BZD27C Series
Voltage Regulator Diodes
BREAKDOWN VOLTAGE : 7 - 188 VOLTS
PEAK PULSE POWER : 150 WATTS
SOD-123FL
Features
Zener and surge current specification
Low leakage current
Excellent stability
High temperature soldering guaranteed:
Cathode Band
Top View
1.0±0.2
Sillicon planar zener diodes.
Low profile surface-mount package.
1.9± 0.1
1.4± 0.15
0.10-0.30
2.8±0.1
0.6±0.25
265℃/10 seconds, at terminals
Mechanical Data
3.7±0.2
Case: JEDEC SOD-123FL molded plastic
Polarity: Color band denotes positive end
Dimensions in millimeters
( cathode ) except for bidirectional
Marking code: see TABLE 1
Weight: 0.006 ounces, 0.02 grams
Mounting position: Any
ABSOLUTE MAXIMUM RATINGS AND CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified
SYMBOL
VALUE
UNITS
PPPM
150
Watts
Ptot
0.8
Watts
Reverse current at stand-off voltage @ V WM
IR
SEE TABLE 1
µA
Maximum instantaneous forward voltage at 0.2A
VF
1.2
Volts
Thermal resistance junction to ambient
RθJA
180
K/W
Operating temperature junction range
TJ
- 55 to +150
TSTG
- 55 to +150
Non-repetitive peak pulse power dissipation
with a 10/1000µs waveform (NOTE 1)
Power dissipation at T A=25℃ (NOTE 2)
Storage temperature range
NOTES:(1)TJ=25℃ prior to surge.
(2)Mounted on epoxy-glass PCB with 3×3 mm Cu pads(≥40µm thick)
(3)Non-repetitive peak reverse current in accordance with "IEC 60-1,Section 8" (10/1000 µs pulse)
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
BZD27C Series
ELECTRICAL CHARACTERISTICS (at T =25℃ unless otherwise noted)
J
When used as voltage regulator diodes
(NOTE 1)
Differential
resistance
Temperature
coefficient
Vz@IzT
rdif@Iz
αz@Iz
Test
current
IZT
V
Ω
mA
Working voltage
Partnumber
Reverse current at
reverse voltage
IR
VR
µA
V
min
max
typ
max
min
max
max
BZD27C3V6P
3.4
3.8
4
8
-0.14
-0.04
100
100
1
BZD27C3V9P
3.7
4.1
4
8
-0.14
-0.04
100
50
1
BZD27C4V3P
4
4.6
4
7
-0.12
-0.02
100
25
1
BZD27C4V7P
4.4
5
3
7
-0.1
10
1
BZD27C5V1P
4.8
5.4
3
6
-0.08
0.02
100
5
1
BZD27C5V6P
5.2
6
2
4
-0.04
0.04
100
10
2
BZD27C6V2P
5.8
6.6
2
3
-0.01
0.06
100
5
2
BZD27C6V8P
6.4
7.2
1
3
100
10
3
BZD27C7V5P
7
7.9
1
2
100
50
3
BZD27C8V2P
7.7
8.7
1
2
0.03
0.08
100
10
3
BZD27C9V1P
8.5
9.6
2
4
0.03
0.08
50
10
5
BZD27C10P
9.4
10.6
2
4
0.05
0.09
50
7
7.5
BZD27C11P
10.4
11.6
4
7
0.05
0.1
50
4.0
8.2
BZD27C12P
11.4
12.7
4
7
0.05
0.1
50
3.0
9.1
BZD27C13P
12.4
14.1
5
10
0.05
0.1
50
2
10
BZD27C15P
13.8
15.6
5
10
0.05
0.1
50
1
11
BZD27C16P
15.3
17.1
6
15
0.06
0.11
25
1
12
BZD27C18P
16.8
19.1
6
15
0.06
0.11
25
1
13
BZD27C20P
18.8
21.2
6
15
0.06
0.11
25
1
15
BZD27C22P
20.8
23.3
6
15
0.06
0.11
25
1
16
BZD27C24P
22.8
25.6
7
15
0.06
0.11
25
1
18
BZD27C27P
25.1
28.9
7
15
0.06
0.11
25
1
BZD27C30P
28
32
8
15
0.06
0.11
25
1
22
BZD27C33P
31
35
8
15
0.06
0.11
25
1
24
BZD27C36P
34
38
21
40
0.06
0.11
10
1
27
BZD27C39P
37
41
21
40
0.06
0.11
10
1
30
BZD27C43P
40
46
24
45
0.07
0.12
10
1
33
BZD27C47P
44
50
24
45
0.07
0.12
10
1
36
BZD27C51P
48
54
25
60
0.07
0.12
10
1
39
BZD27C56P
52
60
25
60
0.07
0.12
10
1
43
BZD27C62P
58
66
25
80
0.08
0.13
10
1
47
BZD27C68P
64
72
25
80
0.08
0.13
10
1
51
BZD27C75P
70
79
30
100
0.08
0.13
10
1
56
BZD27C82P
77
87
30
100
0.08
0.13
10
1
62
BZD27C91P
85
96
60
200
0.08
0.13
5
1
68
BZD27C100P
94
106
60
200
0.09
0.13
5
1
75
BZD27C110P
104
116
80
250
0.09
0.13
5
1
82
BZD27C120P
114
127
80
250
0.09
0.13
5
1
91
BZD27C130P
124
141
110
300
0.09
0.13
5
1
100
BZD27C150P
138
156
130
300
0.09
0.13
5
1
110
BZD27C160P
153
171
150
350
0.09
0.13
5
1
120
BZD27C180P
168
191
180
400
0.09
0.13
5
1
130
BZD27C200P
188
212
200
500
0.09
0.13
5
1
150
Note:1.Pulse test:tp≤5ms.
