BC807-40 RFG
BC807-40 RFG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-23
    BC807-40 RFG
BC807-40 RFG 数据手册
BC807-16/-25/-40 Taiwan Semiconductor 0.3W, PNP Plastic-Encapsulate Transistor FEATURES ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter PARAMETER VALUE UNIT VCBO -50 V VCEO -45 V VEBO -5 V IC -0.5 A hFE 250-600 Package SOT-23 Configuration Single die MECHANICAL DATA ● ● ● ● ● Case: SOT-23 Molding compound meets UL 94 V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Weight: 0.008grams (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device BC807-16 SYMBOL VALUE 5A BC807-25 5B BC807-40 5C Power dissipation UNIT PD 0.3 W Collector-base voltage, emitter open IC = -10 μA, IE = 0 VCBO -50 V Collector-emitter voltage, base open IC = -10 mA, IB = 0 VCEO -45 V Emitter-base voltage, collector open IE = -1 μA, IC = 0 VEBO -5 V Collector current, dc IC -0.5 A Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: J2001 BC807-16/-25/-40 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Collector cutoff current, emitter open Emitter cutoff current, collector open SYMBOL MIN TYP MAX UNIT VCB = -45 V, IE = 0 ICBO - - -0.1 µA VEB = -4 V, IC = 0 IEBO - - -0.1 µA 100 - 250 160 - 400 250 - 600 BC807-16 DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage Transition frequency VCE = -1 V, IC = -100 mA BC807-25 hFE BC807-40 IC = -500 mA, IB = -50 mA VCE(sat) - - -0.7 V IC = -500 mA, IB = -50 mA VBE(sat) - - -1.2 V fT 100 - - MHz VCE = -5 V , IC = -10 mA, f= 50MHz ORDERING INFORMATION ORDERING CODE (Note1, 2) PACKAGE PACKING BC807-XX RF SOT-23 3K / 7" Reel BC807-XX RFG SOT-23 3K / 7" Reel Note: 1. "xx" is Device Code is"16" and "25" and "40" 2. “G” means green compound (halogen free) 2 Version: J2001 BC807-16/-25/-40 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Power Derating Curve Fig. 2 Gain Bandwidth Product VS. Collector Current 1000 fT, Gain Bandwidth Product (MHz) PD, Power Dissipation (mW) 400 300 200 100 0 TA = 25 oC f = 20 MHz -VCE = 5.0 V 100 -VCE = 1 V 10 0 50 100 150 200 1 10 100 1000 IC, Collector Current (mA) TSB, Substrate Temperature (oC) Fig.3 Collector Sat Voltage VS. Collector Current Fig.4 DC Current Gain VS. Collector Current 1000 1000 -VCE = 1V 150 oC 100 25 oC hFE , DC Current Gain -IC, Collector Current (mA) - 50 oC Typical - - - - - - - - Limits at TA = 25 oC 10 150 oC 1 -IC / -IB = 10 0.1 25 oC 100 - 50 oC 10 0 0.1 0.2 0.3 0.4 0.5 0.1 1 10 100 1000 -IC , Collector Current (mA) -VCESAT , Collector Saturation Voltage (V) 3 Version: J2001 BC807-16/-25/-40 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Typical Emitter-Collector Characteristics Fig. 6 Typical Transient Thermal Characteristics 100 2.8 400 0.4 2.4 3.2 1.4 -IC , Collector Current ( mA ) -Ic , Collector Current (mA) 500 2.0 1.8 1.6 300 1.2 1.0 200 0.8 0.6 100 0.35 80 0.3 60 0.25 0.2 40 0.15 20 0.1 0.4 - IB = 0.05 mA - IB = 0.2 mA 0 0 1 -VCE , Collector-Emitter Voltage (V) 0 2 0 4 10 -VCE , Collector-Emitter Voltage (V) 20 Version: J2001 BC807-16/-25/-40 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION SOT-23 SUGGESTED PAD LAYOUT 5 Version: J2001 BC807-16/-25/-40 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: J2001
BC807-40 RFG 价格&库存
很抱歉,暂时无法提供与“BC807-40 RFG”相匹配的价格&库存,您可以联系我们找货
BC807-40 RFG
  • 1+2.206311+0.28580
  • 10+1.3397810+0.17355
  • 100+0.83201100+0.10778
  • 500+0.60941500+0.07894
  • 1000+0.537221000+0.06959
库存:1563
BC807-40 RFG
  • 3000+0.364003000+0.04715
  • 6000+0.324916000+0.04209
  • 9000+0.304959000+0.03951
  • 15000+0.2825115000+0.03660
  • 21000+0.2692121000+0.03488
  • 30000+0.2562730000+0.03320
库存:1563
BC807-40 RFG
