SLG59M1495V
SLG59M1495V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN4
    IC PWR SWITCH N-CHAN 1:1 4STDFN
SLG59M1495V 数据手册
SLG59M1495V Ultra-small 80 mΩ, 1.0 A Load Switch with Discharge  General Description Pin Configuration ON 1 The product is packaged in an ultra-small 1.0 x 1.0 mm package. D 2 SLG59M1495V The SLG59M1495V is designed for load switching applications. The part comes with one 80 mΩ 1.0 A rated MOSFET controlled by a single ON control pin. The MOSFET’s ramp rate is adjustable depending on the input current level of the ON pin. 4 GND 3 S Features • • • • • • • 4-pin STDFN (Top View) One 80 mΩ 1.0 A MOSFET One integrated VGS Charge Pump User selectable ramp rate with external resistor Integrated Discharge Resistor Over Temperature Protection Pb-Free / Halogen-Free / RoHS compliant STDFN 4L, 1.0 x 1.0 x 0.55 mm Block Diagram S D 1.0 A Charge Pump Out Current Detect Slew Rate Control ON ©2022 Renesas Electronics Corporation 000-0059M1495-104 CMOS Input Rev 1.04 Revised February 4, 2022 SLG59M1495V  Pin Description Pin # Pin Name Type Pin Description 1 ON Input Turns on MOSFET. Configurable slew rate control depending on input current. 2 D MOSFET Drain of Power MOSFET 3 S MOSFET Source of Power MOSFET 4 GND GND Ground Ordering Information Part Number Type Production Flow SLG59M1495V STDFN 4L Extended Commercial, -20 °C to 70 °C SLG59M1495VTR STDFN 4L (Tape and Reel) Extended Commercial, -20 °C to 70 °C Application Diagram Current Controls Ramp Rate ON 3.3 V R1 SLG59M1495V Control IC D GND S Adjustable Ramp Rate vs. ON Pin Current (5.5 V, 25 °C) I_ON TSLEW (typ) 20 µA 0.56 V/ms 50 µA 1.34 V/ms 100 µA 2.53 V/ms 150 µA 3.71 V/ms 200 µA 4.68 V/ms 250 µA 5.63 V/ms Adjustable Slew Rate (ON Pin 2) SLG59M1495V has a built in configurable slew control feature. The configurable slew control uses current detection method on Pin 2. When ON voltage rise above ON_VIH_INI (1.2 V typical), the slew control circuit will measure the current flowing into Pin 2. Based on the current flowing into pin 2, different slew rates will be selected by the internal control circuit. See I_ON vs. Tslew table on page 2. The slew rate is configurable by selecting a different R1 resistor value as shown on application diagram on page 2. Calculating the R1 value depends on both the desired slew rate, and the VOH level of the device driving the ON Pin 2. ON_Current = (GPIO_VOH – ON_VREF (1.05 V typical)) / R1 000-0059M1495-104 Page 2 of 9 SLG59M1495V  Absolute Maximum Ratings Parameter Description VD Power Supply TS Storage Temperature ESDHBM ESDM Conditions Min. Typ. Max. Unit -- -- 6 V -65 -- 150 °C ESD Protection Human Body Model 2000 -- -- V ESD Protection Machine Model 400 -- -- V MSL Moisture Sensitivity Level WDIS Package Power Dissipation 1 MOSFET IDSPK Peak Current from Drain to Source For no more than 1 ms with 1% duty cycle -- -- 0.5 W -- -- 1.5 A Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -20 to 70 °C (unless otherwise stated) Parameter VD IDD RDSON IDS TDelay_ON Description Conditions Min. Typ. Max. Power Supply Voltage -20 to 70°C 2.5 -- 5.5 V when OFF -- 0.1 1 µA Power Supply Current (PIN 2) Static Drain to Source ON Resistance when ON, No load -- 18 30 µA TA 25°C MOSFET -- 80 100 mΩ TA 70°C MOSFET -- 100 110 mΩ Operating Current VD = 2.5 V to 5.5 V -- -- 1.0 A ON pin Delay Time 50% ON to Ramp Begin Input Current (PIN 1) = 20 µA, VD = 5 V, Source_Cap = 10 µF, RL = 20 Ω 0 2.4 4.0 ms Configurable 1 50% ON to 90% VS TTotal_ON Total Turn On Time Example: Input Current (PIN 1) = 20 µA, VD = 5 V, Source_Cap = 10 µF, RL = 20 Ω -- RDIS ON_VREF ON_VIH_INI ON_VIL ON_R Slew Rate Example: Input Current (PIN 1) = 20 µA, VD = 5 V, Source_Cap = 10 µF, RL = 20 Ω 11.7 ms -- Configurable 1 10% VS to 90% VS TSLEWRATE Unit -- 0.56 ms V/ms -- V/ms Discharge Resistance 100 150 300 Ω ON Pin Reference Voltage2 0.99 1.05 1.10 V Initial Turn On Voltage Internal Charge Pump ON 1.2 -- VDD V Low Input Voltage on ON pin Internal Charge Pump OFF -0.3 0 0.3 V 100 -- -- MΩ THERMON Thermal shutoff turn-on temperature Input Impedance on ON pin -- 120 -- °C THERMOFF Thermal shutoff turn-off temperature -- 100 -- °C THERMTIME Thermal shutoff time TDelay_OFF TFALL -- -- 1 ms OFF Delay Time 50% ON to VS Fall, VD = 5 V, RL = 20 Ω, no CL -- 6.5 20 µs VS Fall Time 90% VS to 10% VS, VD = 5 V, RL = 20 Ω, no CL -- 1.2 2 µs Notes: 1. Refer to table for configuration details. 