A600-160
A600-160
    JDTFUSE(集电通)
    插件,P=5.1mm
    PTC自恢复保险丝 160mA 600V
A600-160 数据手册
PRODUCT DATASHEET A600 Series PTC Devices A600 Series PTC Devices Description The JDTFUSE A600 Series is designed to protect against power fault events typically found in telecom applications. This series is designed to be used in applications that need to meet the requirements of GR–1089-CORE and UL60950/EN60950/IEC60950. These resettable devices also help to meet the requirements of ITU K.20, K.21 and K.44. Features ● 0.15 - 0.16A hold current range, 60VDC operating voltage ● 600VAC interrupt rating ● Fast time-to-trip ● Binned and sorted narrow resistance ranges available ● RoHS compliant, Lead-Free and Halogen-Free* Agency Approvals Agency Applications File Number E472196 pending Secondary overcurrent protection for: ● Central Office Equipment(CO) ● Customer Premises Equipment(CE) ● Alarm systems ● Set Top Boxes(STB) ● Voice over IP(VOIP) ● Subscriber Line Interface Circuit (SLIC) Regulation Standard 2002/95/EC EN14582 JDT FUSE Industrial Corp. www.jdtfuse.com Page 1/6 A600 Series PTC Devices Performance Specification Model I hold I trip V max V max Operating Interrupt (V dc) (Vrms) I max @25°C (A) @25°C (A) (A) A600-150 0.150 0.300 60 600 3.0 A600-160 0.160 0.320 60 600 3.0 Pd Typ. (W) Maximum Time To Trip Resistance Current (A) Time (Sec) R i min R1max 1.00 1.00 5.00 6.00 22.00 1.00 1.00 7.00 4.00 18.00 (Ω) (Ω) I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Test Resistance change Passive aging     +85°C, 1000 hrs. ±5% typical Humidity aging     +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock     +85°C to -40°C, 20 times ±33% typical Resistance to solvent     MIL-STD-202,Method 215 No change MIL-STD-202,Method 201 No change Vibration     Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C JDT FUSE Industrial Corp. www.jdtfuse.com Page 2/6 A600 Series PTC Devices Thermal Derating Curve 180 Percentage of Rated Current 160 140 120 100 80 60 40 20 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 Temperature (°C ) Average Time-Current Curve TIME IN SECOND 100 10 1 0.1 0 0.5 1 1.5 2 2.5 3 CURRENT IN AMPERES D600-150 D600-160 Ihold Versus Temperature Model Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C A600-150 0.233 0.206 0.178 0.150 0.124 0.110 0.096 0.083 0.062 A600-160 0.249 0.219 0.190 0.160 0.132 0.117 0.103 0.088 0.066 JDT FUSE Industrial Corp. www.jdtfuse.com Page 3/6 A600 Series PTC Devices Soldering Parameters TP 20~40 S TP 260 Ramp-up Critical Zone TL to TP TL 217 tL Tsmax 60~150 s Temperature (°C ) 200 Tsmin Ramp-down 150 ts Preheat 60~180 s 25 t 25°C to peak Time Profile Feature Average Ramp-Up Rate Pb-Free Assembly 3℃/second mac. (Ts max to T p) Preheat -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT FUSE Industrial Corp. www.jdtfuse.com Page 4/6 J600 Series PTC Devices Physical Dimensions(mm.) A E a600 B = Trademark RF150 = Radial type 600 Vrms = 150mA hold current D C A B C D E Max. Max. Typ. Min. Max. Lead Style A600-150 13.5 12.6 5.1 4.7 6.0 Kink A600-160 13.5 12.6 5.1 4.7 6.0 Kink Model PHYSICAL SPECIFICATIONS : Materials : J600: Tin-plated copper, 22AWG, Φ0.65mm(0.026 in). Lead Solderability : MIL-STD-202, Method 208E JDT FUSE Industrial Corp. www.jdtfuse.com Page 5/6 A600 Series PTC Devices Packaging Quantity A600 150 RA B-0.5 Reel QTY Bag QTY Product Hold Rx= B-x.x= 500 500 Series Current Resistance Resistance bin range (mA) range within 0.5 ohms (Optional) in one lot (Optional) Tape & Reel packaging per EIA468-B standard. Cross Reference Cross Reference Model Tyco / PolySwitch® Bourns / POLY-FUSE® Polytronics / EVERFUSE® A600-150 TRF600-150 MF-R015/600 HVR600P150CF A600-160 TRF600-160 MF-R016/600 HVR600P160CF “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com Page 6/6
A600-160 价格&库存
很抱歉,暂时无法提供与“A600-160”相匹配的价格&库存,您可以联系我们找货
A600-160
  • 5+0.80191
  • 50+0.63318
  • 150+0.54881
  • 500+0.48553
  • 2500+0.43491
  • 5000+0.40959
库存:5774
