SLG59M1649V
SLG59M1649V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN8
    A 1.6 MM 23 MO/4 A POWER SWITC
SLG59M1649V 数据手册
SLG59M1649V An Ultra-small, Low-power 23 mΩ/4 A P-Channel Integrated Power Switch with Reverse-Current Blocking General Description Pin Configuration VIN 1 ON 2 ON 3 VIN 4 Designed to operate over a -40°C to 85°C range, the SLG59M1649V is available in a RoHS-compliant, ultra-small 1.0 x 1.6 mm STDFN package. Features SLG59M1649V The SLG59M1649V is a self-powered, high-performance, 23 mΩ pFET integrated power switch designed for 1.5 to 5 V power rail applications up to 4 A. When enabled, internal reverse-current protection will quickly open the switch in the event of a reverse-voltage condition is detected (a VOUT+50mV > VIN condition opens the switch). Upon the detection of a reverse condition, an open-drain FAULT output is asserted. In the event the VIN voltage is too low, the power switch also contains an internal UVLO threshold monitor to keep or to turn the switch OFF. 8 VOUT 7 GND 6 FAULT 5 VOUT 8-pin STDFN (Top View) Applications • Steady-state Operating Current: Up to 4 A • Low Typical RDSON: • 23 mΩ at VIN = 5 V • 31 mΩ at VIN = 2.5 V • 42 mΩ at VIN = 1.5 V • Operating Voltage: 1.5 V to 5.5 V • Reverse-voltage Detection ON or OFF • Internal Gate Drive and VOUT Discharge • Open-drain FAULT Signaling • Operating temperature range: -40°C to 85°C • Low θJA, 8-pin 1.0 mm x 1.6 mm STDFN Packaging • Pb-Free / Halogen-Free / RoHS compliant packaging • Power-Rail Switching: • Notebook/Laptop/Tablet PCs • Smartphones/Wireless Handsets • High-definition Digital Cameras • Set-top Boxes • Point of Sales Pins • GPS Navigation Devices Block Diagram ILOAD Reverse Voltage Detection VIN VOUT FAULT Logic Control SW Closed ON Discharge CMOS Input SW Open GND Silego Technology, Inc. 000-0059M1649-100 Rev 1.00 Revised February 23, 2017 SLG59M1649V Pin Description Pin # Pin Name 1, 4 VIN Type Pin Description Power/Input With an internal 1.2V UVLO threshold, VIN supplies the power for the operation of the power switch, the internal control circuitry, and the source terminal of pFET. Bypass the VIN pin to GND with a 2.2 μF (or larger), low-ESR capacitor. A low-to-high transition on this pin initiates the operation of the power switch. ON is an asserted-HIGH, level-sensitive CMOS input with VIL < 0.3 V and VIH > 1 V. As the ON input circuitry does not have an internal pull-down resistor, connect the ON pin directly to a GPIO controller – do not allow this pin to be open circuited. 2, 3 ON Input 5, 8 VOUT Output Output and drain terminal of MOSFET. An open drain output, FAULT is asserted within TFAULTLOW when a (VOUT+VREVERSE > VIN) condition is detected. The FAULT output is deasserted within TFAULTHIGH when the fault condition is removed. Connect an external 10-kΩ resistor from the FAULT pin to the system’s local logic supply. 6 FAULT Output 7 GND GND Ground connection. Connect this pin to system analog or power ground plane. Ordering Information Part Number Type Production Flow SLG59M1649V STDFN Industrial, -40 °C to 85 °C SLG59M1649VTR STDFN (Tape and Reel) Industrial, -40 °C to 85 °C 000-0059M1649-100 Page 2 of 13 SLG59M1649V Absolute Maximum Ratings Parameter Description Conditions Min. Typ. Max. Unit VIN Power Switch Input Voltage -0.3 -- 6 V TS Storage Temperature -65 -- 150 °C ESDHBM ESD Protection Human Body Model 2000 -- -- V ESDCDM ESD Protection Charged Device Model 1000 -- -- V MSL Moisture Sensitivity Level ΘJA Thermal Resistance TJ,MAX Maximum Junction Temperature MOSFET IDSCONT Continuous Current from VIN to VOUT MOSFET IDSPK Peak Current from Drain to Source 1 1.0 x 1.6 mm 8L STDFN -- 82 -- °C/W -- 150 -- °C Each channel, TJ< 150°C -- -- 2 A Maximum pulsed switch current, pulse width < 1 ms, 1% duty cycle -- -- 2.5 A Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics 1.5 V ≤ VIN ≤ 5.5 V; CIN = 2.2 µF, TA =-40 °C to 85 °C, unless otherwise noted. Typical values are at TA = 25°C (unless otherwise stated) Parameter VIN VIN(UVLO) IIN IIN(OFF) RDSON Description Power Switch Input Voltage VIN Undervoltage Lockout Threshold Quiescent Power Switch Current OFF Mode Power Switch Current Static Drain to Source ON Resistance VREVERSE Reverse-current Voltage Threshold IREVERSE Reverse-current Leakage Current after Reverse Current Event VON Conditions VIN ↑, VON = 0V, IOUT = -100 mA Typ. Max. Unit 1.5 -- 5.5 V -- -- 1.2 V 0.5 -- -- V VIN = 5.25V, VON = HIGH, IOUT = 0 mA -- 6.6 11 µA VIN = 1.5 V, VON = HIGH, IOUT = 0 mA -- 5 8 µA VIN = 5.25 V, VON = LOW, RLOAD = 1 MΩ -- 2 3 µA VIN = 1.5 V, VON = LOW, RLOAD = 1 MΩ -- 0.8 2 µA TA = 25°C, VIN = 5.0 V, ILOAD = -200 mA -- 23 28 mΩ TA = 25°C, VIN = 2.5 V, ILOAD = -200 mA -- 31 38 mΩ TA = 25°C, VIN = 1.5 V, ILOAD = -200 mA -- 42 50 mΩ -- 50 -- mV -- 1 -- µA VIN V VIN ↓, VON = 0V, RLOAD = 10Ω VOUT – VIN > VREVERSE; TA = 25°C; ON = GND ON Pin Voltage Range ION(Leakage) ON Pin Leakage Current Min. 0 -- -- 1 µA ON_VIH ON Pin Input High Voltage 1 -- VDD V ON_VIL ON Pin Input Low Voltage -0.3 0 0.3 V ONHYS ON Hysteresis -- 60 -- mV 000-0059M1649-100 1.4 V ≤ VON ≤ VINor VON = GND Page 3 of 13 SLG59M1649V Electrical Characteristics (continued) 1.5 V ≤ VIN ≤ 5.5 V; CIN = 2.2 µF, TA =-40 °C to 85 °C, unless otherwise noted. Typical values are at TA = 25°C (unless otherwise stated) Parameter Min. Typ. Max. Unit VIN = 5 V; VOUT < 0.4 V 50 80 120 Ω VIN = 5 V -- 10 -- µs -- 1.5 -- ms 50% ON to 50% VOUT ↑; TA = 25°C, VIN = 5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 180 235 μs 50% ON to 50% VOUT ↑; TA = 25°C, VIN = 1.5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 110 145 μs 10% to 90% VOUT ↑; TA = 25°C, VIN = 5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 130 170 μs 10% to 90% VOUT ↑; TA = 25°C, VIN = 1.5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 66 86 μs 90% to 10% VOUT ↓; TA = 25°C, VIN = 5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 2.2 3.6 μs 90% to 10% VOUT ↓; TA = 25°C, VIN = 1.5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 2.2 3.6 μs 50% ON to 50% VOUT ↓; TA = 25°C, VIN = 5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 3.5 5 μs 50% ON to 50% VOUT ↓; TA = 25°C, VIN = 1.5 V; RLOAD = 10 Ω, CLOAD = 0.1 µF -- 5 7 μs TFAULTLOW FAULT Assertion Time Reverse-voltage Detection to FAULT↓; 1.5 V ≤ IN ≤ 5 V; ON = Low -- 2 -- μs 1.5 V ≤ VIN ≤ 5 V; ON = High -- 0.5 -- μs TFAULTHIGH FAULT De-assertion Time Delay to FAULT↑ after fault condition is removed; 1.5 V ≤ VIN ≤ 5 V; ON = Low -- 7 -- ms RDSCHRG TREV TREARM TON_Delay TVOUT(R) TVOUT(F) TOFF_Delay FAULTVOL Description Conditions Output Discharge Resistance Reverse-current Detect Response Delay Reverse Detect Rearm Time ON Delay Time VOUT Rise Time VOUT Fall Time OFF Delay Time FAULT Output Low Voltage 000-0059M1649-100 1.5 V ≤ VIN ≤ 5 V; ON = High -- 2 -- ms IFAULT = 1 mA -- -- 0.2 V Page 4 of 13 SLG59M1649V TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TVOUT(R) 90% VOUT VOUT 50% VOUT(R) TON_Delay 10% VOUT 90% VOUT TOFF_Delay 50% VOUT(F) 10% VOUT TVOUT(F) 000-0059M1649-100 Page 5 of 13 SLG59M1649V RDSON vs. VIN and Temperature RDSON vs.Temperature and VIN 000-0059M1649-100 Page 6 of 13 SLG59M1649V VIN Inrush Current Details When the SLG59M1649V is enabled with ON ↑, the power switch closes to charge the VOUT output capacitor to VIN. The charging current drawn from VIN is commonly referred to as “VIN inrush current” and can cause the input power source to collapse if the VIN inrush current is too high. Since the VOUT rise time of the SLG59M1649V is fixed, VIN inrush current is then a function of the output capacitance at VOUT. The expression