HERAF1604G C0G
HERAF1604G C0G
    TAIWANSEMICONDUCTOR(台半)
    TO220-2
    DIODE GEN PURP 300V 16A ITO220AC
HERAF1604G C0G 数据手册
HERAF1601G – HERAF1606G Taiwan Semiconductor 16A, 50V - 600V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High reliability High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 16 A VRRM 50 - 600 V IFSM 250 A TJ MAX 150 °C Package ITO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) HERAF HERAF HERAF HERAF HERAF HERAF UNIT 1601G 1602G 1603G 1604G 1605G 1606G HERAF HERAF HERAF HERAF HERAF HERAF 1601G 1602G 1603G 1604G 1605G 1606G 50 100 200 300 400 600 V 35 70 140 210 280 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 16 A IFSM 250 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: K2105 HERAF1601G – HERAF1606G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) CONDITIONS HERAF1601G HERAF1602G HERAF1603G HERAF1604G IF = 16A, TJ = 25°C HERAF1605G SYMBOL Junction capacitance Reverse recovery time (2) TJ = 25°C TJ = 125°C HERAF1601G HERAF1602G HERAF1603G HERAF1604G 1MHz, VR = 4.0V HERAF1605G HERAF1606G HERAF1601G HERAF1602G HERAF1603G IF = 0.5A, IR = 1.0A HERAF1604G Irr = 0.25A HERAF1605G HERAF1606G MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 10 µA - 400 µA 150 - pF 110 - pF - 50 ns - 80 ns VF HERAF1606G Reverse current @ rated VR TYP IR CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING HERAF16xG ITO-220AC 50 / Tube HERAF16xGH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 50V(HERAF1601G) to 600V(HERAF1606G) 2. “H” means AEC-Q101 qualified 2 Version: K2105 HERAF1601G – HERAF1606G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 16 HERAF1601G-1005G CAPACITANCE (pF) 12 8 100 HERAF1606G 10 4 0 f=1.0MHz Vsig=50mVp-p 1 25 50 75 100 125 150 1 10 CASE TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 1000 TJ=125°C 100 10 TJ=25°C 1 20 30 40 50 60 70 80 90 100 100 10 1 HERAF1601G-1604G UF1DLW 10 TJ=125°C TJ=25°C 0.1 HERAF1605G 1 0.01 HERAF1606G 0.001 0.1 0.3 0.4 0.5 0.4 0.6 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width Pulse width 300μs 1% duty cycle 0.6 1 0.7 1.2 0.8 1.4 0.9 1.6 1 1.1 1.8 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 300 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 20 250 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2105 1.2 HERAF1601G – HERAF1606G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2105 HERAF1601G – HERAF1606G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2105 HERAF1601G – HERAF1606G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2105
HERAF1604G C0G 价格&库存
很抱歉,暂时无法提供与“HERAF1604G C0G”相匹配的价格&库存,您可以联系我们找货
