SF61G – SF68G
Taiwan Semiconductor
6A, 50V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High current capability, Low VF
High reliability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
6
A
VRRM
50 - 600
V
IFSM
150
A
TJ MAX
150
°C
APPLICATIONS
Package
DO-201AD
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: DO-201AD
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 1.20g (approximately)
DO-201AD
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward
current, 8.3ms single half
sine wave superimposed
on rated load
Junction temperature
Storage temperature
SF
61G
SF
61G
SF
62G
SF
62G
SF
63G
SF
63G
SF
64G
SF
64G
SF
65G
SF
65G
SF
66G
SF
66G
SF
67G
SF
67G
SF
UNIT
68G
SF
68G
VRRM
50
100
150
200
300
400
500
600
V
VR(RMS)
35
70
105
140
210
280
350
420
V
SYMBOL
IF
6
A
IFSM
150
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: G2105
SF61G – SF68G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
5
°C/W
Junction-to-ambient thermal resistance
RӨJA
40
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
SF61G
SF62G
SF63G
SF64G
SF65G
SF66G
SF67G
SF68G
(1)
Reverse current @ rated VR
TJ = 25°C
(2)
Junction capacitance
IF = 6A, TJ = 25°C
Reverse recovery time
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
5
µA
100
µA
100
pF
50
pF
35
ns
VF
IR
TJ = 125°C
SF61G
SF62G
SF63G
SF64G
SF65G
SF66G
SF67G
SF68G
SYMBOL
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SF6xG
DO-201AD
1,250 / Tape & Reel
SF6xG A0G
DO-201AD
500 / Ammo box
SF6xGH
DO-201AD
1,250 / Tape & Reel
SF6xGHA0G
DO-201AD
500 / Ammo box
Notes:
1. "x" defines voltage from 50V (SF61G) to 600V (SF68G)
2. “H” means AEC-Q101 qualified
2
Version: G2105
SF61G – SF68G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
6
CAPACITANCE (pF)
4
2
SF61G - SF64G
100
SF65G - SF68G
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
10
150
0.1
1
AMBIENT TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
1010
SF61G - SF64G
1
UF1DLW
SF65G - SF66G
TJ=125°C
TJ=25°C
10.1
SF67G - SF68G
0.01
0.1
0.001
0.3
0.5
0.7
0.3
0.4
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse
Pulse width
width 300μs
300μs
1%
Pulse width
1% duty
duty cycle
cycle
0.9
0.6
1.1
0.7
1.3
0.8
1.5
0.9
1.7
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
175
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
8
150
8.3ms single half sine wave
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: G2105
1.2
SF61G – SF68G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: G2105
SF61G – SF68G
PACKAGE OUTLINE DIMENSIONS
DO-201AD
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: G2105
SF61G – SF68G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: G2105
很抱歉,暂时无法提供与“SF67G R0G”相匹配的价格&库存,您可以联系我们找货
