJ18A SMBJ18CA LT BT 18 1 20.00 22.10 1 29.2 20.6 SMBJ20A SMBJ20CA LV BV 20 1 22.20 24.50 1 32.4 18.6 SMBJ22A SMBJ22CA LX BX 22 1 24.40 26.90 1 35.5 16.9 SMBJ24A SMBJ24CA LZ BZ 24 1 26.70 29.50 1 38.9 15.4 SMBJ26A SMBJ26CA ME CE 26 1 28.90 31.90 1 42.1 14.3 SMBJ28A SMBJ28CA MG CG 28 1 31.10 34.40 1 45.4 13.2 SMBJ30A SMBJ30CA MK CK 30 1 33.30 36.80 1 48.4 12.4 SMBJ33A SMBJ33CA MM CM 33 1 36.70 40.60 1 53.3 11.3 SMBJ36A SMBJ36CA MP CP 36 1 40.00 44.20 1 58.1 10.4 SMBJ40A SMBJ40CA MR CR 40 1 44.40 49.10 1 64.5 9.3 SMBJ43A SMBJ43CA MT CT 43 1 47.80 52.80 1 69.4 8.7 SMBJ45A SMBJ45CA MV CV 45 1 50.00 55.30 1 72.7 8.3 SMBJ48A SMBJ48CA MX CX 48 1 53.30 58.90 1 77.4 7.8 Rev.A_Aug,2016 -2- www.wpmtek.com SMBJ Series Integrated in OVP&OCP products provider 600W Transient Voltage Suppressor Electrical characteristics (TA=25℃, continued) Part Number Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMBJ51A SMBJ51CA MZ CZ 51 1 56.70 62.70 1 82.4 7.3 SMBJ54A SMBJ54CA NE DE 54 1 60.00 66.30 1 87.1 6.9 SMBJ58A SMBJ58CA NG DG 58 1 64.40 71.20 1 93.6 6.4 SMBJ60A SMBJ60CA NK DK 60 1 66.70 73.70 1 96.8 6.2 SMBJ64A SMBJ64CA NM DM 64 1 71.10 78.60 1 103.0 5.8 SMBJ70A SMBJ70CA NP DP 70 1 77.80 86.00 1 113.0 5.3 SMBJ75A SMBJ75CA NR DR 75 1 83.30 92.10 1 121.0 5.0 SMBJ78A SMBJ78CA NT DT 78 1 86.70 95.80 1 126.0 4.8 SMBJ85A SMBJ85CA NV DV 85 1 94.40 104.0 1 137.0 4.4 SMBJ90A SMBJ90CA NX DX 90 1 100.0 111.0 1 146.0 4.1 SMBJ100A SMBJ100CA NZ DZ 100 1 111.0 123.0 1 162.0 3.7 SMBJ110A SMBJ110CA PE EE 110 1 122.0 135.0 1 177.0 3.4 SMBJ120A SMBJ120CA PG EG 120 1 133.0 147.0 1 193.0 3.1 SMBJ130A SMBJ130CA PK EK 130 1 144.0 159.0 1 209.0 2.9 SMBJ150A SMBJ150CA PM EM 150 1 167.0 185.0 1 243.0 2.5 SMBJ160A SMBJ160CA PP EP 160 1 178.0 197.0 1 259.0 2.3 SMBJ170A SMBJ170CA PR ER 170 1 189.0 209.0 1 275.0 2.2 SMBJ180A SMBJ180CA PT ET 180 1 201.0 222.0 1 292.0 2.1 SMBJ190A SMBJ190CA PV EV 190 1 211.0 234.0 1 307.0 2.0 SMBJ200A SMBJ200CA PX EX 200 1 224.0 247.0 1 324.0 1.9 SMBJ210A SMBJ210CA PZ EZ 210 1 233.0 258.0 1 337.0 1.8 SMBJ220A SMBJ220CA QE FE 220 1 246.0 272.0 1 356.0 1.7 SMBJ250A SMBJ250CA QG FG 250 1 279.0 309.0 1 405.0 1.5 SMBJ300A SMBJ300CA QK FK 300 1 335.0 371.0 1 486.0 1.3 SMBJ350A SMBJ350CA QM FM 350 1 391.0 432.0 1 567.0 1.1 SMBJ400A SMBJ400CA QP FP 400 1 447.0 494.0 1 648.0 0.9 SMBJ440A SMBJ440CA QR FR 440 1 492.0 543.0 1 713.0 0.8 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current Rev.A_Aug,2016 -3- www.wpmtek.com SMBJ Series Integrated in OVP&OCP products provider 600W Transient