BK13C06-40DS/2-0.35V(895) 数据手册
COUNT
DESCRIPTION OF REVISIONS
CHKD DATE
BY
COUNT
BY
CHKD
DATE
APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
30 V AC/DC
RATING VOLTAGE
Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
STORAGE
TEMPERATURE RANGE
APPLICABLE
CONNECTOR
-55℃ TO +85℃(note1)
-10℃ TO +60℃
BK13C06-40DP/2-0.35V(**)
SIGNAL CONTACT 0.3A
POWER CONTACT 5.0A
CURRENT
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT AT
CONSTRUCTION
GENERAL EXAMINATION
CONFIRMED VISUALLY AND BY MEASURING
INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
X
X
X
X
ELECTRICAL CHARACTERISTICS
CONTACT RESISTANCE
20mV AC OR LESS 1kHz, 1mA
SIGNAL CONTACT : 90mΩ MAX
POWER CONTACT : 30mΩ MAX
X
INSULATION RESISTANCE
100V DC
50MΩ MIN
X
VOLTAGE PROOF
100V AC FOR 1min.
NO FLASHOVER OR BREAKDOWN
X
X
X
X
X
X
X
MECHANICAL CHARACTERISTICS
MECHANICAL
OPERATION
VIBRATION
SHOCK
① CONTACT RESISTANCE:
② NO DAMAGE, CRACK OR LOOSENESS
OF PATRS.
10 TIMES INSERTIONS AND EXTRACTIONS.
FREQUENCY 10 TO 55 TO 10 Hz, APPROX 5min
SINGLE AMPLITUDE 0.75mm, 10CYCLES,
FOR 3 DIRECTIONS.
① NO ELECTRICAL DISCONTINUITY OF 1μs.
OF PARTS.
OF PARTS.
490 m/s² DURATION OF PULSE 11ms AT 3 TIMES
FOR 3 DIRECTIONS.
ENVIRONMENTAL CHARACTERISTICS
RAPID CHANGE OF
TEMPERATURE
DAMP HEAT
(STEADY STATE)
SULPHUR DIOXIDE
TEMPERATURE -55 → +85℃
TIME
30 → 30 min
UNDER 5 CYCLES.
(RELOCATION TIME TO CHAMBER: WITHIN2~3 MIN)
② INSULATION RESISTANCE:
50MΩ MIN
③ NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
25MΩ MIN
OF PARTS.
OF PARTS.
EXPOSED AT 40±2℃, 90 TO 95%, 96h.
EXPOSED IN 25 PPM FOR 96h, 25℃, 75±5%RH.
(Test standard : JIS C 60068)
REMARKS
Note 1 : INCLUDE THE TEMPERATURE RISING BY CURRENT.
DRAWN
DESIGNED
CHECKED
APPROVED
J.M.YEOM
J.M.YEOM
H.W.JO
H.W.JO
RELEASED
ENG
20.09.21
Unless otherwise specified, refer to JIS C 5402 and IEC 60512
Note
QT: QUALIFICATION TEST
AT: ASSURANCE TEST
HIROSE KOREA CO.,LTD.
CODE NO.(OLD)
20.09.21
20.09.21
20.09.21
20.09.21
DEPT
X: APPLICABLE TEST
SPECIFICATION SHEET
DRAWING NO.
ELC4-632785-95
PART NO.
1
CODE NO.
CL 6665-0010-9-895
1
BK13C06-40DS/2-0.35V(895) 价格&库存
很抱歉,暂时无法提供与“BK13C06-40DS/2-0.35V(895)”相匹配的价格&库存,您可以联系我们找货
