B5819W
B5819W
    WPMTEK(维攀微)
    SOD-123
    电压:40V 电流:1A
B5819W 数据手册
B5817W/B5818W/B5819W SOD-123 贴片塑封肖特基二极管 SOD-123 Plastic-Encapsulate Schottky Barrier Diode SOD-123 特征 Features z 大电流承受能力。High Current Capability z 正向压降低。Low Forward Voltage Drop 机械数据 Mechanical Data Marking: B5817W: SJ B5818W: SK B5819W: SL z z z z 封装: SOD-123 封装 SOD-123 Small Outline Plastic Package 极性: 色环端为负极 Polarity: Color band denotes cathode end 环氧树脂 UL 易燃等级 Epoxy UL: 94V-0 安装位置: 任意 Mounting Position: Any 极限值和温度特性(TA = 25℃ 除非另有规定) Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) 参数 符号 Parameters Symbol 最大可重复峰值反向电压 Maximum repetitive peak reverse voltage 最大均方根电压 Maximum RMS voltage 最大直流阻断电压 Maximum DC blocking voltage 最大正向平均整流电流 Maximum average forward rectified current 峰值正向浪涌电流 8.3ms 单一正弦半波 Peak forward surge current 8.3 ms single half sine-wave 典型热阻 Typical thermal resistance 功率消耗 Power Dissipation 存储温度 Storage temperature range 单位 B5817W B5818W B5819W VRRM 20 30 40 V VRMS 14 21 28 V VDC 20 30 40 V Unit IFM 1.0 A IFSM 9 A RθJA 250 ℃/W PD 500 mW TSTG -50-+150 ℃ 电特性 (TA = 25℃ 除非另有规定) Electrical Characteristics (Ratings at 25℃ 参数 Parameters ambient temperature unless otherwise specified). 符号 测试条件 Symbol Test conditions 单位 B5817W B5818W B5819W Unit 最大正向电压 Maximum forward voltage 最大反向电压 Maximum reverse breakdown voltage 最大反向电流 Maximum reverse current VF IF = 1.0A IF = 3.0A 0.450 0.750 0.550 0.875 0.600 0.900 V VR IR=1mA 20 30 40 V IR VR=20V B5817W VR=30V B5818W VR=40V B5819W 1.0 mA 典型结电容 Type junction capacitance Cj VR = 4.0V, f = 1MHz 120 pF V1.0_Aug,2018 -1- www.wpmtek.com B5817W/B5818W/B5819W 特性曲线Characteristic Curves SOD-123 PACKAGE OUTLINE Plastic surface mounted package θ θ 焊盘设计参考Precautions: PCB Design(Recommended land dimensions for SOD-123 diode. Electrode patterns for PCBs) 技术要求: 3.24 中心距: 3.24 1, 塑封体尺寸: 2.70 X 1.60 宽: 0.55 2: 未注公差为: ±0.05 焊盘宽: 1.00 3, 所有单位: mm 脚 长: 0.50 焊盘长: 0.80 脚 1.0 0.8 V1.0_Aug,2018 -2- www.wpmtek.com
B5819W 价格&库存
很抱歉,暂时无法提供与“B5819W”相匹配的价格&库存,您可以联系我们找货
