TSI30H120CW C0G
TSI30H120CW C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-262
    DIODE ARRAY SCHOTTKY 120V I2PAK
TSI30H120CW C0G 数据手册
TSI30H100CW – TSI30H200CW Taiwan Semiconductor 20A, 100V - 200V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ high efficiency High forward surge capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 30 A VRRM 100 - 200 V IFSM 200 A TJ MAX 150 °C 2 Package TO-262 (I PAK) Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-262 (I PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: As marked Weight: 1.60g (approximately) 2 TO-262 (I PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM TSI30H 100CW TSI30H 100CW 100 Reverse voltage, total rms value VR(RMS) 70 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage TSI30H 120CW TSI30H 120CW 120 TSI30H 150CW TSI30H 150CW 150 84 105 TSI30H UNIT 200CW TSI30H 200CW 200 V 140 V IF 30 A IFSM 200 A dv/dt 10,000 V/µs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: E2104 TSI30H100CW – TSI30H200CW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2.7 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TSI30H100CW TSI30H120CW TSI30H150CW Forward voltage per diode (1) TSI30H200CW VF TSI30H100CW TSI30H120CW TSI30H150CW Reverse current @ rated VR (2) per diode IF = 15A, TJ = 25°C TSI30H200CW TSI30H100CW TSI30H120CW TSI30H150CW TSI30H200CW TSI30H100CW TSI30H120CW TSI30H150CW TSI30H200CW IF = 15A, TJ = 125°C TYP MAX UNIT 0.69 0.78 V 0.75 0.84 V 0.81 0.90 V 0.84 0.92 V 0.61 0.68 V 0.64 0.73 V 0.68 0.77 V 0.70 0.79 V - 250 µA - 150 µA - 35 mA - 20 mA TJ = 25°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) TSI30HxCW PACKAGE 2 TO-262 (I PAK) PACKING 50 / Tube Notes: 1. "x" defines voltage from 100V (TSI30H100CW) to 200V (TSI30H200CW) 2 Version: E2104 TSI30H100CW – TSI30H200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 TSI30H100CW TSI30H120CW TSI30H100CW 25 TSI30H150CW TSI30H200CW 15 10 1000 TSI30H120CW TSI30H150CW 100 TSI30H200CW 5 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 TJ=150°C 10 TJ=125°C 1 TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10010 TSI30H100CW 10 UF1DLW 1 TJ=150°C TJ=125°C TJ=125°C 0.1 1 TJ=25°C 0.01 0.1 0.1 0.001 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TSI30H120CW TJ=150°C TJ=125°C TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 0.5 0.6 0.7 0.7 0.8 0.9 0.9 1.1 1 1.1 1.2 1.1 1.2 Fig.6 Typical Forward Characteristics 100 0.1 0.5 FORWARD VOLTAGE (V) Fig.5 Typical Reverse Characteristics 1 TJ=25°C TJ=100°C PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics TSI30H100CW 10 (A) 20 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 TSI30H120CW 10 UF1DLW 1 TJ=150°C TJ=125°C TJ=125°C 0.1 TJ=25°C (A) 30 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 35 TJ=100°C 1 TJ=25°C 0.01 0.1 0.001 0.1 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 0.5 0.7 0.5 0.6 0.7 0.9 0.8 1.1 0.9 1 FORWARD VOLTAGE (V) 3 Version: E2104 TSI30H100CW – TSI30H200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.8 Typical Forward Characteristics TSI30H150CW TJ=150°C 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 TSI30H150CW 10 UF1DLW 1 TJ=150°C TJ=125°C TJ=125°C 0.1 TJ=100°C 1 TJ=25°C 0.01 0.1 0.001 0.1 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TSI30H200CW TJ=150°C TJ=125°C TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 0.9 0.8 1.1 0.9 1 1.1 1.2 1.1 1.2 Fig.10 Typical Forward Characteristics 10 0.1 0.5 0.7 0.5 0.6 0.7 FORWARD VOLTAGE (V) Fig.9 Typical Reverse Characteristics 1 TJ=25°C 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 TSI30H200CW 10 1 0.1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=100°C TJ=25°C (A) 10 10010 (A) 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.7 Typical Reverse Characteristics 1 TJ=25°C 0.01 0.1 0.001 0.1 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 0.5 0.5 0.6 0.7 0.7 0.8 0.9 0.9 1.1 1 FORWARD VOLTAGE (V) 4 Version: E2104 TSI30H100CW – TSI30H200CW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-262 (I PAK) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: E2104 TSI30H100CW – TSI30H200CW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: E2104
TSI30H120CW C0G 价格&库存
很抱歉,暂时无法提供与“TSI30H120CW C0G”相匹配的价格&库存,您可以联系我们找货
TSI30H120CW C0G
  • 1+10.003431+1.29136
库存:2000
TSI30H120CW C0G
  • 6+10.177916+1.31389
库存:2000
