SF2002GHC0G
SF2002GHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE GEN PURP 100V 20A TO220AB
SF2002GHC0G 数据手册
SF2001G – SF2008G Taiwan Semiconductor 20A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 20 A VRRM 50 - 600 V IFSM 150 A TJ MAX 150 °C Package TO-220AB Configuration Dual dies ● DC to DC converters ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.82g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) SF SF SF SF SF SF SF SF PARAMETER SYMBOL UNIT 2001G 2002G 2003G 2004G 2005G 2006G 2007G 2008G Marking code on the SF SF SF SF SF SF SF SF device 2001G 2002G 2003G 2004G 2005G 2006G 2007G 2008G Repetitive peak VRRM 50 100 150 200 300 400 500 600 V reverse voltage Reverse voltage, total VR(RMS) 35 70 105 140 210 280 350 420 V rms value Forward current IF 20 A Surge peak forward current, 8.3ms single half sine wave IFSM 150 A superimposed on rated load Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 1 °C Version: I2104 SF2001G – SF2008G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 2.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SF2001G SF2002G SF2003G SF2004G (1) Forward voltage per diode I = 10A, TJ = 25°C SF2005G F SF2006G SF2007G SF2008G TJ = 25°C (2) Reverse current @ rated VR per diode TJ = 125°C Junction capacitance per diode Reverse recovery time 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 5 µA - 400 µA CJ 80 - pF trr - 35 ns VF IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SF20xG TO-220AB 50 / Tube SF20xGH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 50V(SF2001G) to 600V(SF2008G) 2. “H” means AEC-Q101 qualified 2 Version: I2104 SF2001G – SF2008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Junction Capacitance 24 100 20 90 CAPACITANCE (pF) 16 12 8 4 80 70 60 50 0 f=1.0MHz Vsig=50mVp-p 40 25 50 75 100 125 150 1 10 CASE TEMPERATURE (°C) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 10 TJ=100°C TJ=75°C TJ=25°C 0.1 10 20 30 40 50 60 70 80 90 100 100 10 SF2001G-2004G 1 SF2005G-2006G UF1DLW 10 TJ=125°C TJ=25°C 0.1 SF2007G-2008G 1 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.4 0.30.6 0.40.8 0.51.0 0.61.2 0.7 1.4 0.8 1.6 0.9 1.8 2.0 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 175 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 1 100 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) Fig.1 Forward Current Derating Curve 150 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2104 1.2 SF2001G – SF2008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: I2104 SF2001G – SF2008G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2104 SF2001G – SF2008G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2104
SF2002GHC0G 价格&库存
很抱歉,暂时无法提供与“SF2002GHC0G”相匹配的价格&库存,您可以联系我们找货
