Data sheet | Item number: 890-115
Plug; with strain relief housing; 5-pole; 1,50 mm²; black
www.wago.com/890-115
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/11
Dimensions in mm
Overall length when mated
Item description
Male connector/plug WINSTA® MINI with protection against mismating
Use effective pluggable connections instead of laborious screw connections: With the WINSTA® MINI male connector/plug with protection type
IP40. WAGO pluggable installation connectors are useful when requirements repeat or are distributed on a specific grid, for example for installing
grid lighting or flush-mount lighting.
The coding options reduce installation errors, allowing fast, secure wiring of all components. The pluggable installation connector is protected
against ingress by solid granular objects with a diameter of less than 1 mm in accordance with protection type IP40. Standard mains applications for
Hansastr. 27
32423 Minden
13.10.2021 Page 2/11
almost any domain of use can be realised with WINSTA® MINI pluggable installation connectors with A coding. Where space is tight, our smallest
pluggable connection system, WINSTA® MINI, conveniently displays its advantageous properties. It saves space, and, thanks to Push-in CAGE
CLAMP® spring pressure connection technology, it additionally saves time, since the connection is low-maintenance and can be performed without
screw connections. The strip length is 45 mm.
WINSTA® MINI solutions for your electrical installation – protected against mismating and maintenance-free
WINSTA® is the pluggable connection system that is ideally tailored to the strict requirements of electrical installation. It allows error-free installation
of cables and components, quickly and reliably. Now you can also cut installation expenses without compromising quality and safety: The WINSTA®
MINI pluggable installation connector with protection type IP40 reduces the need for servicing and prevents unnecessary downtime.
protection against mismating eliminates errors
compact design for conductors with a cross-section up to 1.5 mm²
with A coding for a large number of uses
custom-engineered solutions
quick replacement of defective units during ongoing operation
Data
Electrical data
Note on contact resistance
approx. 1 mΩ of contact resistance
approx. 0.25 mΩ contact transition plug/socket
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
400 V
Rated surge voltage (III/3)
6 kV
Rated current
13 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Hinweis für den amerikanischen Markt
Application note for the U.S. market (USR): Some versions may also
be used for current interruption in accordance with the UL
certificate in select applications with currents below 5 A and
voltages up to 600 V. For further information, please contact your
local sales office.
Rated voltage UL 1977
600 V
Rated current UL 1977
12 A
Connection data
Total number of connection points
5
Total number of potentials
5
Hansastr. 27
32423 Minden
13.10.2021 Page 3/11
5
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Push-in
Nominal cross-section
1.5 mm²
Solid conductor
0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor; push-in termination
0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor
0.25 … 1 mm² / 22 … 18 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor; with uninsulated ferrule
Fine-stranded conductor; with ferrule; push-in termination
0.75 mm² / 20 AWG
Strip length
9 mm / 0.35 inch
Pole No.
5
Connectable sheathed cable diameter
6.5 … 10.5 mm
Conductor entry direction to mating direction
0 °
Strip length (outer insulation)
45 mm
Physical data
Pin spacing
4.4 mm / 0.173 inch
Width
26.7 mm / 1.051 inch
Height
15.8 mm / 0.622 inch
Depth
71.9 mm / 2.831 inch
Mechanical data
Application
General mains applications
Coding
A
Marking
N⏚123
Potentialkennzeichnung
N⏚123
Mating force of a plug-in connection
approx. 20 … 70 N (depending on pole number)
Retention force of a plug-in connection
Locked: > 80 N
Unmating force of a plug-in connection
Unlocked: approx. 20 … 70 N (depending on pole number)
Number of mating cycles
200, without resistive load
Protection class
IP40
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Hansastr. 27
32423 Minden
13.10.2021 Page 4/11
Male connector/plug
Connector (connection type)
for conductor
Mismating protection
Yes
Note on mismating protection
All WINSTA® components are 100% protected against mismating
when:
a.) plugging different numbers of poles
b.) plugging while rotated 180
c.) plugging while laterally staggered
d.) plugging one pole
Locking lever
Can be retrofitted
Locking of plug-in connection
locking lever
Hinweis zur Verriegelung
All connectors for mounted installations (snap-in versions for
lighting fixtures or devices, all types of PCB and distribution
connectors) are factory-equipped with locking levers to ensure
plugs and sockets are securely locked. Additional locking levers are
only required for flying leads (plug/socket).
Strain relief
Material data
Color
black
Insulation material
Polyamide (PA66)
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper or copper alloy (surface-treated)
Fire load
0.141 MJ
Weight
11.6 g
Environmental requirements
Processing temperature
-5 … +40 °C
Continuous operating temperature
-35 … +85 °C
Note on continuous operating temperature
Insulating parts for temperatures ≤ 105 °C
Commercial data
Product Group
20 (WINSTA)
PU (SPU)
50 Stück
Packaging type
box
Country of origin
DE
GTIN
4045454232924
Customs tariff number
85366990990
Approvals
/ Certificates
Hansastr. 27
32423 Minden
13.10.2021 Page 5/11
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 61535
71-11299
CCA
IEC 61535
NL-64352
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
Steel Vessel Rules
19HG1869855PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001Z6
LR
Lloyds Register
EN 61535
08/20047
(E2)
UL-Approvals
Logo
Approval
Certificate
name
cURus
Underwriters Laboratories Inc.
