SLG59M1709V
SLG59M1709V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFQFN16
    IC PWR SWITCH N-CHAN 1:1 16STQFN
SLG59M1709V 数据手册
 SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features General Description Pin Configuration Operating from a 2.5 V to 5.5 V power supply and fully specified over the -40 °C to 85 °C temperature range, the SLG59M1709V is a high-performance 4 mΩ, 4 A single-channel nFET load switch with adjustable inrush current control which is achieved by adjusting the VOUT slew rate with an external capacitor. Using a proprietary MOSFET design, the SLG59M1709V achieves a stable 4 mΩ RDSON across a wide input/supply voltage range. Incorporating two-stage current protection as well as thermal protection, the SLG59M1709V is designed for all 0.8 V to 5.5 V power rail applications. The SLG59M1709V is packaged in a space-efficient, low thermal resistance, RoHS-compliant 1.6 mm x 2.5 mm STQFN package ON 1 NC 2 VIN 3 VIN 4 VIN 5 VIN 6 16 15 SLG59M1709V VDD GND 7 VIN 14 CAP 13 NC 8 12 VOUT 11 VOUT 10 VOUT 9 VOUT VOUT Features • • • • • • Low Typical RDSON nFET: 4 mΩ Maximum Continuous Switch Current: Up to 4 A Supply Voltage: 2.5 V ≤ VDD ≤ 5.5 V Wide Input Voltage Range: 0.8 V ≤ VIN ≤ VDD Capacitor-adjustable Start-up and Inrush Current Control Two-stage Overcurrent Protection: • Fixed threshold, 8 A Active Current Limit • Fixed 0.5 A Short-circuit Current Limit • Operating Temperature: -40 °C to 85 °C • Low θJA, 16-pin 1.6 mm x 2.5 mm STQFN Packaging • Pb-Free / Halogen-Free / RoHS compliant 16-pin FC-STQFN (Top View) Applications • Notebook Power Rail Switching • Tablet Power Rail Switching • Smartphone Power Rail Switching Block Diagram 4 A @ 4 mΩ VOUT VIN CIN CLOAD +2.5 to 5.5 V VDD Charge Pump Linear Ramp Control CAP CSLEW 4 nF Over Current and Over Temperature Protection SW Closed ON CMOS Input SW Open GND Datasheet CFR0011-120-01 Revision 1.02 Page 1 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Pin Description Pin # Pin Name Type Pin Description 1 VDD Power With an internal 1.9 V VDD(UVLO) threshold, VDD supplies the power for the operation of the load switch and internal control circuitry where its range is 2.5 V ≤ VDD ≤ 5.5 V. Bypass the VDD pin to GND with a 0.1 μF (or larger) capacitor 2 NC NC 3-7 VIN MOSFET Drain terminal of Power MOSFET (Pins 3-7 fused together). Connect a 10 µF (or larger) low ESR capacitor from this pin to GND. Capacitors used at VIN should be rated at 10 V or higher. 8-12 VOUT MOSFET Source terminal of Power MOSFET (Pins 8-12 fused together). Connect a low ESR capacitor (up to 500 μF) from this pin to GND. Capacitors used at VOUT should be rated at 10 V or higher. 13 NC NC 14 CAP Input A low-ESR, stable dielectric, ceramic surface-mount capacitor connected from CAP pin to GND sets the VOUT slew rate and overall turn-on time of the SLG59M1709V. For best performance, the range for CSLEW values are 2 nF ≤ CSLEW ≤ 22 nF. Capacitors used at the CAP pin should be rated at 10 V or higher. 15 GND GND Ground 16 ON Input A low-to-high transition on this pin closes the load switch. ON is an asserted-HIGH, level-sensitive CMOS input with ON_VIL < 0.3 V and ON_VIH > 0.85 V. While there is an internal pull down circuit to ground (~4 MΩ), connect this pin to the output of a general-purpose output (GPO) from a microcontroller or other application processor. No Connect No Connect Ordering Information Part Number Type Production Flow SLG59M1709V STQFN 16L Industrial, -40 °C to 85 °C SLG59M1709VTR STQFN 16L (Tape and Reel) Industrial, -40 °C to 85 °C Datasheet CFR0011-120-01 Revision 1.02 Page 2 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Absolute Maximum Ratings Parameter VDD VIN to GND Description Conditions Min. Typ. Max. Unit -- -- 6 V -0.3 -- 6 V -0.3 -- VIN V ON and CAP Pin Voltages to GND -0.3 -- 6 V Storage Temperature -65 -- 150 °C -- V -- V Power Supply Pin to GND Load Switch Input Voltage to GND Load Switch Output Voltage to VOUT to GND GND ON, CAP to GND TS ESDHBM ESDCDM MSL θJA WDIS MOSFET IDSCONT ESD Protection Human Body Model 2000 -- ESD Protection Charged Device Model 500 -- Moisture Sensitivity Level Package Thermal Resistance, Junction-to-Ambient 1 1.6 x 2.5 mm 16L STQFN; Determined using 1 in2, 1.2 oz. copper pads under each VIN and VOUT on FR4 pcb material -- 35 -- °C/W Package Power Dissipation -- -- 1.2 W Continuous Current from VIN to VOUT -- -- 4 A -- -- 6 A MOSFET IDSPK Peak Current from VIN to VOUT Maximum pulsed switch current, pulse width < 1 ms, 1% duty cycle Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA =-40 °C to 85 °C, unless otherwise noted. Parameter VDD VDD(UVLO) IDD RDSON Description Conditions Power Supply Voltage Min. Typ. Max. Unit 2.5 3.3 5.5 V V VDD Undervoltage Lockout Threshold VDD ↑ 1.6 1.9 2.2 VDD ↓ 1.5 1.8 2.2 V Power Supply Current, when OFF VDD = VIN = 5.5 V; ON = 0 -- 1 2 μA Power Supply Current, when ON VDD = VIN = ON = 5.5 V; No Load -- 120 170 μA VDD = VIN = 5 V; TA = 25°C, IDS = 0.1 A -- 4 5.5 mΩ 5 6.8 mΩ ON Resistance VDD = VIN = 5 V; TA = 85°C, IDS = 0.1 A MOSFET IDS Current from VIN to VOUT Continuous -- -- 4 A IFET_OFF MOSFET OFF Leakage Current VDD = VIN = 5.5 V; VOUT = 0 V; ON = 0 V -- -- 2 μA VIN ILIMIT TON_Delay Datasheet CFR0011-120-01 0.8 -- VDD V Active Current Limit, IACL Drain Voltage VOUT > 0.3 V 6 8 10 A Short-circuit Current Limit, ISCL VOUT < 0.3 V -- 0.5 -- A ON Delay Time 50% ON to VOUT Ramp Start VDD = VIN = 5 V; CSLEW = 4 nF; RLOAD = 20 Ω, CLOAD = 10 μF -- 200 -- μs Revision 1.02 Page 3 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Electrical Characteristics (continued) TA =-40 °C to 85 °C, unless otherwise noted. Parameter VOUT(SR) Description Conditions Min. Max. Unit 10% VOUT to 90% VOUT ↑ Set by External CSLEW1 V/ms Example: CSLEW = 4 nF; VDD = VIN = 5 V; RLOAD = 20 Ω, CLOAD = 10 μF VOUT Slew Rate Example: CSLEW = 4 nF; VDD = VIN = 5 V; RLOAD = 20 Ω, CLOAD = 10 μF Total Turn-on Time 2.9 3.5 Set by External CSLEW1 50% ON to 90% VOUT ↑ TTotal_ON 2.5 Typ. V/ms ms 1.4 1.7 2 ms OFF Delay Time 50% ON to VOUT Fall Start; VDD = VIN = 5 V; RLOAD = 20 Ω, no CLOAD -- 8 15 μs Output Load Capacitance CLOAD connected from VOUT to GND -- -- 500 μF 0.85 -- VDD V -0.3 0 0.3 V -- 1.5 -- μA Thermal shutoff turn-on temperature -- 125 -- °C THERMOFF Thermal shutoff turn-off temperature -- 100 -- °C TOFF_Delay CLOAD ON_VIH High Input Voltage on ON pin ON_VIL Low Input Voltage on ON pin ION(LKG) ON Pin Leakage Current THERMON ON = ON_VIH or ON = GND Notes: 1. Refer to typical Timing Parameter vs. CSLEW performance charts for additional information when available. TON_Delay, VOUT(SR), and TTotal_ON Timing Details ON 50% ON 50% ON TOFF_Delay 90% VOUT VOUT 90% VOUT TON_Delay 10% VOUT 10% VOUT VOUT(SR) (V/ms) TFALL TTotal_ON Datasheet CFR0011-120-01 Revision 1.02 Page 4 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Typical Performance Characteristics RDSON vs. VDD and Temperature RDSON vs. VIN and VDD Datasheet CFR0011-120-01 Revision 1.02 Page 5 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features VOUT Slew Rate vs. Temperature, VDD, VIN, and CSLEW TTotal_ON vs. CSLEW, VIN, VDD, and Temperature Datasheet CFR0011-120-01 Revision 1.02 Page 6 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Timing Diagram - Basic Operation including Active Current Limit Protection HIGH VDD 1.9 V LOW Time VIN ON TTotal_ON TRISE HIGH VOUT 90% TON_Delay 10% Abnormal Step Load Current Event IACL IACL Active Current Limit Operation IDS ISCL ISCL Nominal Steady State Operation Resumes ACL Threshold