TS7809CZ C0G
TS7809CZ C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    IC REG LINEAR 9V 1A TO220
TS7809CZ C0G 数据手册
TS7800 Series Taiwan Semiconductor 3-Terminal Fixed Positive Voltage Regulator FEATURES The TS7800 series voltage regulators are monolithic integrated circuits designed as fixed-voltage regulators for a wide variety of applications including local, on-card regulation. These regulators employ internal current limiting,thermal shutdown, and safe-area compensation. With adequate heatsink they can deliver output currents up to 1 ampere. Although designed primarily as a fixed voltage regulator, these devices can be used with external components to obtain adjustable voltages and currents. ● Output Voltage Range 5V, 8V, 9V, 12V, 24V ● Output current up to 1A ● No external components required ● Internal thermal overload protection ● Internal short-circuit current limiting ● ● ● Output transistor safe-area compensation Output voltage offered in 4% tolerance Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC. Halogen-free according to IEC 61249-2-21 en de d DESCRIPTION ● APPLICATION Power supply ● Home appliance mm ● Pin Definition: 1. Input 2. Ground (tab) 3. Output tR eco TO-220 No TYPICAL APPLICATION CIRCUIT A common ground is required between the input and the output voltages. The input voltage must remain typically 2.0V above the output voltage even during the low point on the Input ripple voltage. XX = these two digits of the type number indicate voltage. * = CIN is required if regulator is located an appreciable distance from power supply filter. ** = COUT is not needed for stability; however, it does improve transient response. 1 Version: G1610 TS7800 Series Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) (Note 1) PARAMETER SYMBOL VOUT=5V, 8V, 9V, 12V Input Voltage VOUT=24V LIMIT UNIT 35 VIN V 40 Output Current IOUT Internal Limited Power Dissipation PD Internal Limited Operating Junction Temperature TJ 0~+125 o -65~+150 o TSTG Thermal Resistance - Junction to Case RӨJC RӨJA 5 50 o C/W C/W de Thermal Resistance - Junction to Ambient C o d Storage Temperature Range C TS7805 ELECTRICAL SPECIFICATIONS o o en Note: Absolute maximum ratings are those values beyond which damage to the device may occur. Functional operation under these conditions is not implied. (VIN=10V, IOUT=500mA, 0 C≤TJ≤125 C, CIN=0.33µF, COUT=0.1µF; unless otherwise specified.) SYMBOL Output voltage VOUT Line Regulation REGLINE Quiescent Current e co Load Regulation CONDITIONS o TJ=25 C 7.5V≤VIN≤20V, 10mA≤IOUT≤1A, PD≤15W 7.5V≤VIN≤25V o TJ=25 C 8V≤VIN≤12V 10mA≤IOUT≤1A o TJ=25 C 250mA≤IOUT≤750mA o IOUT=0, TJ=25 C 7.5V≤VIN≤25V 10mA≤IOUT≤1A o 10Hz≤f≤100KHz, TJ=25 C f=120Hz, 8V≤VIN≤18V o IOUT=1.0A, TJ=25 C f=1KHz o TJ=25 C o TJ=25 C mm PARAMETER IQ ΔIQ tR Quiescent Current Change REGLOAD VN RR VDROP ROUT IOS IO peak No Output Noise Voltage Ripple Rejection Ratio Voltage Drop Output Resistance Output Short Circuit Current Peak Output Current Temperature Coefficient of Output Voltage ΔVOUT/ ΔTJ o o IOUT=10mA, 0 C≤TJ≤125 C MIN 4.80 TYP 5 MAX 5.20 4.75 5 5.25 --------62 ----- 3 1 15 5 4.2 --40 78 2 17 750 2.2 100 50 100 50 8 1.3 0.5 ------- -- -0.6 -- UNIT V mV mA µV dB V mΩ mA A mV/ o C Note: 1. Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible and thermal effects must be taken into account separately. 2. This specification applies only for DC power dissipation permitted by absolute maximum ratings. 2 Version: G1610 TS7800 Series Taiwan Semiconductor TS7808 ELECTRICAL SPECIFICATIONS o o (VIN=14V, IOUT=500mA, 0 C≤TJ≤125 C, CIN=0.33µF, COUT=0.1µF; unless otherwise specified.) VOUT Line Regulation REGLINE Load Regulation REGLOAD Quiescent Current IQ ΔIQ Output Noise Voltage Ripple Rejection Ratio Voltage Drop Output Resistance Output Short Circuit Current Peak Output Current Temperature Coefficient of Output Voltage VN RR VDROP ROUT IOS IO peak mm Quiescent Current Change ΔVOUT/ ΔTJ MIN 7.69 TYP 8 MAX 8.32 7.61 8 8.40 6 2 12 4 ----56 ----- 100 50 100 50 4.3 --52 72 2 16 450 2.2 160 80 160 80 8 1 0.5 ------- o o IOUT=10mA, 0 C≤TJ≤125 C -- -0.8 -- UNIT V mV d Output voltage CONDITIONS o TJ=25 C 10.5V≤VIN≤23V, 10mA≤IOUT≤1A, PD≤15W 10.5V≤VIN≤25V o TJ=25 C 11V≤VIN≤17V 10mA≤IOUT≤1A o TJ=25 C 250mA≤IOUT≤750mA o IOUT=0, TJ=25 C 10.5V≤VIN≤25V 10mA≤IOUT≤1A o 10Hz≤f≤100KHz, TJ=25 C f=120Hz, 11V≤VIN≤21V o IOUT=1.0A, TJ=25 C f=1KHz o TJ=25 C o TJ=25 C de SYMBOL en PARAMETER mA µV dB V mΩ mA A mV/ o C TS7809 ELECTRICAL SPECIFICATIONS o o PARAMETER e co (VIN=15V, IOUT=500mA, 0 C≤TJ≤125 C, CIN=0.33µF, COUT=0.1µF; unless otherwise specified.) SYMBOL CONDITIONS o VOUT TJ=25 C 11.5V≤VIN≤23V, 10mA≤IOUT≤1A, PD≤15W 11.5V≤VIN≤26V o TJ=25 C 12V≤VIN≤17V 10mA≤IOUT≤1A o TJ=25 C 250mA≤IOUT≤750mA o IOUT=0, TJ=25 C 11.5V≤VIN≤26V 10mA≤IOUT≤1A o 10Hz≤f≤100KHz, TJ=25 C f=120Hz, 12V≤VIN≤22V o IOUT=1.0A, TJ=25 C f=1KHz o TJ=25 C o TJ=25 C tR Output voltage REGLINE Load Regulation REGLOAD No Line Regulation Quiescent Current IQ Quiescent Current Change ΔIQ Output Noise Voltage Ripple Rejection Ratio Voltage Drop Output Resistance Output Short Circuit Current Peak Output Current Temperature Coefficient of Output Voltage VN RR VDROP ROUT IOS IO peak ΔVOUT/ ΔTJ o o IOUT=10mA, 0 C≤TJ≤125 C MIN 8.65 TYP 9 MAX 9.36 8.57 9 9.45 6 2 12 4 ----55 ----- 100 50 100 50 4.3 --52 72 2 16 450 2.2 180 90 180 90 8 1 0.5 ------- -- -1 -- UNIT V mV mA µV dB V mΩ mA A mV/ o C Note: 1. Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible and thermal effects must be taken into account separately. 2. This specification applies only for DC power dissipation permitted by absolute maximum ratings. 3 Version: G1610 TS7800 Series Taiwan Semiconductor TS7812 ELECTRICAL SPECIFICATIONS o o (VIN=19V, IOUT=500mA, 0 C≤TJ≤125 C, CIN=0.33µF, COUT=0.1µF; unless otherwise specified.) VOUT Line Regulation REGLINE Load Regulation REGLOAD Quiescent Current IQ ΔIQ Output Noise Voltage Ripple Rejection Ratio Voltage Drop Output Resistance Output Short Circuit Current Peak Output Current Temperature Coefficient of Output Voltage VN RR VDROP ROUT IOS IO peak mm Quiescent Current Change ΔVOUT/ ΔTJ MIN 11.53 TYP 12 MAX 12.48 11.42 12 12.60 10 3 12 