UL 1977
E45171
Counterpart
Item no.890-621
T-distribution connector; 5-pole; Cod. A; 1 input; 2 outputs; 2 locking levers; black
www.wago.com/890-621
Item no.890-205
Socket; 5-pole; Cod. A; 1,50 mm²; black
www.wago.com/890-205
Item no.890-105
Socket; with strain relief housing; 5-pole; Cod. A; 1,50 mm²; black
www.wago.com/890-105
Item no.890-622
T-distribution connector; 5-pole; Cod. A; 1 input; 2 outputs; 3 locking levers; for flying leads; black
www.wago.com/890-622
Item no.890-705/006-000
Hansastr. 27
32423 Minden
www.wago.com/890-705/006-
13.10.2021 Page 6/11
Snap-in socket; without locking lever; 5-pole; Cod. A; 1,50 mm²; black
www.wago.com/890-705/006000
Item no.890-705
Snap-in socket; 5-pole; Cod. A; 1,50 mm²; black
Item no.890-805
Socket for PCBs; straight; 5-pole; Cod. A; black
www.wago.com/890-805
Item no.890-805/011-000
Socket for PCBs; angled; 5-pole; Cod. A; black
www.wago.com/890-805/011000
Item no.890-929
h-distribution connector; 5-pole; Cod. A; 1 input; 2 outputs; outputs on one side; 2 locking levers;
black
www.wago.com/890-929
Item no.890-930
h-distribution connector; 5-pole; Cod. A; 1 input; 2 outputs; outputs on one side; 3 locking levers; for www.wago.com/890-930
flying leads; black
Item no.891-8995/006-101
pre-assembled interconnecting cable; Eca; Socket/plug; 5-pole; Cod. A; H05VV-F 5G 1.5 mm²; 1 m;
1,50 mm²; black
www.wago.com/891-8995
/006-101
Item no.891-8995/106-101
pre-assembled connecting cable; Eca; Socket/open-ended; 5-pole; Cod. A; H05VV-F 5G 1.5 mm²; 1
m; 1,50 mm²; black
/106-101
Required accessories
Locking levers
Locking device
Item no.: 890-111
Locking lever; for flying leads; for tool operation; black
www.wago.com/890-111
Item no.: 890-101
Locking lever; for manual operation; black
www.wago.com/890-101
Item no.: 890-121
Locking lever; for manual operation; white
www.wago.com/890-121
Item no.: 890-131
Locking lever; for flying leads; for tool operation; white
www.wago.com/890-131
Optional accessories
Shield termination
Shield termination
Item no.: 890-527
Shield connecting plate; 5-pole; for plugs; silver-colored
www.wago.com/890-527
Cover
Other
Hansastr. 27
32423 Minden
13.10.2021 Page 7/11
Item no.: 897-2003
Protective cap; Type2; for sockets and plugs; PVC; red
www.wago.com/897-2003
Tool
Operating tool
Item no.: 210-719
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-719
Downloads
Documentation
Bid Text
890-115
Jun 8, 2015
doc
24.1 kB
Download
Feb 19, 2019
xml
3.1 kB
Download
URL
Download
WSCAD Universe 890-115
URL
Download
ZUKEN Portal 890-115
URL
Download
URL
Download
doc - Datei
890-115
X81 - Datei
CAD/CAE-Data
CAD data
2D/3D Models 890-115
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 890-115
Installation Notes
Conductor termination
Hansastr. 27
32423 Minden
13.10.2021 Page 8/11
1. Strip length, outer insulation = 30 mm (2pole), 37 mm (3-pole), 45 mm (4- and 5-pole)
2. Strip length = 9 mm
3. Extended ground conductor = 8 mm
To terminate fine-stranded conductors,
open the clamping unit via screwdriver – 2.5
mm blade width – and insert a stripped
conductor until it hits the backstop.
Terminate solid conductors by simply
pushing them in.
open clamping units via operating tool (890382) and insert stripped conductors until
they hit backstop.
pushing them in.
open clamping units via operating tool (890383) and insert stripped conductors until
they hit backstop.
pushing them in.
Installation
Hansastr. 27
32423 Minden
13.10.2021 Page 9/11
Latch the wired connector into the base of
the strain relief housing.
Push down strain relief clamp by hand.
Latch the top of the strain relief housing.
The printed marking of the connector is
clearly visible in the openings of the strain
relief housing.
Push down strain relief clamp with 2.5 mm
screwdriver alternately on both sides.
Shield termination
Connector with shield termination
Apply the shield to the sheathed cable.
Push the shield connecting plate into the
connector until fully inserted.
Shield length = 8 mm
Hansastr. 27
32423 Minden
13.10.2021 Page 10/11
First insert the wired connector into strain
relief housing, then snap clamp and cover.
Product family
WINSTA® MINI
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 11/11
很抱歉,暂时无法提供与“890-115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+79.174201+10.21983
