IS31FL3239-QFLS4-TR
IS31FL3239-QFLS4-TR
    LUMISSIL
    WFQFN32
    IC INDEPENDENT PWM CONTROL LED D
IS31FL3239-QFLS4-TR 数据手册
IS31FL3239 24-CHANNEL LED DRIVER August 2019 GENERAL DESCRIPTION FEATURES The IS31FL3239 is an LED driver with 24 constant current channels. Each channel can be pulse width modulated (PWM) by 16 bits for smooth LED brightness control. In addition, each channel has an 8-bit output current control register which allows fine tuning the current for rich RGB color mixing, e.g., a pure white color LED application. The maximum output current of each channel is 38mA, which can be adjusted by one 8-bit global control register.   Proprietary programmable technology is used to minimize audible noise caused by MLCC decoupling capacitors. All registers can be programmed via a high speed I2C (1MHz). The IS31FL3239 can be shut down with minimum current consumption by either pulling the SDB pin low or by using the software shutdown feature. The IS31FL3239 is available in QFN-32 (4mm×4mm) package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +125°C.         2.7V to 5.5V VCC supply 1MHz I2C interface, automatic address increment function with readout function Four selectable I2C addresses Accurate Color Rendition - Selectable 16-bit PWM 256/1024/4096/65536 - 8-bit Dot correction - 8-bit Global current adjust Open/short detect function 62kHz PWM frequency (8-bit PWM) Temperature detect function EMI Reduction Technology - Spread spectrum - Selectable 6 phase delay - 180 degree phase delay -40°C to +125°C temperature range QFN-32 (4mm×4mm) package APPLICATIONS    AI-speakers and smart home devices LED in home appliances LED display for hand-held devices TYPICAL APPLICATION CIRCUIT Figure 1 Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 Typical Application Circuit 1 IS31FL3239 Figure 2 Typical Application Circuit (VCC=5V) Note 1: VLED+ should be same as VCC voltage. Note 2: VIH is the high level voltage for IS31FL3239, which is usually same as VCC of Micro Controller, e.g. if VCC of Micro Controller is 3.3V, VIH=3.3V. If VCC=5V and VIH is lower than 2.8V, recommend to add a level shift circuit. Note 3: These resistors are optional to help reduce the power of IS31FL3239 only (values are for VLED+=5V). Note 4: The output current is set up to 23mA when RISET = 3.3kΩ. The maximum global output current can be set by external resistor, RISET. Please refer to the detail application information in RISET section. Note 5: The IC should be placed far away from the antenna in order to prevent the EMI. Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 2 IS31FL3239 PIN CONFIGURATION Package Pin Configuration (Top View) QFN-32 PIN DESCRIPTION No. Pin Description 1~12 OUT1 ~ OUT12 Output channel 1~12 for LEDs. 13,29 GND Ground. 14~25 OUT13 ~ OUT24 Output channel 13~24 for LEDs. 26 SDB Shutdown the chip when pulled low. 27 AD I2C address setting. 28 VCC Power supply. 30 ISET Input terminal used to connect an external resistor. This regulates the global output current. When RISET=3.3kΩ, IOUT=23mA. 31 SDA I2C serial data. 32 SCL I2C serial clock. Thermal Pad Need to connect to GND. Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 3 IS31FL3239 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31FL3239-QFLS4-TR QFN-32, Lead-free 2500 Copyright  ©  2019  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 4 IS31FL3239 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at SCL, SDA, SDB, OUT1 to OUT24 Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~ +150°C -40°C ~ +125°C 51.5°C/W ±8kV ±750V Note 6: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS Typical values are TA = 25°C, VCC = 5V. Symbol VCC Parameter Condition Supply voltage VCC= 5V, VOUT= 0.8V, RISET= 2kΩ, GCC= 0xFF, Scaling= 0xFF (Note 7) Output current VCC= 5V, VOUT= 0.6V, RISET= 3.3kΩ, GCC= 0xFF, Scaling= 0xFF ∆IMAT Channel mismatch RISET= 3.3kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA VHR Headroom voltage RISET= 3.3kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA ICC ISD Quiescent power supply current Shutdown current Typ. 2.7 Maximum output current IOUT Min. Max. Unit 5.5 V 38 21.39 23 mA 24.61 mA 7 % 0.3 0.5 V RISET= 3.3kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA,PWM= 0x00, VCC=3.6V 4.7 7 mA RISET= 3.3kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA,PWM= 0x00, VCC=5V 5.7 8 mA RISET= 3.3kΩ, VSDB= 0V or software shutdown, VCC= 3.6V 0.8 1.6 μA RISET= 3.3kΩ, VSDB= 0V or software shutdown, VCC= 5V 1.8 3 μA -7 fOUT PWM frequency of output OSC= 8MHz, PWM Resolution= 8bit 31.5 kHz TSD Thermal shutdown (Note 8) 165 °C Thermal shutdown hysteresis (Note 8) 20 °C TSD_HY Logic Electrical Characteristics (SDA, SCL, SDB, AD) VIL Logic “0” input voltage VCC= 2.7V~5.5V VIH Logic “1” input voltage VCC= 2.7V~5.5V IIL Logic “0” input current VINPUT= 0V (Note 8) 5 nA IIH Logic “1” input current VINPUT= VCC (Note 8) 5 nA Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 0.4 1.4 V V 5 IS31FL3239 DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 8) Symbol Parameter fSCL Serial-clock frequency tBUF Bus free time between a STOP and a START condition Fast Mode Min. Typ. Fast Mode Plus Max. Min. Typ. Max. Units - 400 - 1000 kHz 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 7: The recommended minimum value of RISET is 2kΩ. Note 8: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 6 IS31FL3239 FUNCTIONAL BLOCK DIAGRAM VCC PWM Control SDA SCL Output Driver I2C Interface OUT1~OUT24 Register Bias AD ISET 6 Group CNT Bandgap MUX SD_Chip SDB OSC Spread Spectrum GND Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 7 IS31FL3239 DETAILED DESCRIPTION Then the master sends an SCL pulse. If the IS31FL3239 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. I2C INTERFACE The IS31FL3239 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3239 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the AD pin. The complete slave address is: Following acknowledge of IS31FL3239, the register address byte is sent, most significant bit first. IS31FL3239 must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3239 must generate another acknowledge to indicate that the data was received. Table 1 Slave Address Bit A7:A3 A2:A1 Value 01101 AD AD connected to GND, AD = 00; AD connected to VCC, AD = 11; AD connected to SCL, AD = 01; AD connected to SDA, AD = 10; A0 0/1 The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. ADDRESS AUTO INCREMENT The SCL line is uni-directional. The SDA line is bi-directional (open-collector) with a pull-up resistor (typically 2kΩ). The maximum clock frequency specified by the I2C standard is 1MHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3239. To write multiple bytes of data into IS31FL3239, load the address of the data register that the first data byte is intended for. During the IS31FL3239 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3239 will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3239 (Figure 6). The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. READING OPERATION The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. Most of the registers can be read. To read the register, after I2C start condition, the bus master must send the IS31FL3239 device address ____ The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. with the R/W bit set to “0”, followed by the register address which determines which register is accessed. Then restart I2C, the bus master should send the After the last bit of the chip address is sent, the master checks for the IS31FL3239’s acknowledge. The master releases the SDA line high (through a pull-up resistor). IS31FL3239 device address with the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31FL3239 to the master (Figure 7). Figure 3 Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 ____ Interface Timing 8 IS31FL3239 Figure 4 Figure 