MUR4L20HR0G
MUR4L20HR0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE GEN PURP 200V 4A DO201AD
MUR4L20HR0G 数据手册
MUR4L20 – MUR4L60 Taiwan Semiconductor 4A, 200V - 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ultra fast recovery time for high efficiency Excellent high temperature switching Glass passivated chip junction RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application PARAMETER VALUE UNIT IF 4 A VRRM 200 - 600 V IFSM 125 A TJ MAX 175 °C Package DO-201AD Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.20g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device MUR4L20 MUR4L40 MUR4L60 UNIT MUR4L20 MUR4L40 MUR4L60 Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 4 A IFSM 125 A TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C 1 Version: B2105 MUR4L20 – MUR4L60 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 15 °C/W Junction-to-ambient thermal resistance RӨJA 42 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) MUR4L20 MUR4L40 MUR4L60 MUR4L20 MUR4L40 MUR4L60 MUR4L20 MUR4L40 MUR4L60 Junction capacitance Reverse recovery time MUR4L20 MUR4L40 MUR4L60 IF = 4A, TJ = 25°C SYMBOL VF TJ = 25°C IR TJ = 125°C 1MHz, VR = 4.0V CJ IF = 0.5A, IR = 1.0A, Irr = 0.25A trr TYP MAX UNIT - 0.89 V - 1.28 V - 5 µA - 10 µA - 150 µA - 250 µA 65 - pF - 25 ns - 50 ns Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MUR4Lx DO-201AD 1,250 / Tape & Reel MUR4Lx A0G DO-201AD 500 / Ammo box MUR4LxH DO-201AD 1,250 / Tape & Reel MUR4LxHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 200V (MUR4L20) to 600V (MUR4L60) 2. “H” means AEC-Q101 qualified 2 Version: B2105 MUR4L20 – MUR4L60 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 4 CAPACITANCE (pF) 3 2 100 1 f=1.0MHz Vsig=50mVp-p 0 10 25 50 75 100 125 150 175 0.1 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 0.1 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 1 UF1DLW MUR4L20 TJ=125°C TJ=25°C 10.1 MUR4L40-4L60 0.01 0.1 0.001 0.3 0.5 0.3 0.4 Pulse width 300μs 1% duty cycle Pulse width 0.7 0.5 0.9 0.6 1.1 1.3 1.5 0.7 0.8 0.9 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 100 0.01 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 5 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: B2105 1.2 MUR4L20 – MUR4L60 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: B2105 MUR4L20 – MUR4L60 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2105
MUR4L20HR0G 价格&库存
很抱歉,暂时无法提供与“MUR4L20HR0G”相匹配的价格&库存,您可以联系我们找货
