S15DLW – S15MLW
Taiwan Semiconductor
1.5A, 200V - 1000V Standard Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Ideal for automated placement
Compact package size
High surge current capability
Low power loss, high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1.5
A
VRRM
200 - 1000
V
IFSM
50
A
TJ MAX
175
°C
Package
SOD-123W
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: SOD-123W
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.019g (approximately)
SOD-123W
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
S15DLW S15GLW S15JLW S15KLW S15MLW UNIT
15DLW
15GLW
15JLW
15KLW
15MLW
Repetitive peak reverse voltage
VRRM
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
560
700
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
1.5
A
IFSM
50
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: C2103
S15DLW – S15MLW
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
29
°C/W
Junction-to-ambient thermal resistance
RӨJA
85
°C/W
Junction-to-case thermal resistance
RӨJC
31
°C/W
Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 1.0A, TJ = 25°C
Forward voltage
IF = 1.5A, TJ = 25°C
(1)
IF = 1.0A, TJ = 125°C
VF
IF = 1.5A, TJ = 125°C
Reverse current @ rated VR
(2)
Junction capacitance
TJ = 25°C
IR
TJ = 125°C
1MHz, VR = 4.0V
CJ
TYP
MAX
UNIT
0.94
1.05
V
0.98
1.10
V
0.81
1.00
V
0.87
1.05
V
1
µA
100
µA
10
pF
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S15xLW
SOD-123W
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(S15DLW) to 1000V(S15MLW)
2
Version: C2103
S15DLW – S15MLW
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
1.5
CAPACITANCE (pF)
1.0
0.5
0.0
25
55
85
115
145
10
1
f=1.0MHz
Vsig=50mVp-p
0.1
175
1
10
LEAD TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
10
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.3 Typical Reverse Characteristics
TJ=125°C
1
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
100
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10 10
1
1
0.1
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
TJ=25°C
0.01
0.1
0.001
0.6
0.7
0.8
0.9
0.3
0.4
0.5
0.6
Pulse width 300μs
1% duty cycle
Pulse width
1.0
0.7
1.1
0.8
FORWARD VOLTAGE (V)
3
(A)
AVERAGE FORWARD CURRENT (A)
2.0
1.2
0.9
1.3
1
1.1
Version: C2103
1.2
S15DLW – S15MLW
PACKAGE OUTLINE DIMENSIONS
SOD-123W
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: C2103
S15DLW – S15MLW
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: C2103
很抱歉,暂时无法提供与“S15MLWHRVG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 12000+0.8062512000+0.10461