Triggered Datasheet CFR0011-120-01 Revision 1.02 Page 7 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Timing Diagram - Active Current Limit & Thermal Protection Operation HIGH VDD 1.9 V LOW Time VIN Nominal Steady State Operation Resumes ON TTotal_ON TRISE VOUT Active Current Limit Operation Thermal Protection Operation 90% TON_Delay 10% IACL Abnormal Step Load Current Event IACL IDS ISCL ISCL Die temp > THERMON Datasheet CFR0011-120-01 Revision 1.02 Page 8 of 20 Die temp < THERMOFF 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features SLG59M1709V Power-Up/Power-Down Sequence Considerations To ensure glitch-free power-up under all conditions, apply VDD first, followed by VIN after VDD exceeds 1.9 V. Then allow VIN to reach 90% of its max value before toggling the ON pin from Low-to-High. Likewise, power-down in reverse order. If VDD and VIN need to be powered up simultaneously, glitching can be minimized by having a suitable load capacitor. A 10 μF CLOAD will prevent glitches for rise times of VDD and VIN higher than 2 ms. If the ON pin is toggled HIGH before VDD and VIN have reached their steady-state values, the load switch timing parameters may differ from datasheet specifications. The slew rate of output VOUT follows a linear ramp set by a capacitor connected to the CAP pin. A larger capacitor value at the CAP pin produces a slower ramp, reducing inrush current from capacitive loads. SLG59M1709V Current Limiting Operation The SLG59M1709V has two types of current limiting triggered by the output VOUT voltage. 1. Standard Current Limiting Mode (with Thermal Shutdown Protection) When the VOUT voltage > 300 mV, the output current is initially limited to the Active Current Limit (IACL) specification listed in the Electrical Characteristics table. The ACL monitor’s response time is very fast and is triggered within a few microseconds to sudden (transient) changes in load current. When a load current overload is detected, the ACL monitor increases the FET resistance to keep the current from exceeding the load switch’s IACL threshold. During active current-limit operation, VOUT is also reduced by IACL x RDSON(ACL). This observed behavior is illustrated in the timing diagrams on Pages 7 and 8. However, if a load-current overload condition persists where the die temperature rises because of the increased FET resistance, the load switch’s internal Thermal Shutdown Protection circuit can be activated. If the die temperature exceeds the listed THERMON specification, the FET is shut OFF completely, thereby allowing the die to cool. When the die cools to the listed THERMOFF temperature threshold, the FET is allowed to turn back on. This process may repeat as long as the output current overload condition persists. 2. Short Circuit Current Limiting Mode (with Thermal Shutdown Protection) When the VOUT voltage < 300 mV (which is the case with a hard short, such as a solder bridge on the power rail), the load switch’s internal Short-circuit Current Limit (SCL) monitor limits the FET current to approximately 500 mA (the ISCL threshold). While the internal Thermal Shutdown Protection circuit remains enabled and since the ISCL threshold is much lower than the IACL threshold, thermal shutdown protection may become activated only at higher ambient temperatures. SLG59M1709V Start-up Inrush Current Considerations with Capacitive Loads In distributed power applications, the SLG59M1709V is generally implemented on the outboard or downstream side of switching regulator dc/dc converters with internal overcurrent protection. As an adjustable output voltage slew-rate load switch, it is important to understand the start-up operation of the SLG59M1709V with capacitive loads. An equivalent circuit of the SLG59M1709V’s