2. Voltage before ON pin resistor needs to be higher than 1.2 V to generate required ION 000-0059M1495-104 Page 3 of 9 SLG59M1495V  Slew Rate vs. ON Current Slew Rate (V/ms) Vs. ON Current, T = 25C 10%VS to 90%VS, RL = 20 ohm, CL = 10uF 7.00 6.00 5.00 VD = 2.5V V/ms 4.00 VD = 3.3V 3.00 VD = 5V VD = 5.25V 2.00 VD = 5.5V 1.00 0.00 0 50 100 150 200 250 ON Current (uA) TTotal_ON vs. On Current Ttotal_on vs ON Current. 50%ON to 90%VS, T = 25C, RL = 20 ohm, CL = 10uF 14.00 12.00 Ttota al_on (ms) 10.00 VD = 2.5V 8.00 VD = 3.3V 6.00 VD = 5V VD = 5.25V 4.00 VD = 5.5V 2.00 0.00 0 50 100 150 200 250 ON Current (uA) 000-0059M1495-104 Page 4 of 9 SLG59M1495V  TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TOFF_DELAY 90% VS VS 90% VS TON_DELAY 10% VS 10% VS Slew Rate (V/ms) TFALL TTotal_ON SLG59M1495V Layout Suggestion Note: All dimensions shown in micrometers (µm) 000-0059M1495-104 Page 5 of 9 SLG59M1495V  Package Top Marking System Definition NN Pin 1 Identifier + Serial Number Line 1 Serial Number Line 2 NN -Part Serial Number Field Line 1 where each “N” character can be A-Z and 0-9 + - Part Serial Number Field Line 2 where “+” character can be +, -, =, or blank 000-0059M1495-104 Page 6 of 9 SLG59M1495V  Package Drawing and Dimensions 4 Lead STDFN Package 1.0 x 1.0 mm 000-0059M1495-104 Page 7 of 9 SLG59M1495V  Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 4L Green 4 1.0 x 1.0 x 0.55 8000 8000 178 / 60 200 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 200 400 8 Part Pitch [mm] 2 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 4L Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.16 1.16 0.63 4 2 1.5 1.75 3.5 8 Refer to EIA-481 specification Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.55 mm3 (nominal). More information can be found at www.jedec.org. 000-0059M1495-104 Page 8 of 9 SLG59M1495V  Revision History Date Version 2/4/2022 1.04 Updated Company name and logo Fixed typos 11/20/2017 1.03 Updated Package Marking Definition Updated Layout Suggestion 11/30/2015 1.02 Added MSL information 9/9/2015 1.01 Updated Abs Max Ratings with ESD for Machine Model Updated Conditions in Electrical Characteristics Table 000-0059M1495-104 Change Page 9 of 9 IMPORTANT NOTICE AND DISCLAIMER RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. Renesas grants you permission to use these resources only for development of an application that uses Renesas products. Other reproduction or use of these resources is strictly prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property. Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims, damages, costs, losses, or liabilities arising out of your use of these resources. Renesas' products are provided only subject to Renesas' Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources expands or otherwise alters any applicable warranties or warranty disclaimers for these products. (Rev.1.0 Mar 2020) Corporate Headquarters Contact Information TOYOSU FORESIA, 3-2-24 Toyosu, Koto-ku, Tokyo 135-0061, Japan www.renesas.com For further information on a product, technology, the most up-to-date version of a document, or your nearest sales office, please visit: www.renesas.com/contact/ Trademarks Renesas and the Renesas logo are trademarks of Renesas Electronics Corporation. All trademarks and registered trademarks are the property of their respective owners. © 2021 Renesas Electronics Corporation. All rights reserved.
SLG59M1495V 价格&库存
很抱歉,暂时无法提供与“SLG59M1495V”相匹配的价格&库存,您可以联系我们找货
