PRODUCT DATASHEET
ASMD1210 Series Surface Mount PTC Devices
Description
The ASMD1210 series provides surface mount
resettable overcurrent protection with holding current
from 0.05A to 2.00A.
This series is suitable for wide range of applications
in modern electronics where space is limited.
Features
● RoHS compliant and lead-free
● Low profile
● Halogen-free
● Fast response to fault current
● Compact design saves board space
● Compatible with high temperature solders
Agency Approvals
Agency
Applications
File Number
pending
pending
● Battery PCM
● Game console port protection
● USB hubs, ports and peripherals
● Optical disk drives
● Set-top-box and HDMI
● General electronics
Regulation
Standard
2002/95/EC
EN14582
JDT FUSE Industrial Corp.
www.jdtfuse.com
Page 1/7
Performance Specification
Model
V max
(V dc)
I max
(A)
I hold
I trip
Maximum
Time To Trip
Pd
@25°C
(A)
@25°C
(A)
Typ.
(W)
Resistance
Current
(A)
Time
(Sec)
R i min
R1max
(Ω)
(Ω)
ASMD1210-005
30.0
100
0.05
0.15
0.6
0.25
1.50
2.800
50.000
ASMD1210-010
30.0
100
0.10
0.30
0.6
0.50
0.60
0.800
15.000
ASMD1210-020
30.0
100
0.20
0.40
0.6
8.0
0.02
0.400
5.000
ASMD1210-035
6.0
100
0.35
0.75
0.6
8.0
0.20
0.200
1.300
ASMD1210-050
13.2
100
0.50
1.00
0.6
8.0
0.10
0.180
0.900
ASMD1210-075
6.0
100
0.75
1.50
0.6
8.0
0.10
0.070
0.400
ASMD1210-110
6.0
100
1.10
2.20
0.6
8.0
0.30
0.050
0.210
ASMD1210-150
6.0
100
1.50
3.00
0.6
8.0
0.50
0.030
0.110
ASMD1210-175
6.0
100
1.75
3.50
0.8
8.0
0.60
0.020
0.080
ASMD1210-200
6.0
100
2.00
4.00
0.8
8.0
1.00
0.015
0.070
I hold = Hold Current. Maximum current device will not trip in 25°C still air.
I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air.
V max = Maximum operating voltage device can withstand without damage at rated current (Imax).
I max = Maximum fault current device can withstand without damage at rated voltage (V max).
Pd
= Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage.
Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C.
R1max = Maximum device resistance is measured one hour post reflow.
CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame.
Environmental Specifications
Conditions
Test
Resistance change
Passive aging
+85°C, 1000 hrs.
±5% typical
Humidity aging
+85°C, 85% R.H. , 168 hours
±5% typical
Thermal shock
+85°C to -40°C, 20 times
±33% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
Vibration
MIL-STD-202,Method 201
No change
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
www.jdtfuse.com
Page 2/7
Thermal Derating Curve
Percentage of Derated Current
Derating Curves for SMD1210 Series
160
140
120
100
80
60
40
-20
60
80
Temperature (°C )
Average Time-Current Curve
TIME IN SECOND
100
0.05A
0.10A
0.12A
0.20A
0.25A
0.35A
0.50A
0.75A
1.00A
1.10A
1.50A
2.00A
10
1
0.1
0.01
0.1
1
10
CURRENT IN AMPERES
www.jdtfuse.com
Page 3/7
Thermal Derading Chart
Maximum ambient operating temperature (Tmao) vs. hold current (Ihold)
Model
- 40°C
- 20°C
0°C
25°C
40°C
50°C
60°C
70°C
85°C
ASMD1210-005
0.08
0.07
0.06
0.05
0.04
0.04
0.03
0.03
0.02
ASMD1210-010
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
ASMD1210-020
0.29
0.26
0.22
0.20
0.16
0.14
0.13
0.11
0.08
ASMD1210-035
0.47
0.45
0.40
0.35
0.33
0.28
0.24
0.21
0.18
ASMD1210-050
0.76
0.67
0.58
0.50
0.43
0.40
0.36
0.32
0.28
ASMD1210-075
1.00
0.97
0.86
0.75
0.64
0.59
0.54
0.48
0.40
ASMD1210-110
1.69
1.48
1.29
1.10
0.88
0.76
0.65
0.57
0.43
ASMD1210-150
2.13
1.92
1.71
1.50
1.26
1.14
1.01
0.89
0.71
ASMD1210-175
2.54
2.30
2.02
1.75
1.47
1.33
1.18
1.05
0.86
ASMD1210-200
2.90
2.63
2.31
2.00
1.68
1.52
1.35
1.20
0.98
Soldering Parameters
TP 20~40 S
TP 260
Ramp-up
Profile Feature
Critical Zone
TL to TP
TL 217
tL
Tsmax
Temperature (°C )
Preheat
Tsmin
Ramp-down
ts
Preheat 60~180 s
25
3℃/second mac.
