MBR230LSTR
MBR230LSTR
    SMCDIODESOLUTIONS(桑德斯)
    SOD123
    DIODE SCHOTTKY 30V 2A SOD123
MBR230LSTR 数据手册
SANGDEST MICROELECTRONICS MBR230LS SURFACE MOUNT SCHOTTKY BARRIER DIODE Green Products Technical Data Data Sheet N1466, Rev. - MBR230LS SURFACE MOUNT SCHOTTKY BARRIER DIODE Features: • • • • • • • • • Low Turn-on Voltage Fast Switching PN Junction Guard Ring Transient and ESD Protection Designed for Surface Mount Application Plastic Material - UL Recognition Flammability Classification 94V-O Green Products in Compliance with the ROHS Directive This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data: • • • • Case: SOD-123, Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.01 grams(approx) Mechanical Dimensions: In mm / Inches SOD-123(CJ) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR230LS SURFACE MOUNT SCHOTTKY BARRIER DIODE Green Products Technical Data Data Sheet N1466, Rev. - Marking Diagram: Where X is Date Code B3N = Part Name Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR230LS Package SOD-123(Pb-Free) Shipping 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR230LS SURFACE MOUNT SCHOTTKY BARRIER DIODE Green Products Technical Data Data Sheet N1466, Rev. - Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol Value Unit VR 30 V Average Rectified Output Current IF(AV) 2 A Forward Voltage @IF = 0.5A,TA = 25°C @IF = 2.0A,TA = 25°C VFM 0.3 0.5 V Peak Reverse Current At Rated DC Blocking Voltage @TA = 25°C IRM 1.0 mA IFSM 25 A Cj 170 pF TJ -55 to +100 °C Storage Temperature Range TSTG -55 to +100 °C Voltage Rate of Change (rated VR, TJ=25°C) d v/dt 10000 V/µs wt 0.028 g Peak Reverse Voltage Non−Repetitive Peak Surge Current (Surge Applied at Rated Load Conditions Halfwave, Single Phase, 60 Hz) Maximum Junction Capacitance (Note 1) Operating Junction Temperature Range Approximate Weight Case Style SOD-123 Note 1. Measured at 1MHz and applied reverse voltage of 5.0V D.C. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS Technical Data Data Sheet N1466, Rev. - MBR230LS SURFACE MOUNT SCHOTTKY BARRIER DIODE Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
MBR230LSTR 价格&库存
很抱歉,暂时无法提供与“MBR230LSTR”相匹配的价格&库存,您可以联系我们找货