slew-rate control loop with capacitors at its VIN and VOUT pins is shown in Figure 1: Datasheet CFR0011-120-01 Revision 1.02 Page 9 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features SLG59M1709V Start-up Inrush Current Considerations with Capacitive Loads (continued) CSLEW Figure 1. SLG59M1709V’s Equivalent Slew-rate Control Loop Circuit. For a desired VOUT slew-rate (VOUT(SR)), a corresponding CSLEW value is selected. At the VOUT pin and with ON = LOW, the internal FET is OFF, VOUT is initially at 0V, and there is no stored charge on CLOAD. When a low-to-high transition is applied to the IC’s ON pin, an internal current source (I1) is enabled which, in turn, charges the external slew-rate capacitor, CSLEW. The SLG59M1709V’s internal micropower op amp sets the circuit’s VOUT(SR) based on the slew rate of the nodal voltage at its non-inverting pin (the voltage at the CAP pin). As a function of VOUT(SR) and CLOAD, a 1st-order expression for the circuit’s FET current (and inrush current) when a low-to-high transition on the ON pin is applied becomes: Start-up Current IDS or IINRUSH = VOUT(SR) x CLOAD From the expression above and for a given VOUT(SR), CLOAD determines the magnitude of the inrush current; that is, for large values of CLOAD, large inrush currents can result. If the inrush currents are large enough to trigger the overcurrent protection of an upstream dc/dc converter, the system can be shut down. In applications where the desired VOUT(SR) is fast and CLOAD is very large (>200 µF), there is a secondary effect on the observed VOUT(SR) attributed to the SLG59M1709V’s internal short-circuit current limit monitor (its SCL monitor). If the resultant inrush current is larger than the IC’s ISCL threshold, the SCL current monitor limits the inrush current and the current to charge CLOAD until the ISCL OFF threshold is crossed (~0.3V). During the time the SCL monitor’s been activated, the inrush current profile may exhibit an observable reduction in VOUT(SR) as shown in Figure 2 where CSLEW was set to 4nF and 470 µF was chosen for CLOAD. Datasheet CFR0011-120-01 Revision 1.02 Page 10 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features SLG59M1709V Start-up Inrush Current Considerations with Capacitive Loads (continued) Figure 2. A SLG59M1709V with CSLEW set to 4nF and 470µF for CLOAD. CLOAD-to-CSLEW ratio is greater than 33,600. Note that the internal SCL monitor’s been triggered and VOUT(SR) is reduced until VOUT reaches ~0.3V. A closer analysis of the IC’s internal slew-control large-scale yields the following: ISCL I1 = MSR x CLOAD CSLEW where ISCL = IC’s short-circuit current limit threshold, typically 0.5A; MSR = An internal slew-rate multiplier from the IC’s CAP pin to the VOUT pin; I1 = An internal current source to charge the external capacitor (CSLEW). Rearranging the equation to isolate both CLOAD and CSLEW yields the following: CLOAD ISCL = I xM CSLEW 1 SR For the SLG59M1709V device, the right-hand side of the expression is approximately 33,600 after taking into account part-to-part variations because of process, voltage, and temperature. Referring to the configuration of Figure 2’s scope capture, the CLOAD-to-CSLEW ratio is 117,500 (470µF/4nF) where it is evident that the SCL monitor circuit is charging CLOAD shortly after a low-to-high ON transition. If it is desired to avoid a reduction in VOUT(SR), the choices are decreasing CLOAD and/or increasing CSLEW so that the ratio is always less than 33,600 including taking into account external capacitor tolerances for initial accuracy and temperature. As shown in Figure 3, it was chosen to reduce VOUT(SR) by increasing CSLEW to 15nF while keeping CLOAD at 470µF. With this configuration, the ratio of CLOAD to CSLEW is about 31,333 (smaller than 33,600). Upon a low-to-high transition on the ON pin, the VOUT increases smoothly with no evidence of SCL monitor’s interaction. Datasheet CFR0011-120-01 Revision 1.02 Page 11 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features SLG59M1709V Start-up Inrush Current Considerations with Capacitive Loads (continued) Figure 3. A SLG59M1709V with CSLEW set to 15nF and 470µF retained for CLOAD. CLOAD-to-CSLEW ratio is smaller than 33,600. Note smooth VOUT transition. Power Dissipation The junction temperature of the SLG59M1709V depends on different factors such as board layout, ambient temperature, and other environmental factors. The primary contributor to the increase in the junction temperature of the SLG59M1709V is the power dissipation of its power MOSFET. Its power dissipation and the junction temperature in nominal operating mode can be calculated using the following equations: PD = RDSON x IDS2 where: PD = Power dissipation, in Watts (W) RDSON = Power MOSFET ON resistance, in Ohms (Ω) IDS = Output current, in Amps (A) and TJ = PD x θJA + TA where: TJ = Junction temperature, in Celsius degrees (°C) θJA = Package thermal resistance, in Celsius degrees per Watt (°C/W) TA = Ambient temperature, in Celsius degrees (°C) Datasheet CFR0011-120-01 Revision 1.02 Page 12 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Power Dissipation (continued) During active current-limit operation, the SLG59M1709V’s power dissipation can be calculated by taking into account the voltage drop across the load switch (VIN-VOUT) and the magnitude of the output current in active current-limit operation (IACL): PD = (VIN-VOUT) x IACL or PD = (VIN – (RLOAD x IACL)) x IACL where: PD = Power dissipation, in Watts (W) VIN = Input Voltage, in Volts (V) RLOAD = Load Resistance, in Ohms (Ω) IACL = Output limited current, in Amps (A) VOUT = RLOAD x IACL For more information on GreenFET load switch features, please visit our website and see App Note “AN-1068 GreenFET and High Voltage GreenFET Load Switch Basics”. Datasheet CFR0011-120-01 Revision 1.02 Page 13 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Layout Guidelines: 1. The VDD pin needs a 0.1 µF (or larger) external capacitor to smooth pulses from the power supply. Locate this capacitor as close as possible to the SLG59M1709V’s pin 1. 2. Since the VIN and VOUT pins dissipate most of the heat generated during high-load current operation, it is highly recommended to make power traces as short, direct, and wide as possible. A good practice is to make power traces with an absolute minimum widths of 15 mils (0.381 mm) per Ampere. A representative layout, shown in Figure 4, illustrates proper techniques for heat to transfer as efficiently as possible out of the device; 3. To minimize the effects of parasitic trace inductance on normal operation, it is recommended to connect input CIN and output CLOAD low-ESR capacitors as close as possible to the SLG59M1709V's VIN and VOUT pins; 4. The GND pin should be connected to system analog or power ground plane. SLG59M1709V Evaluation Board: А GreenFET Evaluation Board for SLG59M1709V is designed according to the statements above and is illustrated on Figure 4. Please note that evaluation board has D_Sense and S_Sense pads. They cannot carry high currents and dedicated only for RDSON evaluation. Figure 4. SLG59M1709V Evaluation Board. Datasheet CFR0011-120-01 Revision 1.02 Page 14 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V GND GND 1 IOUT 1 GND 1 ON 1 C4 3 .9 nF U1 1 2 3 4 5 6 7 VDD NC VIN VIN VIN VIN VIN ON GND CAP NC VOUT VOUT VOUT VOUT VOUT 1 3 5 7 9 2 4 6 8 10 1 C2 10u 1 1 2 3 4 1 2 3 4 SOURCE 1 2 3 4 DRAIN GND D/VIN GND S_SENSE 1 2 3 4 1 C1 22u D_SENSE CAP/RSET Array 16 15 14 13 12 11 10 9 8 1 VDD 1 