(Ts max to T p)
60~150 s
200
150
Average Ramp-Up Rate
Pb-Free Assembly
t 25°C to peak
Time
Recommended reflow methods: IR, vapor phase oven,
hot air oven, N2 environment for lead-free
Recommended maximum paste thickness is 0.25mm
Devices can be cleaned using standard industry methods
and solvents.
Note 1:All temperature refer to topside of the package,
measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended
profile, devices may not meet the performance
requirements.
www.jdtfuse.com
-Temperature Min(Ts min)
150℃
-Temperature Max(Ts max)
200℃
-Time(Ts min to Ts max)
60~180 seconds
Time maintained above:
-Temperature(TL)
217℃
-Time(tL)
60~150 seconds
Peak Temperature(Tp)
260℃
Ramp-Down Rate
6℃/second max.
Time 25℃ to Peak Temperature 8 minutes max
Storage Condition
0℃~35℃,≤70%RH
Page 4/7
Physical Dimensions(mm.)
A
Model
B
C
D
E
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Min.
ASMD1210-005
3.00
3.43
2.35
2.80
0.30
0.80
0.30
0.10
ASMD1210-010
3.00
3.43
2.35
2.80
0.30
0.80
0.30
0.10
ASMD1210-020
3.00
3.43
2.35
2.80
0.30
0.80
0.30
0.10
ASMD1210-035
3.00
3.43
2.35
2.80
0.30
0.80
0.30
0.10
ASMD1210-050
3.00
3.43
2.35
2.80
0.30
0.80
0.30
0.10
ASMD1210-075
3.00
3.43
2.35
2.80
0.30
0.80
0.30
0.10
ASMD1210-110
3.00
3.43
2.35
2.80
0.30
0.80
0.30
0.10
ASMD1210-150
3.00
3.43
2.35
2.80
0.40
0.80
0.30
0.10
ASMD1210-175
3.00
3.43
2.35
2.80
0.50
1.20
0.30
0.10
ASMD1210-200
3.00
3.43
2.35
2.80
0.50
1.20
0.30
0.10
Termination Pad Characteristics
Terminal pad materials:Tin-plated Nickel-Copper
Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3.
Packaging Quantity and Marking
2.0±0.1
Part Number
1.9±0.1
1.0±0.1
www.jdtfuse.com
Quantity
ASMD1210-050.075
4000 pcs/reel
The others
4500 pcs/reel
1.0±0.1
Page 5/7
Tape And Reel Specifications (mm)
Governing Specifications
EIA 481-1
W
8.15 ± 0.2
P0
4.0 ± 0.10
P1
4.0 ± 0.10
P2
2.0 ± 0.05
A0
2.82 ± 0.10
B0
3.52 ± 0.10
B1max.
4.35
D0
1.50 + 0.1, -0
F
3.5 ± 0.05
E1
1.75 ± 0.10
E2min.
6.25
T
0.6
T1max.
0.1
K0
1.04 ± 0.1
Leader min.
390
Trailer min.
160
Reel Dimensions
A max.
178
N min.
60
W1
9 ± 0.5
W2
12.6 ± 0.5
Storage And Handling
● Storage conditions:40°C max, 70% R.H.
● Devices may not meet specified performance
if storage conditions are exceeded.Technology Corp.
www.jdtfuse.com
P1
P2
D0
P0
E1
F
W
T
D2
K0
A0
B0
H
W4
W3
D
C
W2
W
F
W1
H1
Page 6/7
Part Number System
ASMD 1210 -
Special Voltage Rating(Optional)
Holding Current Rating
Device Dimensions:
Length/width(Unit:1/100 inch) Size 3225 mm / 1210 inch
Surface Mount Device
Cross Reference
Cross Reference
Model
Tyco / PolySwitch®
Littelfuse / POLY-FUSE®
Polytronics / EVERFUSE®
ASMD1210-005
MicroSMD005F
1210L005
SMD1210P005TF
ASMD1210-010
MicroSMD010F
1210L010
SMD1210P010TF
ASMD1210-020
1210L020
SMD1210P020TF
ASMD1210-035
MicroSMD035F
1210L035
SMD1210P035TF
ASMD1210-050
MicroSMD050F
1210L050
SMD1210P050TF
ASMD1210-075
MicroSMD075F
1210L075
SMD1210P750TF
ASMD1210-110
MicroSMD110F
1210L110
SMD1210P110TF
ASMD1210-150
MicroSMD150F
1210L150
SMD1210P150TF
ASMD1210-175
MicroSMD175F
1210L175
SMD1210P175TF
ASMD1210-200
MicroSMD200F
1210L200
SMD1210P200TF
“PolySwitch” is a registered trademark of Tyco Electronics.
“POLY-FUSE” is a registered trademark of Littelfuse,Inc.
“EVERFUSE” is a registered trademark of Polytronics Technology Corp.
www.jdtfuse.com
Page 7/7
很抱歉,暂时无法提供与“ASMD1210-075”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.57840
- 100+0.34500
- 1000+0.24150
- 4000+0.17250
- 8000+0.16390
- 40000+0.15180
- 国内价格
- 10+0.33645
- 100+0.26792
- 300+0.23371
- 1000+0.20804
- 4000+0.18751
- 8000+0.17725