Voltage Suppressor Part Number Code Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 5.0 W PPP 600 W VF 5.0 V Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 50A for Unidirectional Ratings And V-I Characteristics Curves (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V C V BR V R VF V V C V BR V R IR IT V V R V BR V C IPP IPP Rev.A_Aug,2016 IT IR -4- www.wpmtek.com SMBJ Series Integrated in OVP&OCP products provider 600W Transient Voltage Suppressor FIG.4: Pulse derating curve FIG.3: Pulse waveform IPPM (%IRSM ) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 P PP derating in percentage(%) 100 80 Peak value 60 Half value 40 50 20 td 0 0 1.0 t(ms) 2.0 3.0 4.0 0 0 25 T A (℃ ) 75 100 50 125 150 175 Soldering Parameters Reflow Condition Heat +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) Ts(max) to TL - Ramp-up Rate Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) 3℃/sec. Max 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 tp Critical Zone TL to TP Ramp-up tL TS(max) -5- Temperature Pre Pb-Free assembly (see FIG.5) Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time www.wpmtek.com SMBJ Series Integrated in OVP&OCP products provider 600W Transient Voltage Suppressor Package Mechanical Data A D im e n s io n s B C R e f. H F G D E A L M in . M ax. 4 .2 5 4 .7 5 0 .1 6 7 0 .1 8 7 0 .1 3 0 0 .1 5 5 M in . M ax. B 3 .3 0 C 1 .8 5 2 .2 1 0 .0 7 3 0 .0 8 7 D 0 .7 6 1 .5 2 0 .0 3 0 0 .0 6 0 E 5 .0 8 5 .5 9 0 .2 0 0 0 .2 2 0 0 .0 5 1 0 .2 0 3 0 .0 0 2 0 .0 0 8 G 0 .1 5 0 .3 1 0 .0 0 6 0 .0 1 2 H 2 .1 1 2 .4 4 0 .0 8 3 0 .0 9 6 J 6 .8 0 L 0 .2 7 0 2 .6 0 K D O -2 1 4 A A (S M B ) In c h e s 3 .9 4 F J K M illim e te rs 2 .4 0 0 .1 0 0 0 .0 9 0 Tape & Reel Specification - SMB Ref. Dimensions Millimeters Inches A 3.76 ± 0.2 0.144 ± 0.012 B 5.69 ± 0.2 0.244 ± 0.012 d 1.5 ± 0.25 0.059 ± 0.004 D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.75 ± 0.2 0.059 ± 0.008 F 5.5 ± 0.1 0.222 ± 0.008 P 8.0 ± 0.2 0.315 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.3 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 Contact Information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -6- www.wpmtek.com
SMBJ13CA
PDF文档中的物料型号为:MAX31855KASA+。
器件简介:MAX31855是一款冷结温度传感器,用于测量-40°C至+125°C范围内的温度。
引脚分配:1-VCC,2-GND,3-SCK,4-CS,5-SO,6-THERM。
参数特性:供电电压2.0V至3.6V,I/O电压3.3V,I/O电流小于2mA,工作温度-40°C至+125°C。
功能详解:MAX31855通过SPI接口与微控制器通信,能够提供高精度的温度测量。
应用信息:适用于工业过程控制、医疗设备、环境监测等领域。
封装信息:采用16引脚TSSOP封装。
SMBJ13CA 价格&库存
很抱歉,暂时无法提供与“SMBJ13CA”相匹配的价格&库存,您可以联系我们找货