ht t p : //
www.lgesem i .c o m
BZD27C Series
J
When used as protection diodes
Partnumber
Rev.Breakdown
voltage
Test
current
Temperature
coefficient
V(BR)R@Itest
Itest
αz@Itest
VC
V
mA
V
min
Clamping
voltage
min
max
max
Reverse current at
stand-off voltage
@IRSM1)
A
IR
@Vwm
µA
V
max
BZD27C7V5P
7
100
11.3
13.3
1500
6.2
BZD27C8V2P
7.7
100
0.03
0.08
12.3
12.2
1200
6.8
BZD27C9V1P
8.5
50
0.03
0.08
13.3
11.3
100
7.5
BZD27C10P
9.4
50
0.05
0.09
14.8
10.1
BZD27C11P
10.4
50
0.05
0.1
15.7
9.6
5
9.1
BZD27C12P
11.4
50
0.05
0.1
17
8.8
5
10.0
BZD27C13P
12.4
50
0.05
0.1
18.9
7.9
5
11
BZD27C15P
13.8
50
0.05
0.1
20.9
7.2
5
12
BZD27C16P
15.3
25
0.06
0.11
22.9
6.6
5
13
BZD27C18P
16.8
25
0.06
0.11
25.6
5.9
5
15
BZD27C20P
18.8
25
0.06
0.11
28.4
5.3
5
16
BZD27C22P
20.8
25
0.06
0.11
31
4.8
5
18
BZD27C24P
22.8
25
0.06
0.11
33.8
4.4
5
BZD27C27P
25.1
25
0.06
0.11
38.1
3.9
5
22
BZD27C30P
28
25
0.06
0.11
42.2
3.6
5
24
BZD27C33P
31
25
0.06
0.11
46.2
3.2
5
27
BZD27C36P
34
10
0.06
0.11
50.1
3
5
30
BZD27C39P
37
10
0.06
0.11
54.1
2.8
5
33
BZD27C43P
40
10
0.07
0.12
60.7
2.5
5
36
BZD27C47P
44
10
0.07
0.12
65.5
2.3
5
39
BZD27C51P
48
10
0.07
0.12
70.8
2.1
5
43
BZD27C56P
52
10
0.07
0.12
78.6
1.9
5
47
BZD27C62P
58
10
0.08
0.13
86.5
1.7
5
51
BZD27C68P
64
10
0.08
0.13
94.4
1.6
5
56
BZD27C75P
70
10
0.08
0.13
103.5
1.5
5
62
BZD27C82P
77
10
0.08
0.13
114
1.3
5
68
BZD27C91P
85
5
0.09
0.13
126
1.2
5
75
BZD27C100P
94
5
0.09
0.13
139
1.1
5
82
BZD27C110P
104
5
0.09
0.13
139
0.72
5
91
BZD27C120P
114
5
0.09
0.13
152
0.65
5
100
BZD27C130P
124
5
0.09
0.13
169
0.59
5
110
BZD27C150P
138
5
0.09
0.13
187
0.53
5
120
BZD27C160P
153
5
0.09
0.13
205
0.48
5
130
BZD27C180P
168
5
0.09
0.13
229
0.43
5
150
BZD27C200P
188
5
0.09
0.13
254
0.39
5
160
Note:1)Non-repetitive peak reverse current in accordance with"IEC 60-1,Section 8"(10/1000µs pulse);see Fig.4.
ht t p : //
www.lgesem i .c o m
BZD27C Series
Ratings AND Charactieristic Curves
Figure 2. Maximum Pulse Power Dissipation vs. Zener Voltage
Figure 1. Forward Current vs. Forward Voltage
10.00
160
Typ. VF
PRSM–Max. Pulse Power Dissipation ( W )
I F – Forward Current ( A )
140
Max. VF
1.00
0.10
0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6
120
100
80
60
40
VF – Forward Voltage ( V )
75 100 125 150 175 200
V Znom – Zener Voltage ( V )
Figure 3. Typ. Diode Capacitance vs. Reverse Voltage
C D – Typ. Junction Capacitance ( pF )
50
Figure 4. Non-Repetitive Peak Reverse Current Pulse Definition
10000
C5V1P
C6V8P
C12P
IRSM
100
90
C18P
1000
t1 = 10 µs
t2 = 1000 µ s
50
100
C27P
C51P
10
C200P
10
0.0
0.5
1.0
1.5
2.0
2.5
VR – Reverse Voltage (V)
t
t1
3.0
t2
Figure 5. Power Dissipation vs. Ambient Temperature
Ptot –Power Dissipation ( W )
3.0
tie point temperature
2.5
2.0
1.5
ambient temperature
1.0
0.5
0.0
50
75
100
125
150
Tamb – Ambient Temperature ( qC )
ht t p : //
www.lgesem i .c o m
很抱歉,暂时无法提供与“BZD27C33P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.62220
- 100+0.48108
- 国内价格
- 10+0.68570
- 100+0.53018
- 300+0.45242
- 3000+0.39410
- 6000+0.34744
- 9000+0.32400
