1N5817 – 1N5819
Taiwan Semiconductor
1A, 20V - 40V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low forward voltage drop
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
20 - 40
V
IFSM
30
A
TJ MAX
125
°C
Package
DO-204AL (DO-41)
Configuration
Single die
MECHANICAL DATA
Case: DO-204AL (DO-41)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.330g (approximately)
DO-204AL (DO-41)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
1N5817
1N5818
1N5819
1N5817
1N5818
1N5819
UNIT
Repetitive peak reverse voltage
VRRM
40
V
Reverse voltage, total rms value
VR(RMS)
14
21
28
V
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
Critical rate of rise of off-state voltage
IF
1
A
IFSM
30
A
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +125
°C
Storage temperature
TSTG
-55 to +125
°C
1
Version: H2104
1N5817 – 1N5819
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
100
°C/W
Junction-to-case thermal resistance
RӨJC
45
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
1N5817
Forward voltage
(1)
1N5818 IF = 1A, TJ = 25°C
VF
1N5819
Reverse current @ rated VR
(2)
Junction capacitance
TJ = 25°C
IR
TJ = 100°C
1MHz, VR = 4.0V
CJ
TYP
MAX
UNIT
0.45
V
0.55
V
0.60
V
1
mA
10
mA
55
pF
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
1N581x
DO-204AL (DO-41)
5,000 / Tape & Reel
1N581x A0G
DO-204AL (DO-41)
3,000 / Ammo box
1N581xH
DO-204AL (DO-41)
5,000 / Tape & Reel
1N581xHA0G
DO-204AL (DO-41)
3,000 / Ammo box
Notes:
1. “x” defines voltage from 20V (1N5817) to 40V (1N5819)
2. “H” means AEC-Q101 qualified
2
Version: H2104
1N5817 – 1N5819
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
CAPACITANCE (pF)
1
100
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
0.1
125
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
10 10
UF1DLW
1
1N5817
TJ=125°C
1
0.1
TJ=25°C
1N5818-1N5819
0.01
0.1
0.001
0.0
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.2
0.4
0.4
0.5
0.6
0.8
0.6
0.7
0.8
1.0
0.9
1.2
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
35
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
2
30
8.3ms single half sine wave
25
10
5
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: H2104
1.2
1N5817 – 1N5819
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: H2104
1N5817 – 1N5819
PACKAGE OUTLINE DIMENSIONS
DO-204AL (DO-41)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: H2104
1N5817 – 1N5819
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2104
很抱歉,暂时无法提供与“1N5818 B0G”相匹配的价格&库存,您可以联系我们找货