2 3 VDD 1 1 FAULT# 1 An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features S/VOUT Figure 5. SLG59M1709V Evaluation Board Connection Circuit. Basic Test Setup and Connections Figure 6. Typical connections for GreenFET Evaluation. EVB Configuration 1. Connect oscilloscope probes to VIN, VOUT, ON, etc.; 2. Turn on Power Supply 1 and set desired VDD from 2.5 V…5.5 V range; 3. Turn on Power Supply 2 and set desired VIN from 0.8 V…VDD range; 4. Toggle the ON signal High or Low to observe SLG59M1709V operation. Datasheet CFR0011-120-01 Revision 1.02 Page 15 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Package Top Marking System Definition Pin 1 Identifier PPPPP WWNNN ARR Part Code Date Code + LOT Code Assembly + Rev. Code PPPPP - Part ID Field WW - Date Code Field1 NNN - Lot Traceability Code Field1 A - Assembly Site Code Field 2 RR - Part Revision Code Field2 Note 1: Each character in code field can be alphanumeric A-Z and 0-9 Note 2: Character in code field can be alphabetic A-Z Datasheet CFR0011-120-01 Revision 1.02 Page 16 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Package Drawing and Dimensions 16 Lead STQFN Package 1.6 mm x 2.5 mm (Fused Lead) Datasheet CFR0011-120-01 Revision 1.02 Page 17 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features SLG59M1709V 16-pin STQFN PCB Landing Pattern Datasheet CFR0011-120-01 Revision 1.02 Page 18 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STQFN 16L 1.6x2.5mm 0.4P FCA Green 1.6x2.5x 0.55mm 16 3000 3000 178/60 100 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 100 400 8 Part Pitch [mm] 4 Carrier Tape Drawing and Dimensions Package Type Pocket BTM Pocket BTM Length Width STQFN 16L 1.6x2.5mm 0.4P FCA Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.8 2.8 0.7 4 4 1.55 1.75 3.5 8 P0 D0 E Y W F Section Y-Y B0 CL K0 Y P1 A0 Refer to EIA-481 specification Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 2.2 mm3 (nominal). More information can be found at www.jedec.org. Datasheet CFR0011-120-01 Revision 1.02 Page 19 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation  SLG59M1709V An Ultra-small, 4 mΩ, 4 A Load Switch with Multiple Protection Features Revision History Date Version 2/4/2022 1.02 Updated Company name and logo Fixed typos 10/19/2018 1.01 Updated style and formatting Added Layout Guidelines Fixed typos 1/30/2017 1.00 Production Release Datasheet CFR0011-120-01 Change Revision 1.02 Page 20 of 20 4-Feb-2022 ©2022 Renesas Electronics Corporation IMPORTANT NOTICE AND DISCLAIMER RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. Renesas grants you permission to use these resources only for development of an application that uses Renesas products. Other reproduction or use of these resources is strictly prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property. Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims, damages, costs, losses, or liabilities arising out of your use of these resources. Renesas' products are provided only subject to Renesas' Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources expands or otherwise alters any applicable warranties or warranty disclaimers for these products. (Rev.1.0 Mar 2020) Corporate Headquarters Contact Information TOYOSU FORESIA, 3-2-24 Toyosu, Koto-ku, Tokyo 135-0061, Japan www.renesas.com For further information on a product, technology, the most up-to-date version of a document, or your nearest sales office, please visit: www.renesas.com/contact/ Trademarks Renesas and the Renesas logo are trademarks of Renesas Electronics Corporation. All trademarks and registered trademarks are the property of their respective owners. © 2021 Renesas Electronics Corporation. All rights reserved.
SLG59M1709V 价格&库存
很抱歉,暂时无法提供与“SLG59M1709V”相匹配的价格&库存,您可以联系我们找货
