PRODUCT DATASHEET
A600 Series PTC Devices
Description
The JDTFUSE A600 Series is designed to protect
against power fault events typically found in telecom
applications. This series is designed to be used in
applications that need to meet the requirements of
GR–1089-CORE and UL60950/EN60950/IEC60950.
These resettable devices also help to meet the
requirements of ITU K.20, K.21 and K.44.
Features
● 0.15 - 0.16A hold current range, 60VDC operating
voltage
● 600VAC interrupt rating
● Fast time-to-trip
● Binned and sorted narrow resistance ranges available
● RoHS compliant, Lead-Free and Halogen-Free*
Agency Approvals
Agency
Applications
File Number
E472196
pending
Secondary overcurrent protection for:
● Central Office Equipment(CO)
● Customer Premises Equipment(CE)
● Alarm systems
● Set Top Boxes(STB)
● Voice over IP(VOIP)
● Subscriber Line Interface Circuit (SLIC)
Regulation
Standard
2002/95/EC
EN14582
JDT FUSE Industrial Corp.
www.jdtfuse.com
Page 1/6
Performance Specification
Model
I hold
I trip
V max
V max
Operating Interrupt
(V dc)
(Vrms)
I max
@25°C
(A)
@25°C
(A)
(A)
A600-150
0.150
0.300
60
600
3.0
A600-160
0.160
0.320
60
600
3.0
Pd
Typ.
(W)
Maximum
Time To Trip
Resistance
Current
(A)
Time
(Sec)
R i min
R1max
1.00
1.00
5.00
6.00
22.00
1.00
1.00
7.00
4.00
18.00
(Ω)
(Ω)
I hold = Hold Current. Maximum current device will not trip in 25°C still air.
I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air.
V max = Maximum operating voltage device can withstand without damage at rated current (Imax).
I max = Maximum fault current device can withstand without damage at rated voltage (V max).
Pd
= Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage.
Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C.
R1max = Maximum device resistance is measured one hour post reflow.
CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame.
Environmental Specifications
Conditions
Test
Resistance change
Passive aging
+85°C, 1000 hrs.
±5% typical
Humidity aging
+85°C, 85% R.H. , 168 hours
±5% typical
Thermal shock
+85°C to -40°C, 20 times
±33% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
MIL-STD-202,Method 201
No change
Vibration
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
www.jdtfuse.com
Page 2/6
Thermal Derating Curve
180
Percentage of Rated Current
160
140
120
100
80
60
40
-10
40
50
60
70
80
Temperature (°C )
Average Time-Current Curve
TIME IN SECOND
100
10
1
0.1
1
1.5
2
2.5
3
CURRENT IN AMPERES
D600-150
D600-160
Ihold Versus Temperature
Model
Maximum ambient operating temperature (Tmao) vs. hold current (Ihold)
- 40°C
- 20°C
0°C
25°C
40°C
50°C
60°C
70°C
85°C
A600-150
0.233
0.206
0.178
0.150
0.124
0.110
0.096
0.083
0.062
A600-160
0.249
0.219
0.190
0.160
0.132
0.117
0.103
0.088
0.066
www.jdtfuse.com
Page 3/6
Soldering Parameters
TP 20~40 S
TP 260
Ramp-up
Critical Zone
TL to TP
TL 217
tL
Tsmax
60~150 s
Temperature (°C )
200
Tsmin
Ramp-down
150
ts
Preheat 60~180 s
25
t 25°C to peak
Time
Profile Feature
Average Ramp-Up Rate
Pb-Free Assembly
3℃/second mac.
(Ts max to T p)
Preheat
-Temperature Min(Ts min)
150℃
-Temperature Max(Ts max)
200℃
-Time(Ts min to Ts max)
60~180 seconds
Time maintained above:
-Temperature(TL)
217℃
-Time(tL)
60~150 seconds
Peak Temperature(Tp)
260℃
Ramp-Down Rate
6℃/second max.
Time 25℃ to Peak Temperature 8 minutes max
Storage Condition
0℃~35℃,≤70%RH
Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free
Recommended maximum paste thickness is 0.25mm
Devices can be cleaned using standard industry methods and solvents.
Note 1:All temperature refer to topside of the package, measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.
www.jdtfuse.com
Page 4/6
J600 Series PTC Devices
Physical Dimensions(mm.)
A
E
a600
B
= Trademark
RF150
= Radial type 600 Vrms
= 150mA hold current
D
C
A
B
C
D
E
Max.
Max.
Typ.
Min.
Max.
Lead
Style
A600-150
13.5
12.6
5.1
4.7
6.0
Kink
A600-160
13.5
12.6
5.1
4.7
6.0
Kink
Model
PHYSICAL SPECIFICATIONS :
Materials :
J600: Tin-plated copper, 22AWG, Φ0.65mm(0.026 in).
Lead Solderability : MIL-STD-202, Method 208E
www.jdtfuse.com
Page 5/6
Packaging Quantity
A600
150
RA
B-0.5
Reel QTY
Bag QTY
Product
Hold
Rx=
B-x.x=
500
500
Series
Current
Resistance
Resistance bin range
(mA)
range
within 0.5 ohms
(Optional)
in one lot
(Optional)
Tape & Reel packaging per EIA468-B standard.
Cross Reference
Cross Reference
Model
Tyco / PolySwitch®
Bourns / POLY-FUSE®
Polytronics / EVERFUSE®
A600-150
TRF600-150
MF-R015/600
HVR600P150CF
A600-160
TRF600-160
MF-R016/600
HVR600P160CF
“PolySwitch” is a registered trademark of Tyco Electronics.
“POLY-FUSE” is a registered trademark of Littelfuse,Inc.
“EVERFUSE” is a registered trademark of Polytronics Technology Corp.
www.jdtfuse.com
Page 6/6
很抱歉,暂时无法提供与“A600-150”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.00305
- 50+0.81145
- 150+0.72934
- 500+0.56730
- 2500+0.52168
- 5000+0.49421
