TBS608 M1G
TBS608 M1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    6A 800V STANDARD BRIDGE RECTIFIE
TBS608 M1G 数据手册
TBS606 – TBS610 Taiwan Semiconductor 6A, 600V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement UL Recognized File # E-326854 Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application PARAMETER VALUE UNIT IF 6 A VRRM 600 - 1000 V IFSM 150 A TJ MAX 150 °C Package TBS Configuration Quad MECHANICAL DATA ● ● ● ● ● ● Case: TBS Molding compound meets UL 94V-0 flammability rating Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1 whisker test Polarity: As marked Weight: 0.220g (approximately) TBS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TBS606 TBS608 TBS610 TBS606 TBS608 TBS610 UNIT Repetitive peak reverse voltage VRRM 600 800 1000 V Reverse voltage, total rms value VR(RMS) 420 560 700 V Forward current Surge peak forward current single half sine-wave superimposed on rated load IF t = 8.3ms IFSM t = 1.0ms 6 A 150 A 400 A Rating for fusing (t
TBS608 M1G 价格&库存
很抱歉,暂时无法提供与“TBS608 M1G”相匹配的价格&库存,您可以联系我们找货
