SFA1002G C0G
SFA1002G C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE GEN PURP 100V 10A TO220AC
SFA1002G C0G 数据手册
SFA1001G – SFA1008G Taiwan Semiconductor 10A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High reliability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C Package TO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.80g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SYMBOL SFA SFA SFA SFA SFA SFA SFA SFA UNIT 1001G 1002G 1003G 1004G 1005G 1006G 1007G 1008G SFA SFA SFA SFA SFA SFA SFA SFA 1001G 1002G 1003G 1004G 1005G 1006G 1007G 1008G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V IF 10 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: K2103 SFA1001G – SFA1008G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 3.5 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) Junction capacitance Reverse recovery time CONDITIONS SFA1001G SFA1002G SFA1003G SFA1004G I = 10A, TJ = 25°C SFA1005G F SFA1006G SFA1007G SFA1008G TJ = 25°C TJ = 100°C SFA1001G SFA1002G SFA1003G SFA1004G 1MHz, VR = 4.0V SFA1005G SFA1006G SFA1007G SFA1008G IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 10 µA - 400 µA - 70 pF - 50 pF - 35 ns VF IR CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SFA10xG TO-220AC 50 / Tube SFA10xGH TO-220AC 50 / Tube Notes: 1. “x” defines voltage from 50V(SFA1001G) to 600V(SFA1008G) 2. “H” means AEC-Q101 qualified 2 Version: K2103 SFA1001G – SFA1008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Junction Capacitance 12 100 10 90 CAPACITANCE (pF) 8 6 4 2 SFA1001G-1004G 80 70 SFA1005G-1008G 60 50 0 f=1.0MHz Vsig=50mVp-p 40 25 50 75 100 125 150 1 10 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 10 1 TJ=25°C 0.1 30 40 50 60 70 80 90 100 10 100 1 SFA1001G-1004G UF1DLW 10 TJ=125°C TJ=25°C 0.1 SFA1005G-1006G 1 0.01 SFA1007G-1008G Pulse width 300μs Pulse width 1% duty cycle 0.001 0.1 0.40.3 0.60.4 0.80.5 1 0.61.2 0.71.4 0.81.6 0.9 1.8 1 2 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.4 Typical Forward Characteristics 100 20 1000 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) Fig.1 Forward Current Derating Curve 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2103 1.2 SFA1001G – SFA1008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2103 SFA1001G – SFA1008G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2103 SFA1001G – SFA1008G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2103
SFA1002G C0G 价格&库存
很抱歉,暂时无法提供与“SFA1002G C0G”相匹配的价格&库存,您可以联系我们找货