4 ----55 ----- 100 50 100 50 4.3 --75 71 2 18 350 2.2 240 120 240 120 8 1 0.5 ------- o o IOUT=10mA, 0 C≤TJ≤125 C -- -1 -- UNIT V mV d Output voltage CONDITIONS o TJ=25 C 14.5V≤VIN≤27V, 10mA≤IOUT≤1A, PD≤15W 14.5V≤VIN≤30V o TJ=25 C 15V≤VIN≤19V 10mA≤IOUT≤1A o TJ=25 C 250mA≤IOUT≤750mA o IOUT=0, TJ=25 C 14.5V≤VIN≤30V 10mA≤IOUT≤1A o 10Hz≤f≤100KHz, TJ=25 C f=120Hz, 15V≤VIN≤25V o IOUT=1.0A, TJ=25 C f=1KHz o TJ=25 C o TJ=25 C de SYMBOL en PARAMETER mA µV dB V mΩ mA A mV/ o C TS7824 ELECTRICAL SPECIFICATIONS o o PARAMETER e co (VIN=33V, IOUT=500mA, 0 C≤TJ≤125 C, CIN=0.33µF, COUT=0.1µF; unless otherwise specified.) SYMBOL CONDITIONS o VOUT TJ=25 C 27V≤VIN≤38V, 10mA≤IOUT≤1A, PD ≤15W 27V≤VIN≤38V o TJ=25 C 28V≤VIN≤32V 10mA≤IOUT≤1A o TJ=25 C 250mA≤IOUT≤750mA o IOUT=0, TJ=25 C 27V≤VIN≤38V 10mA≤IOUT≤1A o 10Hz≤f≤100KHz, TJ=25 C f=120Hz, 27V≤VIN≤37V o IOUT=1.0A, TJ=25 C f=1KHz o TJ=25 C o TJ=25 C tR Output voltage REGLINE Load Regulation REGLOAD No Line Regulation Quiescent Current IQ Quiescent Current Change ΔIQ Output Noise Voltage Ripple Rejection Ratio Voltage Drop Output Resistance Output Short Circuit Current Peak Output Current Temperature Coefficient of Output Voltage VN RR VDROP ROUT IOS IO peak ΔVOUT/ ΔTJ o o IOUT=10mA, 0 C≤TJ≤125 C MIN 23.07 TYP 24 MAX 24.96 22.85 24 25.20 18 6 12 4 ----54 ----- 100 50 100 50 4.6 --170 70 2 28 150 2.2 480 240 480 240 8 1 0.5 ------- -- -1.5 -- UNIT V mV mA µV dB V mΩ mA A mV/ o C Note: 1. Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible and thermal effects must be taken into account separately. 2. This specification applies only for DC power dissipation permitted by absolute maximum ratings. 4 Version: G1610 TS7800 Series Taiwan Semiconductor ORDERING INFORMATION 8V 9V 12V PACKING TS7805CZ C0 TO-220 50pcs / Tube TS7805CZ C0G TO-220 50pcs / Tube TS7808CZ C0 TO-220 50pcs / Tube TS7808CZ C0G TO-220 50pcs / Tube TS7809CZ C0 TO-220 50pcs / Tube TS7809CZ C0G TO-220 50pcs / Tube TS7812CZ C0 TO-220 TS7812CZ C0G TO-220 TS7824CZ C0 TO-220 TS7824CZ C0G TO-220 50pcs / Tube 50pcs / Tube 50pcs / Tube 50pcs / Tube No tR e co mm en 24V PACKAGE d 5V PART NO. de OUTPUT VOLTAGE 5 Version: G1610 TS7800 Series Taiwan Semiconductor de d ELECTRICAL CHARACTERICS CURVES (TA=25oC, unless otherwise noted) Figure 2. Ripple Rejection as a Function of Output Voltage e co mm en Figure 1. Peak Output Current as a Function of Input-Output Differential Voltage Figure 4. Output Voltage as a Function of Junction Temperature No tR Figure 3. Ripple Rejection as a Function of Frequency Figure 5. Output Impedance as a Function of Output Voltage Figure 6. Quiescent Current as a Function of Temperature 6 Version: G1610 TS7800 Series Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) MARKING DIAGRAM mm en de d TO-220 No tR e co xx = Output Voltage Code (05=5V, 08=8V, 09=9V, 12=12V, 24=24V) Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code CZ = Package Code for TO-220 7 Version: G1610 TS7800 Series No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8 Version: G1610
TS7809CZ C0G 价格&库存
很抱歉,暂时无法提供与“TS7809CZ C0G”相匹配的价格&库存,您可以联系我们找货