relating VIN inrush current, the SLG59M1649V VOUT rise time, and CLOAD is: VIN Inrush Current = CLOAD x ∆VOUT VOUT Rise Time where in this expression ∆VOUT is equivalent to VIN if the initial SLG59M1649V’s output voltages are zero. In the table below are examples of VIN inrush currents assuming zero initial charge on CLOAD as a function of VIN. VIN VOUT Rise Time CLOAD Inrush Current 1.5 V 66 μs 0.1 μF 2.3 mA 5V 130 μs 0.1 μF 3.8 mA Since the relationship is linear and if CLOAD were increased to 1 µF, then the VIN inrush currents would be 10x higher in either example. If a large CLOAD capacitor is required in the application and depending upon the strength of the input power source, it may very well be necessary to increase the CIN-to-CLOAD ratio to minimize VIN droop during turn-on. For other VOUT rise time options, please contact Silego for additional information. Power Dissipation The junction temperature of the SLG59M1649V depends on factors such as board layout, ambient temperature, external air flow over the package, load current, and the RDSON-generated voltage drop across each power MOSFET. While the primary contributor to the increase in the junction temperature of the SLG59M1649V is the power dissipation of its power MOSFETs, its power dissipation and the junction temperature in nominal operating mode can be calculated using the following equations: PDTOTAL = RDSON x IDS2 where: PDTOTAL = Total package power dissipation, in Watts (W) RDSON = Power MOSFET ON resistance, in Ohms (Ω) IDS = Output current, in Amps (A) and TJ= PDTOTAL x θJA + TA where: TJ = Die junction temperature, in Celsius degrees (°C) θJA = Package thermal resistance, in Celsius degrees per Watt (°C/W) – highly dependent on pcb layout TA = Ambient temperature, in Celsius degrees (°C) 000-0059M1649-100 Page 7 of 13 SLG59M1649V Power Dissipation (continued) In nominal operating mode, the SLG59M1649V’s power dissipation can also be calculated by taking into account the voltage drop across each switch (VIN-VOUT) and the magnitude of that channel’s output current (IOUT): PDTOTAL = (VIN-VOUT) x IDS or PDTOTAL = (VIN – (RLOAD x IDS)) x IDS where: PDTOTAL = Total package power dissipation, in Watts (W) VIN = Input Voltage, in Volts (V) RLOAD] = Output Load Resistance, in Ohms (Ω) IDS = Output current, in Amps (A) VOUT= Output voltage, or RLOAD x IDS Power Dissipation Derating Curve Maximum Power Dissipation (W) 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 Ambient Temperature °(C) Note: Each VIN, VOUT = 1 in2 1.2 oz. copper on FR4 000-0059M1649-100 Page 8 of 13 SLG59M1649V SLG59M1649V Layout Suggestion Note: All dimensions shown in micrometers (μm) Recommended PCB Layout for external power traces SLG59M1649V VIN VOUT Note: All dimensions shown in μm (micrometers) 000-0059M1649-100 Page 9 of 13 SLG59M1649V Package Top Marking System Definition ABC Serial Number Pin 1 Identifier ABC - 3 alphanumeric Part Serial Number where A, B, or C can be A-Z and 0-9 000-0059M1649-100 Page 10 of 13 SLG59M1649V Package Drawing and Dimensions 8 Lead STDFN Package 1.0 x 1.6 mm 000-0059M1649-100 Page 11 of 13 SLG59M1649V Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 8L 1x1.6mm 0.4P FCD Green 8 1.0 x 1.6 x 0.55 3,000 3,000 178 / 60 100 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 100 400 8 Part Pitch [mm] 4 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 8L 1x1.6mm 0.4P FCD Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.12 1.72 0.7 4 4 1.55 1.75 3.5 8 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.88 mm3 (nominal). More information can be found at www.jedec.org. 000-0059M1649-100 Page 12 of 13 SLG59M1649V Revision History Date Version 2/23/2017 1.00 000-0059M1649-100 Change Production Release Page 13 of 13
SLG59M1649V 价格&库存
很抱歉,暂时无法提供与“SLG59M1649V”相匹配的价格&库存,您可以联系我们找货