5 Figure 6 Bit Transfer Writing to IS31FL3239 (Typical) Writing to IS31FL3239 (Automatic Address Increment) Figure 7 Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 Reading from IS31FL3239 9 IS31FL3239 REGISTER DEFINITIONS Table 2 Register Function Address Name 00h Function Control Register R/W Table Default Power control register R/W 3 Channel [24:1] PWM register byte R/W 5 Update Register Update the PWM and Scaling data W - LED Scaling Register Control each channel’s DC current R/W 7 6Eh Global Current Control Register Control Global DC current/SSD R/W 8 70h Phase Delay and Clock Phase Register Phase Delay and Clock Phase R/W 9 71h Open Short Detect Enable Register Open short detect enable R/W 10 LED Open/Short Register Open short information R/W 11 77h Temperature Sensor Register Temperature information R/W 12 78h Spread Spectrum Register Spread spectrum control register R/W 13 7Fh Reset Register Reset all registers W - 05h~0Ch 11h~18h 1Dh~2Ch PWM Register 31h~38h 3Dh~44h 49h 4Ch~4Fh 52h~55h 58h~5Fh 62h~65h 68h~6Bh 72h~76h Table 3 00h Control Register Bit D7 D6:D4 D3 D2:D1 D0 Name - OSC - PMS SSD Default 0 000 0 00 0 The Control Register sets software shutdown mode, internal oscillator clock frequency and PWM resolution. The internal oscillator clock frequency and the PWM resolution will decide the output PWM frequency. Recommend selecting PWM frequency lower than 500Hz or higher than 20kHz to avoid MLCC audible noise as shown in Table 4. SSD 0 1 Software Shutdown Enable Software shutdown mode Normal operation OSC 000 001 010 011 100 101 110 111 Oscillator Clock Frequency Selection 16MHz 8MHz 1MHz 500kHz 250kHz 125MHz 62kHz 31kHz Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 PMS 00 01 10 11 0000 0000 PWM Resolution 8-bit 10-bit 12-bit 16-bit Table 4 PWM Frequency PWM 16M Resolution 8M 1M 500k 250k 125k 62k 31k 8-bit 62k 32k 4k 2k 1k 0.5k 244 122 10-bit 16k 8k 1k 0.5k 244 122 NA NA 12-bit 4k 2k 244 122 NA NA NA NA 16-bit 244 122 NA NA NA NA NA NA Table 5 05h~0Ch,11h~18h,1Dh~2Ch,31h~38h,3Dh~44h PWM Register (OUT1~OUT24) Reg 05h, 07h, 09h… 06h, 08h, 0Ah… Bit D7:D0 D7:D0 Name PWM_H PWM_L Default 0000 0000 0000 0000 Each output has 2 bytes to modulate the PWM duty in 256/1024/4096/65536 steps. If using 8 bit PWM resolution, only PWM_L bits need to be set. 10 IS31FL3239 The value of the SL (Scaling Register) decides the peak current of each LED noted IOUT. IOUT and the value of the PWM Registers decide the average current of each LED noted ILED. IOUT is computed by Formula (1): I OUT  I OUT ( MAX )  GCC SL  256 256 Table 6 PWM and Scaling Register Map PWM OUT PWM_H PWM_L 1 06h 05h 4Ch 2 08h 07h 4Dh 3 0Ah 09h 4Eh 4 0Ch 0Bh 4Fh 5 12h 11h 52h 6 14h 13h 53h 7 16h 15h 54h 8 18h 17h 55h 9 1Eh 1Dh 58h 10 20h 1Fh 59h 11 22h 21h 5Ah 12 24h 23h 5Bh 13 26h 25h 5Ch 14 28h 27h 5Dh 15 2Ah 29h 5Eh 16 2Ch 2Bh 5Fh 17 32h 31h 62h 18 34h 33h 63h 19 36h 35h 64h 20 38h 37h 65h 21 3Eh 3Dh 68h 22 40h 3Fh 69h 23 42h 41h 6Ah 24 44h 43h 6Bh (1) ILED computed by Formula (2): I LED PWM   I OUT N PWM  (2) 15  D[ n ]  2 n (3) n0 Where IOUT(MAX) is the maximum output current decided by RISET (Check RISET section for more information), GCC is the global current setting (6Eh), and SL is the scaling of each output (4Ch~4Fh, 52h~55h, 58h~5Fh, 62h~65h, 68h~6Bh), N=256/1024/4096/65536(8/10/12/16 bit PWM resolution). For example: RISET=3.3kΩ, GCC=0xFF, SL=0xFF, PMS=“11” (16-bit PWM resolution), PWM_H=0xFF, PWM_L=0xFF, IOUT(MAX) = 23.18mA I OUT  I OUT ( MAX )  PWM  255 255   23 mA (1) 256 256 15  D[ n ]  2 n  65535 (3) n0 N= 65536 I LED  65535  23 mA  23 mA 65536 (2) Where IOUT(MAX) is the maximum output current decided by RISET (Check RISET section for more information) The IOUT of each channel is setting by the SL bits of LED Scaling Register (4Ch~4Fh, 52h~55h, 58h~5Fh, 62h~65h, 68h~6Bh). Please refer to the detail information in Table 7. If RISET=3.3kΩ, GCC=0xFF, SL=0xFF, PMS= “00” (8-bit PWM