SF3001PT – SF3008PT
Taiwan Semiconductor
30A, 50V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Dual rectifier construction, positive center-tap
Glass passivated chip junctions
Superfast recovery time, high voltage
Low forward voltage, high current capability
Low thermal resistance
Low power loss, high efficiency
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
50 - 600
V
IFSM
300
A
TJ MAX
150
°C
Package
TO-247AD (TO-3P)
Configuration
Dual dies
APPLICATIONS
DC to DC converter
Switching mode converters and inverters
Lighting application
Snubber
Freewheeling application
MECHANICAL DATA
Case: TO-247AD (TO-3P)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 301 class 2 whisker test
Mounting torque: 1.13 N⋅m maximum
Polarity: As marked
Weight: 5.60g (approximately)
TO-247AD (TO-3P)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
SF
SF
3001 3002
PT
PT
SF
SF
3001 3002
PT
PT
50
100
35
70
SF
3003
PT
SF
3003
PT
150
105
SF
SF
3004 3005
PT
PT
SF
SF
3004 3005
PT
PT
200
300
140
210
SF
SF
3006 3008 UNIT
PT
PT
SF
SF
3006 3008
PT
PT
400
600
V
280
420
V
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Junction temperature
IF
30
A
IFSM
300
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: J2103
SF3001PT – SF3008PT
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
SF3001PT
SF3002PT
SF3003PT
SF3004PT
SF3005PT
SF3006PT
SF3008PT
Reverse current @ rated VR per diode
Junction capacitance per diode
Reverse recovery time
(2)
IF = 15A, TJ = 25°C
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
0.95
V
1.30
V
1.70
V
10
µA
500
µA
CJ
175
pF
trr
35
ns
VF
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SF30xPT
TO-247AD (TO-3P)
30 / Tube
SF30xPTH
TO-247AD (TO-3P)
30 / Tube
Notes:
1. “x” defines voltage from 50V(SF3001PT) to 600V(SF3008PT)
2. “H” means AEC-Q101 qualified
2
Version: J2103
SF3001PT – SF3008PT
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
30
25
CAPACITANCE (pF)
10
100
5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=100°C
10
TJ=75°C
1
TJ=25°C
0.1
30
40
50
60
70
80
90
100
100010
SF3001PT - SF3004PT
SF3005PT - SF3008PT
UF1DLW
100 1
TJ=125°C
TJ=125°C
10
0.1
1
0.01
TJ=25°C
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6
0.3
0.4
0.5
0.6
0.7
0.8
0.9
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
330
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
1000
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
300
270
240
210
180
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
35
Version: J2103
1.2
SF3001PT – SF3008PT
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: J2103
SF3001PT – SF3008PT
PACKAGE OUTLINE DIMENSIONS
TO-247AD (TO-3P)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2103
SF3001PT – SF3008PT
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2103
很抱歉,暂时无法提供与“SF3008PTHC0G”相匹配的价格&库存,您可以联系我们找货
