SRF2020 – SRF20150
Taiwan Semiconductor
20A, 20V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
A
VRRM
20 - 150
V
IFSM
200
A
TJ MAX
125, 150
°C
Package
ITO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
Storage temperature
SRF
SRF
SRF
SRF
SRF
SRF
SRF
SRF
2020 2030 2040 2050 2060 2090 20100 20150
SRF SRF SRF SRF SRF SRF
SRF
SRF
UNIT
VRRM
40
50
60
90
100
150
V
VR(RMS)
14
21
28
35
42
63
70
105
V
IF
A
IFSM
200
A
TJ
-55 to +125
TSTG
-55 to +150
-55 to +150
1
°C
°C
Version: J2105
SRF2020 – SRF20150
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.55
V
0.70
V
0.92
V
1.02
V
500
µA
100
µA
15
mA
10
mA
mA
mA
5
mA
SRF2020
SRF2030
SRF2040
Forward voltage per diode
(1)
SRF2050
SRF2060
IF = 10A,TJ = 25°C
VF
SRF2090
SRF20100
SRF20150
SRF2020
SRF2030
SRF2040
Reverse current @ rated VR per
diode
(2)
SRF2050
SRF2060
TJ = 25°C
IR
SRF2090
SRF20100
SRF20150
SRF2020
SRF2030
SRF2040
diode
(2)
SRF2050
SRF2060
TJ = 100°C
IR
SRF2090
SRF20100
SRF20150
SRF2020
SRF2030
SRF2040
diode
(2)
SRF2050
SRF2060
TJ = 125°C
IR
SRF2090
SRF20100
SRF20150
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
2
Version: J2105
SRF2020 – SRF20150
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SRF20x
ITO-220AB
50 / Tube
SRF20xH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 20V(SRF2020) to 150V(SRF20150)
2. “H” means AEC-Q101 qualified
3
Version: J2105
SRF2020 – SRF20150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SRF2060 - 20150
CAPACITANCE (pF)
15
10
SRF2020 - 2050
SRF2020-2040
1000
SRF2050-2060
100
SRF2090-20150
5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
1
0.1
TJ=25°C
0.01
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
100
90
100
100 10
SRF2020-2040
10
UF1DLW
1
SRF2050-2060
TJ=125°C
TJ=25°C
0.1
SRF20150
1
SRF2090-20100
0.01
0.1
0.001
0.0 0.3 0.2
0.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.4
0.5
0.60.6 0.7 0.80.8
1.0
0.9
11.2 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
250
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
10
REVERSE VOLTAGE (V)
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
4
(A)
AVERAGE FORWARD CURRENT (A)
25
Version: J2105
1.2
SRF2020 – SRF20150
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: J2105
SRF2020 – SRF20150
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2105
SRF2020 – SRF20150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: J2105
很抱歉,暂时无法提供与“SRF2020 C0G”相匹配的价格&库存,您可以联系我们找货