resolution, only use the PWM_L, the PWM_H will be ignored), PWM_H=0x77, PWM_L=0xAA, IOUT(MAX) = 23.18mA I OUT 255 255  I OUT ( MAX )    23 mA (1) 256 256 PWM  8  D[ n ]  2 n  170 (3) n0 N= 256 I LED  170  23 mA 256 (2) Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 SL 49h Update Register When SDB= “H” and SSD= “1”, a write of “0000 0000” to 49h to update PWM registers (05h~0Ch, 11h~18h, 1Dh~2Ch, 31h~38h, 3Dh~44h). Table 7 4Ch~4Fh, 52h~55h, 58h~5Fh, 62h~65h, 68h~6Bh LED Scaling Register (OUT1~OUT24) Bit D7:D0 Name SL Default 0000 0000 Each output has 8 bits to modulate DC current in 256 steps. The value of the SL Registers decides the DC peak current of each LED noted IOUT. IOUT is computed by Formula (1): 11 IS31FL3239 I OUT  I OUT ( MAX )  SL  GCC SL  256 256 OSDE 00 01 10 11 (1) 7  D[ n ]  2 n (4) n0 Where IOUT(MAX) is the maximum output current decided by RISET. GCC is the global current setting (6Eh) and 4Ch~4Fh, 52h~55h, 58h~5Fh, 62h~65h, 68h~6Bh don’t need to update by 49h, each register will be updated immediately when it is written. Table 8 6Eh Global Current Control Register Bit D7:D0 Name GCC Default 0000 0000 7  D[ n ]  2 n n0 (5) If GCC=0xFF, SL=0xFF, IOUT=IOUT(MAX) If GCC=0x01, SL=0xFF, I OUT  I OUT ( MAX )  1 255  256 256 Table 9 70h Phase Delay and Clock Phase Register D7 Name PDE - Default 0 0 72h D7:D6 D5:D2 D1:D0 Name - OP/ST[4:1] - Default 00 0000 00 72h D7:D6 D5:D4 D3:D0 Name OP/ST[10:9] - OP/ST[8:5] Default 00 00 0000 Table 11-3 74h LED Open/Short Register Bit D7:D6 D5:D0 Name - OP/ST[16:11] Default 00 00 0000 Table 11-4 75h LED Open/Short Register Where IOUT(MAX) is the maximum output current decided by RISET (Check RISET section for more information). Bit Table 11-1 72h LED Open/Short Register Table 11-2 73h LED Open/Short Register GCC and SL control the IOUT as shown in Formula (1). GCC  Open Detect Enable Detect disable Detect disable Short detect enable Open detect enable 72h D7:D6 D5:D4 D3:D0 Name OP/ST[22:21] - OP/ST[20:17] Default 00 00 0000 Table 11-5 76h LED Open/Short Register D4 D3 D2 D1 D0 Bit D7:D3 D2:D0 PS PS PS PS PS PS Name - OP/ST[24:23] 0 0 0 0 0 0 Default 0000 00 00 D6 D5 IS31FL3239 features a 6 phase delay function, when this bit is set, the phase delay function is enabled. PDE 0 1 Phase Delay Enable Phase delay disable Phase delay enable PS 0 1 Phase Select Phase delay 0 Degree Phase delay 180 Degree Open or short status is stored in 72h to 76h. OP[24:1] 0 1 Open Information of OUT24:OUT1 Open not detected Open detected ST[24:1] 0 1 Short Information of OUT24:OUT1 Short not detected Short detected Table 12 77h Temperature Sensor Register Table 10 71h Open Short Detect Enable Register Bit D7:D2 D1:D0 Name - OSDE Default 0000 00 00 OSDE enables the detection with the result stored in 72h~76h, notice either open or short information is saved not both Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 Bit D7:D6 D5 D4 D3:D2 D1:D0 Name TROF - T_Flag - TS Default 00 0 0 00 00 TS stores the temperature/thermal roll-off point. TROF stores percentage of output current of the thermal rool-off function. Read T_Flag=1 indicates die temperature exceeds the setting point (TS). Before each reading of 77h register, TROF and TS need to be re-written. 12 IS31FL3239 TROF 00 01 10 11 Thermal roll off percentage of output current 100% 75% 55% 30% 00 01 10 11 Temperature Point, Thermal roll off start point 140°C 120°C 100°C 90°C T_Flag 0 1 Temperature Flag Temperature point not exceeded Temperature point exceeded TS Table 13 78h Spread Spectrum Register Bit D7:D5 D4 D3:D2 D1:D0 Name DCPWM SSP RNG CLT Default 000 0 00 00 When DCPWM is set to “0”, the PWM outputs are decided by PWM Register (05h~0Ch,11h~18h,1Dh~2Ch,31h~38h,3Dh~44h), and the PWM range is 0/256~255/256, still the 1/256 can’t be turned on. When the DCPWM is set to “1”, no matter what the values in PWM Registers are, the output will be turned on 256/256, the output will open totally. Spread spectrum register configures the spread spectrum function, adjust the cycle time and range. Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 DCPWM xx0 xx1 x0x x1x 0xx 1xx Setting the output to work in DC mode Output 1~8 PWM data set by registers 05h~0Ch,11h~18h Output 1~8 set to 256/256 turn on (PWM=256) Output 9~16 PWM data set by registers 1Dh~2Ch Output 9~16 set to 256/256 turn on (PWM=256) Output 17~24 PWM data set by registers 31h~38h,3Dh~44h Output 17~24 set to 256/256 turn on (PWM=256) SSP 0 1 Spread Spectrum Enable Disable Enable CLT 00 01 10 11 Spread Spectrum Cycle Time 1980μs 1200μs 820μs 660μs RNG 00 01 10 11 Spread Spectrum Range ±5% ±15% ±24% ±34% 7Fh Reset Register A write of “0000 0000” to 7Fh will reset all registers to their default values. 13 IS31FL3239 APPLICATION INFORMATION RISET The maximum output current IOUT(MAX) of OUT1~OUT24 can be adjusted by the external resistor, RISET, as described in Formula (6). I OUT ( MAX )  x  V ISET R ISET (6) x = 58.84, VISET = 1.3V. The recommended minimum value of RISET is 2kΩ. When RISET=3.3kΩ, IOUT(MAX)=23.18mA When RISET=2kΩ, IOUT(MAX)=38.25mA CURRENT SETTING The maximum output current is set by the external register RISET. The current of each output can also be set independently by the SL 8 bits of LED Scaling Register (4Ch~4Fh, 52h~55h, 58h~5Fh, 62h~65h, 68h~6Bh). surges when the OUTx channels turn ON. These current surges will generate an AC ripple on the power supply which cause stress to the decoupling capacitors. When the AC ripple is applied to a monolithic ceramic capacitor chip (MLCC) it will expand and contract causing the PCB to flex and generate audible hum in the range of between 300Hz to 18kHz, To avoid this hum, there are many countermeasures, such as selecting the capacitor type and value which will not cause the PCB to flex and contract. An additional option for avoiding audible hum is to set the IS31FL3239’s output PWM frequency above/below the audible range. The Control Register (00h) can be used to set the switching frequency to 122Hz~62kHz as shown in Table 4, some combine setting of the OSC and PMS bits will get different output PWM frequency, and higher than 20kHz or lower than 500Hz is out of the audible range. OPEN/SHORT DETECT FUNCTION Some applications may require the IOUT of each channel need to be adjusted independently. For example, if OUT1 drives 1 LED and OUT2 drives 2 parallel LEDs, and they should have the same average current like 18mA, we can set the IOUT(Max) to 36mA, and GCC=0xFF, 4Ch=0x80, 4Dh=0xFF, the OUT1 sinks about 18mA and OUT2 sinks 36mA which can have two LEDs in parallel. IS31FL3239 has open and short detect bit for each LED. Another example, OUT1, OUT2 and OUT3 drive an RGB LED, OUT1 is Red LED, OUT2 is Green LED and OUT 3 is Blue LED, with same RISET, GCC and same SL bits, when OUT1 OUT2 and OUT3 have the same PWM value, the LED may looks a litter pink, or not so white, in this case, the SL bits can be used to adjust the single IOUTx of some output and make it pure white color. We call this SL bits another name: white balance registers. The Global Current Control Register (6Eh) needs to set to 0x01 in order to get the right open/short data. PWM CONTROL The PWM Registers (05h~0Ch, 11h~18h, 1Dh~2Ch, 31h~38h, 3Dh~44h) can modulate LED brightness of each 24 channels with 256/1024/4096/65536 steps. For example, if the data in PWM_H register is “0000 0000” and in PWM_L register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. PWM FREQUENCY SELECT The IS31FL3239 output channels operate with a default 8 bit PWM resolution and the PWM frequency of 62kHz (the oscillator frequency is 16MHz). Because all the OUTx channels are synchronized, the DC power supply will experience large instantaneous current Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 By setting the OSDE bit of Open Short Detect Enable Register (71h) from “00” to “10” (store short