SLG59M1568V
SLG59M1568V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN14
    IC PWR SWITCH N-CHAN 1:1 14STDFN
SLG59M1568V 数据手册
SLG59M1568V 7.3 mΩ, 9 A GreenFET Load Switch with Discharge  General Description Pin Configuration The SLG59M1568V is designed for load switching application. The part comes with one 9 A rated MOSFET switched on by an ON control pin. MOSFET turn on time is independently adjusted by an external capacitor. MOS_D 1 14 MOS_D 2 13 MOS_S MOS_S ON_MOS 3 12 CAP 4 11 GND ON_MOS 5 10 CAP MOS_D 6 9 MOS_D 7 8 MOS_S MOS_S Features • • • • • • • • VDD One 9 A independent MOSFET Integrated VGS Charge Pump Internal discharge for gate and source User selectable ramp control by external capacitor Protected by thermal shutdown with current limit Pb-Free / RoHS Compliant Halogen-Free STDFN 14L, 1 x 3 x 0.55 mm 14-pin STDFN (Top View) Target Applications • Consumer Electronics • Portable: Tablets, Notebooks • PCs and PC peripherals • Commercial and Industrial Electronics • Printers • Servers • Embedded PCs • Data Communications Equipment Block Diagram 9 A @ 7.3 mΩ MOS_D +2.5 to 5.5 V CAP MOS_S Charge Pump PIN10 Linear Ramp Control PIN12 Over Current and Over Temperature Protection PIN3 ON/OFF CMOS Input PIN5 ©2022 Renesas Electronics Corporation 000-0059M1568-106 Rev 1.06 Revised February 7, 2022 SLG59M1568V  Pin Description Pin # Pin Name Type Pin Description 1 MOS_D MOSFET Drain of MOSFET 2 MOS_D MOSFET 3 ON_MOS Input 4 VDD Power 5 ON_MOS Input 6 MOS_D MOSFET Drain of MOSFET 7 MOS_D MOSFET Drain of MOSFET 8 MOS_S MOSFET Source of MOSFET 9 MOS_S MOSFET Source of MOSFET 10 CAP Input Sets ramp and turn on time for MOSFET. Tied to Pin 12 on PCB. 11 GND GND Ground 12 CAP Input Sets ramp and turn on time for MOSFET. Tied to Pin 10 on PCB. 13 MOS_S MOSFET Source of MOSFET 14 MOS_S MOSFET Source of MOSFET Drain of MOSFET Turns on MOS (4 MΩ pull down resistor). Tied to Pin 5 on PCB. VDD Power for Load Switch Control Turns on MOS (4 MΩ pull down resistor). Tied to Pin 3 on PCB. Ordering Information Part Number Type Production Flow SLG59M1568V STDFN 14L Industrial, -40 °C to 85 °C SLG59M1568VTR STDFN 14L (Tape and Reel) Industrial, -40 °C to 85 °C 000-0059M1568-106 Page 2 of 10 SLG59M1568V  Absolute Maximum Ratings Parameter VDD TS ESDHBM WDIS IDSMAX Description Conditions Power Supply Storage Temperature ESD Protection Human Body Model Min. Typ. Max. Unit -- -- 6 V -65 -- 150 °C 2000 -- -- V -- -- 1.2 W 9 A 12 A Package Power Dissipation Max Operating Current MOSFET IDSPK Peak Current from Drain to Source For no more than 10 continuous seconds out of every 100 seconds -- -- Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C (unless otherwise stated) Parameter VDD IDD RDSON Description Conditions Power Supply Voltage Power Supply Current when OFF Typ. Max. 2.5 -- 5.5 V -- 0.1 1 µA -- 50 75 µA -- 7.3 9 mΩ TA = 70°C; IDS = 100 mA -- 8 11 mΩ 8.5 11.5 mΩ -- 9 A 1.0 5.0 VDD V -- 300 500 µs TA = 85°C; IDS = 100 mA MOSFET IDS VMOS_D TON_Delay Current from Drain to Source Continuous Drain Voltage ON Delay Time 50% ON to Ramp Begin -- Configurable 1 50% ON to 90% VS TTotal_ON Total Turn On Time Example: CAP (Pin 10 & 12) share a single 4nF capacitor, VDD = VD = 5 V, CLOAD = 10 µF, RLOAD = 20 Ω -- Slew Rate CLOAD Output Load Capacitance 1.1 ms -- ms Configurable 1 10% VS to 90% VS VS(SR) Unit TA = 25°C; IDS = 100 mA Power Supply Current when ON ON Resistance Min. V/ms Example: CAP (Pin 10 & 12) share a single 4nF capacitor, VDD = VD = 5 V, CLOAD = 10 µF, RLOAD = 20 Ω -- 6.0 -- V/ms CLOAD connected from MOS_S to GND -- -- 1000 µF Discharge Resistance 100 210 300 Ω ON_VIH High Input Voltage on ON pin 0.85 -- VDD V ON_VIL Low Input Voltage on ON pin RDIS -0.3 0 0.3 V Active Current Limit MOSFET will automatically limit current when VS > 250 mV -- 12.0 -- A Short Circuit Current Limit MOSFET will automatically limit current when VS < 250 mV -- 0.5 -- A Thermal shutoff turn-on temperature -- 125 -- °C THERMOFF Thermal shutoff turn-off temperature -- 100 -- °C THERMTIME Thermal shutoff time -- -- 1 ms ILIMIT THERMON 000-0059M1568-106 Page 3 of 10 SLG59M1568V  TA = -40 °C to 85 °C (unless otherwise stated) Parameter Description Conditions TOFF_Delay OFF Delay Time 50% ON to VS Fall, VDD = VD = 5 V Min. Typ. Max. Unit -- -- 15 µs Notes: 1. Refer to table for configuration details. TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TOFF_Delay 90% VS VS 90% VS TON_Delay 10% VS 10% VS VS(SR) (V/ms) TFALL TTotal_ON 000-0059M1568-106 Page 4 of 10 SLG59M1568V  Slew Rate vs. CAP, VMOS_D, and VDD TTotal_ON vs. CAP, VMOS_D, and VDD 000-0059M1568-106 Page 5 of 10 SLG59M1568V  Package Top Marking System Definition Part Code Pin 1 Identifier PPDDL Lot # Date Code 000-0059M1568-106 Page 6 of 10 SLG59M1568V  Package Drawing and Dimensions 14 Lead STDFN Package 1 mm x 3 mm (Fused Lead) 000-0059M1568-106 Page 7 of 10 SLG59M1568V  Tape and Reel Specifications Package Type # of Pins Nominal Package Size STDFN 14L 1x3mm 0.4P FC 14 1x3x0.55mm Trailer A Leader B Pocket Tape (mm) Max Reel & Units per Units Hub Size Reel Pockets Length Pockets Length Width Pitch per Box (mm) (mm) (mm) 3000 3000 178/60 100 400 100 400 8 4 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Length Width Package [mm] [mm] Type STDFN 14L 1x3mm 0.4P FC Pocket Depth [mm] Index Hole Pitch [mm] Pocket Pitch [mm] Index Hole Diameter [mm] Index Hole Index Hole to Tape to Pocket Tape Width Edge Center [mm] [mm] [mm] A0 B0 K0 P0 P1 D0 E F W 1.15 3.15 0.7 4 4 1.5 1.75 3.5 8 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 1.65 mm3 (nominal). More information can be found at www.jedec.org. 000-0059M1568-106 Page 8 of 10 SLG59M1568V  Recommended Land Pattern and PCB Layout 000-0059M1568-106 Page 9 of 10 SLG59M1568V  Revision History Date Version 2/7/2022 1.06 Renesas rebranding Fixed typos 4/13/2018 1.05 Fixed typo in Block Diagram Fixed typo in Abs Max Table Clean up EC Table Parameters and Conditions Updated Charts 3/15/2016 1.04 Fixed RDSon values 000-0059M1568-106 Change Page 10 of 10 IMPORTANT NOTICE AND DISCLAIMER RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. Renesas grants you permission to use these resources only for development of an application that uses Renesas products. Other reproduction or use of these resources is strictly prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property. Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims, damages, costs, losses, or liabilities arising out of your use of these resources. Renesas' products are provided only subject to Renesas' Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources expands or otherwise alters any applicable warranties or warranty disclaimers for these products. (Rev.1.0 Mar 2020) Corporate Headquarters Contact Information TOYOSU FORESIA, 3-2-24 Toyosu, Koto-ku, Tokyo 135-0061, Japan www.renesas.com For further information on a product, technology, the most up-to-date version of a document, or your nearest sales office, please visit: www.renesas.com/contact/ Trademarks Renesas and the Renesas logo are trademarks of Renesas Electronics Corporation. All trademarks and registered trademarks are the property of their respective owners. © 2021 Renesas Electronics Corporation. All rights reserved.
SLG59M1568V 价格&库存
很抱歉,暂时无法提供与“SLG59M1568V”相匹配的价格&库存,您可以联系我们找货