information) or “11” (store open information), the LED Open/Short Register will store the open/short information immediately the MCU can get the open/short information by reading the 72h~76h. SPREAD SPECTRUM FUNCTION PWM current switching of LED outputs can be particularly troublesome when the EMI is concerned. To optimize the EMI performance, the IS31FL3239 includes a spread spectrum function. By setting the RNG bit of Spread Spectrum Register (78h), Spread Spectrum range can be choose from ±5% /±15% /±24% /±34%. The spread spectrum can spread the total electromagnetic emitting energy into a wider range that significantly degrades the peak energy of EMI. With spread spectrum, the EMI test can be passed with smaller size and lower cost filter circuit. OPERATING MODE IS31FL3239 can only operate in PWM Mode. The brightness of each LED can be modulated with 256/1024/4096/65536 steps by PWM registers. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. 14 IS31FL3239 SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting the SSD bit of the Control Register (00h) to “0”, the IS31FL3239 will operate in software shutdown mode. When the IS31FL3239 is in software shutdown, all current sources are switched off, so the LEDs are OFF but all registers accessible. Typical current consume is 0.8μA (VCC=3.6V). Hardware Shutdown The chip enters hardware shutdown when the SDB pin is pulled low. All analog circuits are disabled during hardware shutdown, typical the current consumption is 0.8μA (VCC=3.6V). The chip releases hardware shutdown when the SDB pin is pulled high. The rising edge of SDB pin will reset the I2C module, but the register information retains. During hardware shutdown the registers are accessible. If the VCC supply drops below 1.75V but remains above 0.1V during SDB pulled low, please re-initialize all Function Registers before SDB pulled high. LAYOUT The IS31FL3239 consumes lots of power so good PCB layout will help improve the reliability of the chip. Please consider below factors when layout the PCB. Power Supply Lines When designing the PCB layout pattern, the first step should consider about the supply line and GND Lumissil Microsystems – www.lumissil.com Rev. A, 07/29/2019 connection, especially those traces with high current, also the digital and analog blocks’ supply line and GND should be separated to avoid the noise from digital block affect the analog block. At least one 0.1μF capacitor, if possible with a 1μF capacitor is recommended to connected to the ground at power supply pin of the chip, and it needs to close to the chip and the ground net of the capacitor should be well connected to the GND plane. RISET RISET should be close to the chip and the ground side should well connect to the GND plane. Thermal Consideration The over temperature of the chip may result in deterioration of the properties of the chip. The thermal pad of IS31FL3239 should connect to GND net and need to use 9 or 16 vias connect to GND copper area, the GND area should be as large area as possible to help radiate the heat from the IS31FL3239. Current Rating Example For a RISET=3.3kΩ application, the current rating for each net is as follows: • VCC pin maximum current is 8mA when VCC=5V, but the VLED+ net is provide total current of all outputs, its current can as much as 23mA×24=552mA, recommend trace width for VCC pin: 0.20mm~0.3mm, recommend trace width for VLED+ net: 0.30mm~0.5mm • Output pins=23mA, recommend trace width is 0.2mm~0.254mm • All other pins
IS31FL3239-QFLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3239-QFLS4-TR”相匹配的价格&库存,您可以联系我们找货
IS31FL3239-QFLS4-TR
  • 2500+7.594412500+0.98038
  • 5000+7.426575000+0.95871
  • 7500+7.342527500+0.94786
库存:2420
IS31FL3239-QFLS4-TR
  • 1+15.158451+1.95683
  • 10+11.1162010+1.43501
  • 25+10.1030825+1.30423
  • 100+8.98858100+1.16035
  • 250+8.45714250+1.09175
  • 500+8.13679500+1.05039
  • 1000+8.092891000+1.04473
库存:2420
